Vibration@slow speeds - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 10-27-2005, 09:22 PM Thread Starter
Ihave 99 F250 with a 7.3 and a 6 speed manual.evr since i bought the truck i have a horrible vibration in 1st gear @ about 2000-2500 rpm which worsens the higher the load. i had the drivline angles checked all run 2 about 2-2.5 degrees driveline has been balanced tires have been balanced u joints replaced steady bearings also replaced but now iam out of ideas. Any ideas would be greatly apprecitated. thanks
Kvizbar is offline
post #2 of 5 (permalink) Old 10-28-2005, 06:40 AM
Re: Vibration@slow speeds
Is it only in first gear? If so I would say that gear is the problem.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
post #3 of 5 (permalink) Old 10-28-2005, 07:23 AM
Sounds like the old dual-mass flywheel/broken spring thing. Feel kinda like an engine miss?
Dunno,
Allan
AllanInNE is offline
post #4 of 5 (permalink) Old 10-28-2005, 11:12 PM Thread Starter
I actually can make it vibrate in second gear if i really load it up, It does kinda feel like an engine miss though. I have a Luk ceramic clutch it in with there flywheel if this helps????
Kvizbar is offline
post #5 of 5 (permalink) Old 10-31-2005, 04:01 PM
KTTA720's Avatar
Mine had a similar problem and it was a clutch problem right aroung 15 mph and it was a clutch bearing, hope this helps
2002 Ford F250 6speed Extended cab long bed XLT sport, black 5in lift 35" tires three 12" Memphis Subs, over 2000w power, Kenwood CD player with video screen. Powerstroke out and 6BT Cummins 12v IN 20MPG!!!!
79W900AEXHD 3406BATA 425, 9X4 60in flattop long wheelbase DS402 on pete air leaf
67 GTO Ram air III 400 10.5:1 compression isky lopin cam, edelbrock cam intake carb and headers, built th400, 5spd soon to come 3:90 Posi
Company stuff:
77 Kenworth, KTA 15over Eatons on Tortion
78 Autocar BC444 15X4 triple frame Hendrickson on SSHD best logger
61 B75 mack on 84 pete frame 400 Cummins 14615 on air ride SQHPs Long and tall Black and chrome
KTTA720 is offline
