Wait to start light wont go out, truck wont start.....Help! - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 08-28-2005, 04:10 PM Thread Starter
the truck will turn over fine and everything acts normal but the WTS light stays on and will not go off and the truck will not fire..anyone have an idea what is going on...help plz..thanks, Jason
2014 Platinum White F250 Lariat 4x4 Super Cab 6.7L SWB
Purchased 4/25/14-3.31 E-Locker-275/70/R18E
Sold-2006 Dodge 2500 5.9L 4x4 Sport
Silver Line 4in Turbo Back-AFE CAI-Smarty-6in Skyjacker Lift-Black 20in Rockstars-37in Khumos
Sold-2002 Silver F250 7.3L 4x4 Crew Cab
Custom 4in Turbo Back Straight Pipe by Lane's Performance-BFG All Terrain 285/75/R16-Wicked Wheel-Sonnax/Tricumulator-EBPV Delete-Isspro EV Series Pyro/Boost/Tranny Gauges-AIH Delete w/ Boost Fitting-DI 6 pos. flip chip High Idle/Stock/Tow/Daily/Race/Extreme-DI Boost Relief Valve-5% Tint
AA777 is offline
post #2 of 4 (permalink) Old 08-28-2005, 06:11 PM
JimTJr's Avatar
My Photos: (20)
Re: Wait to start light wont go out, truck wont start.....Help!
Glow plug relay sticking? Not sure,, It seems to me that the WTS light is CONTROLLED inside the PCM..and the Glow plugs can still be "HOT" with the light off... [img]/ubbthreads/images/graemlins/shrug.gif[/img] Click here,, and save this thread!! Little secrets that are REALLY HANDY! scroll down to GPR threads and it tells how to check the relay.
Really you dont need the GP system right now,,,it should start without it.
Are you sure your getting fuel? Check the level in the filter housing...or simpler...DRAIN it completely and turn the key on ,,see how fast it pumps out...BEFORE YOU DO THIS,,,if you dont already have it...the drain goes down the right side of the motor...and stops. ALOT of us have a piece of fuel line pushed up onto it,,,and ran out thru the cross member hole,,right above the axle housing. THIS way you can put a container under it and see how much you get out....also see the quality of it,, (Water...grime ect...)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #3 of 4 (permalink) Old 08-30-2005, 12:08 PM
Rickie's Avatar
If your problem is your chip, disconnect the battery cables, remove the chip, momentarily short the battery cables together (while disconnected), reconnect the batteries and see if the Wait to Start light goes out. If it does, then more than likely you chip is causing problems.
If you do not have a code reader and you are waiting to find one, this task can be performed fairly easily to at least rule out one possible item.
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade HX Crossover Mod & Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline
post #4 of 4 (permalink) Old 08-30-2005, 03:27 PM
Remove your chip (if you have one) and if it still does it than your pcm needs to be re-flashed or replaced. [img]/ubbthreads/images/graemlins/frown.gif[/img]
2000 psd CC SB 4x4,
This...That...And-The-Other...
OLD Powerstroke 7.3l
620.8HP/1157.9TQ Dunbar's Dyno 5/26/07
New Cummins 5.9l 12v Conversion.
sno_cat is offline
