Warn Hubs and vacuum? - Diesel Forum - TheDieselStop.com
Old 11-24-2009, 07:31 PM   #1 (permalink)
txfxl's Avatar
Well i've had the warn hubs installed on my truck for about a year now and just today realized i didn't do anything with the old vacuum lines that are on there. i don't plan on ever going back to the vacuum operated style hub so what is the best thing to do with the lines?
2000 F250 ext cab 8' Bed, 4x4, AFE Stage II, Warn Premium Locking Hubs, MBRP 4" Turbo Back, 3 Gauge Pillar (Turbo, Pyro, Trans), Racor CCV Filter, AIH Delete With Code Fooler, Wicked Wheel, Oil Crossover Line, Coolant Filter, 203* Thermostat, Stancor GPR, Under Hood Fuel Pressure Gauge, DB Starter, ITP In-Tank Mod, Intenational Bellowed Up-Pipes, Peripheral Ipod Direct Connect
Chip and a valve body in the overtime funded near future
txfxl is offline
Old 11-24-2009, 10:43 PM   #2 (permalink)
Greg03PSD's Avatar
I've got Warn hubs on mine as well. I removed the line & capped the fitting where the line attached. Follow the vacuum line from the end where it connected to the top of the steering knuckle - you should come to an in-line nipple in the fenderwell. Remove the line between that nipple & the knuckle & then put a vacuum line cap on the nipple. You can get little the rubber caps for capping vacuum lines at any auto parts store for a buck or two. They come in several sizes, so just make sure you get the right size. You could also cap the lines near further up, but it's probably not worth the trouble. it probably would not be a bad idea to put a cap on the metal nipple on the steering knuckle to prevent dirt, water, etc. from getting into knuckle.
2003 F-250 4x4, 7.3L PowerStroke
6" Skyjacker Z-link lift, 35" MT Baja MTZ tires
18" Wheels
Warn 16.5Ti winch w/ hidden mount
Front & Rear ARB Air Lockers
Dynatrac Free-Spin Front Hub Conversion
Edge Juice Programmer
Fabtech Ladder Bars
AutoEnginuity w/ Ford Enhanced package - Southeastern Connecticut - Just bring beer!
Greg03PSD is offline
Old 11-25-2009, 10:24 AM   #3 (permalink)
txfxl's Avatar
Awesome, thanks!
txfxl is offline
