hope this helps...
KL1 DIAGNOSTIC TROUBLE CODE (DTC) P1690
- DTC P1690 indicates that the PCM has detected a failure on the WGC circuit.
- Possible causes:
- short to ground
- open in harness
- damaged connection
- damaged WGC solenoid
- damaged PCM
- blown fuse
- Disconnect the WGC solenoid harness connector.
- Key on, engine off.
- Measure voltage between Pin 2 (KEY PWR) on the WGC solenoid harness connector and ground.
- Key off.
Was voltage greater than 10.5 volts?
Yes No GO to
KL2 . REPAIR open in (KEY PWR) Circuit 16, or REPLACE blown fuse. RESTORE vehicle. CLEAR DTCs and RETEST.
KL2 CHECK FOR OPEN IN CONTROL CIRCUIT
- Install breakout box; leave PCM disconnected.
- Measure resistance between Pin 1 on the WGC solenoid harness connector and PCM Test Pin 47.
Is resistance less than 5 ohms?
Yes No GO to
KL3 . REPAIR open in Circuit 1275 (W/R). RESTORE vehicle. CLEAR DTCs and RETEST.
KL3 CHECK FOR SHORT TO GROUND
- Measure resistance between WGC solenoid harness connector Pin 1 and ground.
Is resistance greater than 10,000 ohms?
Yes No GO to
KL4 . REPAIR short to ground on Circuit 1275 (W/R). RESTORE vehicle. CLEAR DTCs and RETEST.
KL4 CHECK WGC SOLENOID
- Measure resistance between Pin 1 and Pin 2 of WGC solenoid harness connector.
Is resistance less than 50 ohms?
Yes No REPLACE the PCM. RESTORE vehicle. CLEAR DTCs and RETEST. REPLACE the WGC solenoid. RESTORE vehicle. CLEAR DTCs and RETEST.
