po603 and i had one that was like po440 or something. what do they mean?
The P0603 relates to a PCM "KAM" error (KAM= "Keep Alive Memory"). This DTC can show up when the battery voltage is low or not present. Did you recently have the batteries unhooked for any reason, or did they get low or go dead?
This code can also be set if the PCM was removed from the truck (again, a no power situation). Also, if it was removed, and possibly during reinstallation, one of the power pins may have been damaged or is not making good contact with the PCM connector: double check your connector, if so.
It could also be a blown fuse in the "KAPWR" ("Keep Alive Power") circuit. Depending on your model-year, this fuse may be located in the fuse-box under the dash, fuse #15 (5 amp). This fuse also supplies power to other things (like the GEM module, 4-wheel antilock, etc.), so those other things may not be getting power as well.
Lastly, the PCM may be experiencing some other internal memory failure issue...meaning the PCM may be bad.
The P0440 has to do with evaporative emmision controls, something you don't have on your diesel-powered truck! Are you sure it was a P0440? You might want to double-check on that one.
By the way, with DTC codes, those are numbers (zeros), not letter o's.
If you can clear the codes (or have them cleared) do it. Then drive awhile and see if they return. Or...they may also go away on their own, after a few drive cycles.
Good luck!
Originally Posted by woodnthings8
PO603 means you probably have a tuner and you changed programming, When you do this it cycles power to the PCM.
FYI: Power is not "cycled" to the PCM when changing tunes. At least not in the "Keep Alive" circuit. The KAM power is supplied directly from the batteries to the PCM (through a fuse, of course). Even with tuners that up-load through the OBD-II connector, the power is never interrupted. However, with some tuners, if/when a new program is uploaded to the PCM, it erases/downloads the original program, which can often cause a memory processing error and result in a "KAM error" DTC, even though the power was never actually interrupted.
Al in SoCal
2000 F350 SRW CC 4X4 AFE Stage II w/PG-7 Garrett 38R Turbo Swamps Stage II Single-shots Stealth Dual-HPOP ITP Custom-modified Regulated-return Fuel System DP-Tuner PCM & F-5 chip (Live tuned!) Autometer Gauges (Pyro, Boost, Eng oil temp)
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
4" Custom S/S Exhaust into 5" Dual Aussie Stacks
ZF 6-Spd "Hand-shaker" Southbend Double-Disc clutch
...plus some other goodies...
so when i changed it from performance tune to tow tune it deleted then reloaded. would that cause the code?
2000 f 250 4x4. ccsb
just hit 206,000
38R with Turbo Master
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
I used an Edge "Evolution" programmer for a while. Whenever I would change programs, I would get a "KAM error" DTC also.
Again, when you change tunes, your messing with the PCM's program. The KAM ("Keep Alive Memory") is what keeps all of the drive-parameters stored and active when the truck is not running (your truck basically "learns" your driving style and remembers it). When you change programs, you have now changed some of the pre-set parameters in the PCM. Now they don't "jive" with what was stored from previous driving. This causes the PCM to generate an ERROR code (something changed in the PCM, without the PCM changing it).
Does that make sense?
Bottom line: don't worry about the code. Does your SuperChips programmer have the ability to read and clear DTC's? (The Edge Evolution does, that's one of the reasons I bought it) If so, just clear the code. It's not a problem. The KAM Error code will most likely return again the next time you change programs. No big deal, just one of the quirks of the computer...
BTW, that's one of the beautiful things about a chip rather than a programmer: instantaneous program changes...on-the-fly...with no codes, no errors. I much prefer the chip over the programmer (better tunes, too!)
Al in SoCal
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
Second that, on the fly is waaaay better....the KAM code should be cleared when you go from perf to tow mode, a good programmer does that automatically, i know SCT and Superchips do, not that they are the best but are OK as handheld tuners go....I am having good results using the SCT on the highest setting now, never had the guts to do it because didn't have the gauges before, but my pyro results have been good so far.
2000 F-350 7.3 PS ,4R100 Lariat Dually http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
