What is needed to run 35" tires - Diesel Forum - TheDieselStop.com
Old 03-07-2005, 10:32 PM   #1 (permalink)
Brother in law has a 2000 F250 4x4. He's wanting to run 35" tires, and had his mind set on a 4" lift. However, this month's Off-Road Adventures from 4 Wheel Parts has a profile of a lifted 2000 Ford on 46" tires. In the article, its states that the truck started off with 35" tires and a 2 inch leveling kit. Neither of us thought about a leveling kit as a way to get 35" tires on. All of the sudden the light bulb turned on !!!
Has anyone on these boards used a leveling kit and 35" tires? What is your experiences? What brands did you find to be the best?
Also, what do you guys consider the minimum rim size to get 35" tires on?
Thanks in advance.
David
_________________________________________
2006 Dodge CTD 325/610 SLT 4x4 Mega Cab
ARE LSII Bed Lid
djp9747 is offline
Old 03-08-2005, 12:05 AM   #2 (permalink)
GS
Re: What is needed to run 35" tires
I have seen SD's leveled and running 315/75r16's. I run mine on a 4" lift w/ stock rims.
Bowhuntr
99.5 Red Metallic F250 SWB 4x4 Off Road, DAC2 PSD CC Lariat, Isspro EV Pyro/Boost, SCMT, SB CON-O, Modified Zoodad Intake w/K&N filter, 4" DPPI exhaust w/6" SS Tip, 6 speed, Man hubs, C/TT, 3.73 LS, 4whl ABS, 4" Procomp/Dual Rancho 9000's, Rear add leaf, 315 BFG MT's. Pulling 30' Savanna 5er
GS is offline
Old 03-08-2005, 12:48 AM   #3 (permalink)
Isn't the stock wheels 7" wide ? I did a quick check on BF Goodrich's web site for the tires listed in your signature, BF Goodrich Mud Terrains, and according to their specs, the minimum wheel width for that tire is 8", a full 1" more than your rim. Isn't this pushing it a bit? Here's the link to the specs
http://www.bfgoodrichtires.com/asset...rain_ta_km.pdf
The reason I ask is that I have 315/70/17 BFG AT on my truck and BFGoodrich recommends a 8.5" minimum rim width, and Dodges come with 8" wide wheels stock. I had 1 Discount tire refuse to put the tires on the wheels because they were .5" smaller than the recommended wheel size by BF Goodrich. They (Discount Tire) cited safety reasons, that said the tire would not get a good seal to the inside of the wheel. They also said that the tire would bubble in the middle because the sidewalls would be pulled in more than they were designed for, thereby increasing the wear in the center of the tire.
David
ARE LSII Bed Lid
djp9747 is offline
Old 03-08-2005, 12:55 AM   #4 (permalink)
My Photos: (27)
Were running 35 BFG all terrains with just 450 springs in the front of our 6.0. It rubs a little on the plastic but it's not bad!
IRAQI WAR VET AND PROUD OF IT!
2008 F250 FX4 6.4
SUPERF350 2006 F350
POWDER COATED CAC TUBES
PROJECT TRUCK 85 F250 4X4 6.9 6.0 IN IRAQ
superf350 is offline
Old 03-08-2005, 10:13 AM   #5 (permalink)
rdvit94's Avatar
I am running 315s with a 3.5" lift. The tires don't rub, but it's close. I think anything under 3" would be cutting it close. I also run 315s on stock rims. Ya they say you're not supposed to, but me and buddy have been doing it for a couple years with no problems. You will get better tire wear and the handling would probably be better with a wider rim. But I can't afford new rims, so I am happy with the stockers
2001 F-350 XLT, CC, LWB, 4x4, Auto, Off-Road, DP-Tuner (stock-40-80-120), SP Diesel Air Intake, MBRP 4" Exhaust, Banks BHA, TAG, Dieselsite BRV, AIH Mod, 203 Stat, Sonnax/Tri Kit, Tank Mods, Redhead Steering Gear, DB Electric Starter, Di Pricol Gauges in A-Pillar, 3.5" Custom Lift, 315/75/16 BFG ATs, Delta Toolbox
Truck Pics
rdvit94 is offline
Old 03-08-2005, 08:05 PM   #6 (permalink)
Mad Max's Avatar
I have 12.5 x 35's on 16.5 rims and my truck only has a leveling kit on it. The last set of BFG's lasted 65K miles and the set that is on my truck has 30K on them and still look good. The major wear that is on them is from my right foot [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
I had to adjust the fender skirt a little to keep them from rubbing. Took all of 20 min to adjust.
If you live in AZ come join us at Arizona Powerstroke Group... Click here
http://www.azpsg.com/index.php?referrerid=6
99.5 F-350 BTS Trans / Termys / Swamps 200/30 AA Injectors / Swamps IDM / GT38R BB Turbo / AFE Stage 2 / DP/ Evans Coolant, ART Rotors / Dynatrac Spin Free HD Front Hubs, 4 inch Stainless Exhaust, Auto Meter Cobalt Gauges.
Mad Max is offline
Old 03-08-2005, 08:49 PM   #7 (permalink)
Running my BFG 315's with nothing more than the Pro Comp Leveling kit. I think it looks great! I only get a slight rub on the edges of the Leaf Pack when turning all the way to the stops.
Early 99 F-350 PSD XL, 4x4,6spd, SPA Digital Gauges, A Pillar install, Swamp's F*ME Injectors, Modified H2E Turbo, Dual HPOP's, 4" Exhaust, Chrome Single Stack, Upgraded PCM (DAC 3), 6pos Chip w/ Swamp's Custom Programming, High Flow Fuel system, Regulated Return Fuel System and Upgraded Fuel Feed Lines, South Bend FE Clutch, Turbo Temp Minder, ESP Performance Pre Luber, PSC Delphi Steering Pump, Fabtech 3.5" Hanger Kit, Bilstein 5100 Shocks, Dynatrac Superduty Hub Conversion, Warn Premium Locking Hubs, Daystar Polyurethane Bushings, 315/75 BFG All Terrains on Alcoa Wheels, CCV Mod, AMSOIL Synthetic Everywhere, FS2500 Bypass Filter, MAG-HYTEC diff covers, Firestone Air Spings w/leveling valve, On Board Air, Harpooned Tank, Aux Batt on Isolator, Espar Hydronic 5 Coolant Heater, 110 gal Custom Inbed Tank, Stainless Braided Brake Lines, LineX Bed Liner, Tekonsha Prodigy Brake Controller, B&W Turnover Gooseneck Ball, B&W Tow&Stow Hitch
eng211ine is offline
Old 03-08-2005, 09:04 PM   #8 (permalink)
Atlantaboy's Avatar
I am runnin' Fabtech 3.5" with 35's. Buy a leveling kit of Ebay for $299.
2001 F250 CC 4x4 (Blown motor @ 148k)
Garmon's Diesel Performance (bang bang bang)
01' F250 CC 7.3
6.5" ProComp on 35's Motometal 951's
03' headlights/corners, billet grill, Alpine/XM
16.5:1, Mahle's .0050 with harden forged
Comp 910's, 4130 pushrods, Mac/K&N
H11 studs, HT turbo, DP tuned,
Bean's singles/plentums, DI's fuel system
Mag-Hytec cover, Autometer gauges
Built trans with Red Altos/Mojo VB/PI triple disc.
My Rig
Atlantaboy is offline
Old 03-08-2005, 11:59 PM   #9 (permalink)
i have 315-75r-16 geolander at's on 16x10's. i have an add-a-leaf (1"-1 1/2") and i had to trim both the bumper trim and plastic fender liner. it doesn't rub, but i am either going to put 4" springs or a shackle relocate because it still has a fairly extreme rake with the airbags in back. i have heard that you can fit 35's on a stock truck, but i wouldn't suggest it.
justinharmony is offline
Old 03-09-2005, 01:27 PM   #10 (permalink)
Edge Mini-Spring pack with V code springs, 315 BFG AT's. Rub a little on plastic (and leaf springs at full lock) but not bad at all. Just heat up the innerwells with a heat gun and push them out a little. I am also running stock rims, don't have the cash for rims right now.
03' F-250 4x4 7.3L PSD, Reg. cab, 6 spd, Silver.
4" dp 5" straight thru, Autometer gauges, DI 4 pos. chip, Wicked Wheel, Edge Mini spring pack, 315-75x16 BFG AT's.
68' Bronco, uncut, 289,
3.5" lift, 31-10.5's, No ps or brakes.
70' Z-28, 350 4 spd.
68EB is offline
