Is there any specific additive that is better than the others? Lucas seems to put out a good product. How about Amsoil? I can't find Amsoil at any of the stores around my area though, so I am more apt to run Lucas. Is it worth $30 a gallon for that stuff? I am due an oil change soon and going on a 1500 mile trip to the east coast.
99 F-250 Super Duty
Moto Blue 4" turbo back
MAC cold air intake
Edge Evolution
Autometer A pilar gauges
285/75/16 Nitto Terra Graplers on 16x8 Eagle rims
If you ask me, I think just a plain diesel oil like Rotella 15W-40 is all you will ever need. Change it every 5K and keep on truckin. But it's your money if you want to use to synthetics.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Most of us don't run anything additives in our oils. The modern dino and synthetic fluids don't require them if changed properly. Now for fuel I use Powerservice on every fill up.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
If you really want to find out how your oil is doing, you should take an oil sample while your changing it and have it tested. Then test again later down the road when you're again changing the oil. This will give you a much better range of how long you can run your oil and how it's holding up.
2k F250 XLT CC 6sp PSD, 3.73 LS axle, Superchip, W-D Turbo Brake, Memphis speakers & 5ch amp, WD-Pyro & Boost gauges, Rechargable MagLite, quick disconnect jumper cables, CAT batteries, ARE tonneau,
"unaable" on the tailgate!! New door actuators!!
T-304 Stainless exhaust turbo back, Southbend clutch
NONE would be my answer too. You need to start with a good quality oil and leave it alone. Additive can throw off the oil's natural additive pack and cause it to underperform.
I recommend Rotella T 5-40 Synthetic
Or Shaffer's 9000
AMSOIL 15-40 does well too.
Larry [img]/ubbthreads/images/graemlins/cool.gif[/img]
02 F250XLT SD CC LB 4X4, Silver, SD Air Lifts, 4R100, Westin Sportsman grill/brushguard, Leer Shell, AIS Severe Duty w/added fender intake, Edge EVO running 80 HP, ISSPRO's w/cubby mount, Rancho 9000X's, Banks 3 1/2" downpipe, BTM, 3 1/2" exhaust front to rear with 5" stainless tip. Sonnex and Tricum's. Fumoto Valve. Royal Purple ATF. Tru-Cool 4590. Tekonisha Prodigy. SP Diesel SSEBTC Exhaust Brake. Like new 88 Vacationeer 11.4' or 2008 Cardinal 31SB, 1992 Bayliner Trophy and the itch to go, baited hooks and the need to fish, loaded guns and the need to hunt.
Wow, I guess it's unanimous. I guess I can save my money for something else. Thanks for all the inputs. I already run Rotella 15-40 and Powerservice fuel additive. I guess I am on the right track. Keep on truckin...
99 F-250 Super Duty
MAC cold air intake
Edge Evolution
You would notice a difference in smoothness and easier cold starts by switching to Rotelly 5-40 Synthetic, possibly longer change intervals too. That's the only thing I can think of for you to try.
The stuff you're using should hold it together for many many miles to come.
May there be a road. [img]/ubbthreads/images/graemlins/cool.gif[/img]
