What trans would a 2003 F350 w/7.3 have? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 01-30-2012, 05:36 PM Thread Starter
I am not a Ford authority. What auto trans would a 2003 F350 extended cab short box with a 7.3l diesel have? Were there various or just one type?
sqdqo is offline
post #2 of 3 (permalink) Old 01-30-2012, 06:14 PM
RT
RT's Avatar
4R100 - just the one type. This replaced the E40D that was found on pre-99 model PSDs. There are some upgrades in the 03 over the 99-01 years, but its the same model transmission.
RT is offline
post #3 of 3 (permalink) Old 01-30-2012, 06:37 PM
aekrogh's Avatar
Yep...What RT said.....
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
aekrogh is offline
