What's your mileage on your 7.3 ? and with what repairs??? - Page 22 - Diesel Forum - TheDieselStop.com
Old 10-31-2012, 10:47 AM   #316 (permalink)
ReefBlue's Avatar
369,639: new IPR.
1999.5 F250 creeping up on 400k.
Phantom problem? Check this: Phantom electrical problems?
Keep everyone (and yourself) updated:7.3 mileage and repair thread
ReefBlue is online now   Reply With Quote
Old 11-01-2012, 12:31 PM   #317 (permalink)
thecheesemannn's Avatar
231477 Another new injector....
This will make #10 over the last 15,000mi :banghead:
http://www.riffraffdiesel.com/mm5/me...731-FS-INJ-OEM
Gunna order it tonight from riffraff.... Unless youguys know a better place
Sent from my ADR6400L using AutoGuide.Com Free App
Personal Trucks:
Red 2003 F250 XLT Crew Cab 6.0L Powerstroke FX4 162,000miles,
BONE STOCK
Black 2003 Excursion Limited 6.0L Powerstroke 178,000miles.
Welded EGR, 4" Magnaflow Turbo Back, Warn Manual Locking Hubs, Blue Spring, aFe Air Filter
Check out my Fuelly Here
"The cheapest Powerstroke you buy, will be the most expensive Powerstroke you ever own"
Originally Posted by RT View Post
That's where theoretical dieselology comes in.
thecheesemannn is online now   Reply With Quote
Old 11-02-2012, 02:23 PM   #318 (permalink)
03' 7.3 stock:
Other than Scheduled maint. and tires:
U-joints/ Carrier bearing 140k
Head light 139K
Ball joints (all)- 122k
Brakes- (all 4) 98K
fuel bowl drain o-rings 95k
GPR- 75k
U-joints- 55k
gtxtrem is offline   Reply With Quote
Old 11-03-2012, 12:46 AM   #319 (permalink)
Riffraff Diesel: New Alliant Stock Injectors
Curious if your clutch depress/stalling issues have been resolved. If you have bad injector oil o-rings(like I did) or the HPOP is not up to snuff, it will stall. You need 500psi @ warm idle to maintain idle or re-start. If you have already addressed the CPS and ICP, this is a good place to start. I just installed 2 brand new Alliant injectors(215.00ea. from Seattle Injector out of all places)also installed all new o-rings on the remaining 6 flow tested injectors. My truck was stalling when I depressed the clutch and would not re-start warm without a squirt of starting fluid. It would only start dead cold. While I had it torn down, I installed all new Motorcraft glowplugs. Even with the miles she fires right off...cold or hot.
1995(10/94) F350 XLT CC 2WD DRW Flatbed, ZF 5-speed, LUK clutch, 4.10 Eaton TrueTrac, full Banks kit, New 4" Diamond Eye exhaust w/ muffler, BD exhaust brake, Firestone air bags, 100 gallon fuel capacity...800,180 miles and counting...
oldstroke is offline   Reply With Quote
Old 11-03-2012, 11:49 AM   #320 (permalink)
I changed my orings, and the clutch stalling stopped, but it still bogs down alittle, sometimes not every time.
I have all new glowplugs, and it starts really well, nomatter the temperature. I have addressed the CPS ICP IPR and BPS.
I bought a rebuild kit for my turbo, and found both my compressor wheel and my drive wheel are destroyed.
My truck still smokes like a freight train, and I have stopped driving it until I had time to change the #5 injector.
I can hear the injector knocking loudly, it started knocking suddenly after I got off the highway from doing 70mph for about an hour.
When I changed my injector orings, i found a solenoid that had rattled all the bolts out, and i heard a knock then too, but that was injector #1.
I also found a faulty compression ring that had cracked on injector #7, and a ripped oring on #5.
Sounds to me like your LPOP isnt filling your HPOP up, but Im not expert on these motors. I know old school VW Diesels, if you ever had a question about those, I would know an answer!
Users RT, KLHansen, and ReefBlue seem to be the most active and know alot about them. Give one of them a poke, see if they might know They were right about my orings... for the most part.
Personal Trucks:
BONE STOCK
Old 11-03-2012, 12:11 PM   #321 (permalink)
I am all good now...running strong. I thought my stalling might be the HPOP again since I racked up 260k on this one and was having the same symptoms when my original failed at 500k....glad it was just the o-rings. Hope you are done with the injectors for a while after this run...
I installed a '84 Jetta Turbo Diesel into my '81 VW Caddy...will never sell. Love the old Dashers too...you just never see 'em
Old 11-19-2012, 08:00 AM   #322 (permalink)
232,200 New Turbo
Sent from my Verizon 4G-LTE smart phone.
Personal Trucks:
BONE STOCK
Old 11-19-2012, 10:05 AM   #323 (permalink)
JakeSpoon's Avatar
1999.5 F250 168000 2nd owner, owned since 2004,
Things replaced:
HPOP O-rings,
waterpump,
Fuel bowl drain orings,
vaccum lines at front hubs,
seats, with 06 King Ranch seats
1999.5 F250 CC 4X4 PSD Lariat White over Gold BONE STOCK w/ 143950 miles
JakeSpoon is offline   Reply With Quote
Old 11-19-2012, 05:08 PM   #324 (permalink)
225 k -
water pump ( I think a second one is needed as of today.)
o rings on fuel pump
fuel pump
ITP intank conversion
+ normal brakes...
2000-7.3 2wd Excursion, 230+k, Hutch Mod., Rotella ELC @ 185k, Friends n Family Hauler...
Kids_Ride is offline   Reply With Quote
Old 11-22-2012, 02:01 PM   #325 (permalink)
300,500 mi., left hub, right front disc brake caliper, CPS, GPR, ICP sensor.
2003 F-250 Lariat 7.3 PSD Auto 4X4, Stock with Banks Ram Air intake, IAH Delete, Amsoil fluids, Amsoil bypass filter system, Dieselsite coolant filter, 285/75R-16 BFG A/Ts, Autometer quad pod (boost, pyro, fuel psi, trans temp, GPR light), Marinco mod, Hutch mod, Harpoon mod.
7MAGMIKE is offline   Reply With Quote
Old 12-06-2012, 02:11 PM   #326 (permalink)
Supporting Member
Rowan Redfire's Avatar
EOT, GPR, Injectors, CMP, GP's, Front Wheel hubs twice, left side axle, starter, alternator, IPR
Rowan Redfire is offline   Reply With Quote
Old 12-06-2012, 06:59 PM   #327 (permalink)
220k just did a ipr, cps and that is it.
2002 F-350 7.3 XLT, CC, SB, SRW, 4x4 with 220k on it.
Pretty much stock except, 203 themostat, DIY Air intake and DP tuner.
dieselstrokin is offline   Reply With Quote
Old 12-10-2012, 01:25 PM   #328 (permalink)
217,000 miles.
So far:
1.) entire a/c system
2.) all 4 brake calipers, pads, and rotors
3.) water pump
4.) fuel pump
5.) idler pulley
6.) alternator (oh-rye-lees every two years like clockwork)
7.) ICP
besides tires and filters, that is pretty much it. simple wear and tear items.
empiretc is offline   Reply With Quote
Old 12-12-2012, 06:20 PM   #329 (permalink)
Americandiesel9's Avatar
365000 miles 2 trans 3 clutches and typical other things averging 20 mpg
SOLD BUT NOT FORGOTTEN 97 f350 cc lb 4x4 5 speed 260000 mostly stock 6in lift 37" Goodyear mud tires, k&n air filter, straight exhaust with 3" dp
2005 chevy 3500 duramax crewcab dually 4x4 270000 (sold)
1999 dodge 2500 club cab 24vcummins 4x4 auto 569000(sold)
2000 f250 7.3 4x4 6 speed single cab pretty much stock no muffler no cat with Diablo tuner 350000
Americandiesel9 is offline   Reply With Quote
Old 12-14-2012, 01:03 AM   #330 (permalink)
Only 128K miles as I have now retired and do not commute now. Just my local daily use, and all biannual cross country trips - I like it better than the cars for frequent month long vacation travels. The HPOP was replaced the first week I owned it. No other serious problems. Have replaced batteries twice, tires twice, the brake pads once, front speakers, wipers, but essentially I have personally just done the routine maintenance and it keeps rolling fine. Still on original cps. Will have to replace or fix the driver leather seat covering as is starting to split in one place. Plan to keep truck as long as I need a truck to support my activities (which is as long as I keep breathing).
Lake Norman at Denver NC 1999 250 PSD (built Sept 98) Lariat XLE7 CC Auto LWB 4WD ESOF ABS 3.73LS X-Caliber cap BFG 285E AT/KOs Jayco-TT 31BHS
David C is offline   Reply With Quote
