1999.5 F250 168000 2nd owner, owned since 2004,
Things replaced:
HPOP O-rings,
waterpump,
Fuel bowl drain orings,
vaccum lines at front hubs,
seats, with 06 King Ranch seats
add to that... Glow Plug Relay
(Im beginning to think it has never worked since i have owned it)
1999.5 F250 CC 4X4 PSD Lariat White over Gold BONE STOCK w/ 143950 miles
Just the occasional u-joint and brake pad mainly. You can see the mods to each one of my trucks in my sig. 04 6.0 had a bad coast clutch solenoid at 145k in the tranny when I got it. Nothing major now. My 06 went in for an ebp sensor at 99k when I first got it. The mechanic left a nut sitting in the intake tube to the turbo. When he started it...well you know what happened....so new turbo under mechanics mistake....otherwise my 06 has been my best truck. My 08 is almost at 100k...the DPF took a dump at 70k, fixed that with a dpf delete.... She starts, runs, get's me there, and gets me back every day. My 99 7.3 I sold with 400k was my first truck I ever had. bought her with 200k, sold her with 400k. The only thing I did on it was glow plugs at 250k, and a water pump at 325k. There's my input. My Dodge I replaced with my 08 went through two motors at under 90k.
Ty (Dukey)
I may be the average teenage Farmer/Rancher, but everything done to my trucks I did myself!
2006 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~4 inch Diamond Eye Turbo Back Exhaust, IPR Research Coolant Filter, XDP EGR Delete, ARP Head Studs & Black Diamond HGs, SCT SF3 3015 tuner, Air Lift Load Lifter 5,000s w/ On Board Compressor System~~
Early 2004 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~ 03 motor, Straight pipe with stock pipe, DFUSER Coolant Filter, River City Diesel EGR Delete, Ranch Hand Grille Guard, Flatbed, Regular Cab...my Cow feeding/farm truck ~~~
2008 F-350 6.4 POWERSTROKE!!!~~Diamond Eye 4 Inch Turbo Back DPF DELETE Exhaust, SCT SF3 3015R Race Tuner, Sinister MFG EGR Delete, AFE High Flow Filter~~NOT A SINGLE REPAIR!!~~~~
JUST SOLD>>400,000 MILES!!!~~1999 F-350 7.3 Powerstroke 6 Speed with AFE Cold Air Intake, Hypertech Max Energy, Air-Lift Load Lifter 5,000s.............and of course a Dixie Horn~~~
Sorry guys...just realized that this is a 7.3 only threat. Let me quote the one sentence.
Quote: My 99 7.3 I sold with 400k was my first truck I ever had. bought her with 200k, sold her with 400k. The only thing I did on it was glow plugs at 250k, and a water pump at 325k. There's my input. My Dodge I replaced with my 08 went through two motors at under 90k.
Ty (Dukey)
Injectors sent to Full Force Diesel and flow tested
New Valve Cover gaskets & UVCHs
New Glow Plugs
New Garrett Turbo
New Up-Pipes & collector donut gaskets
Re-taped & butt-spliced new UVCH connectors into the engine wiring harness
New Oil cooler gaskets
New (Used) Oil dip stick & tube
New Water Pump
New Idler & Tensioner
New serpentine belt
New Coolant hoses
Oil Change - Rotella T 15-40
Coolant Change - Prestone
& one case of brake clean.... Yes, case
Sent from my Verizon 4G-LTE smart phone using Autoguide
Personal Trucks:
Red 2003 F250 XLT Crew Cab 6.0L Powerstroke FX4 162,000miles,
BONE STOCK
Black 2003 Excursion Limited 6.0L Powerstroke 178,000miles.
Welded EGR, 4" Magnaflow Turbo Back, Warn Manual Locking Hubs, Blue Spring, aFe Air Filter
I wonder if a 6, 6.4, or a 6.7 has even gotten close to that? If one did, it probably had way more problems
Than a 7.3 with similar mileage! I know, the 6.7 is alittle new to have that kind of mileage....
Personal Trucks:
BONE STOCK
I believe the 7.3 to be the pinnacle of both old and new school technology. The 7.3 is fully capable due to it's simplistic industrial design and relatively low cost of operation. I do not believe any of the other ford diesels are capable, at least without high cost.
1995(10/94) F350 XLT CC 2WD DRW Flatbed, ZF 5-speed, LUK clutch, 4.10 Eaton TrueTrac, full Banks kit, New 4" Diamond Eye exhaust w/ muffler, BD exhaust brake, Firestone air bags, 100 gallon fuel capacity...800,180 miles and counting...
163000 new engine wirring harness. Other than that 1 alternator, calipers and bads, rotor up front and back, belt, tires. Other than that nothing but maintance. Did do turbo but did not need to.
2000 F250 crew cab long box
Banks exhaust, bighead, trancommand, boost gauge trans temp, pyrometer(post turbo)
Dp-Tuner 60& 80econ 60& 80 tow
Strictly diesel overboost annihilator
jobeperformance intake
dieselsite 203 t stat, coolant filter, evans coolant
38r with bank-bighead installed, diesel site non ebv flange international up-pipes coated, diesel site engine boot-kit, non-ebv pedestal
strictly diesel regulated fuel return kit 65psi.
new fuel bowl
CMF+ intake
isspro ev2 pyrometer(pre turbo), fuel pressure, coolant temp, HPOP gauge Matt
New Glow Plugs
New Garrett Turbo
New Water Pump
New serpentine belt
New Coolant hoses
Add a new Coolant cap from the dealership, and an oil dipstick flange o-ring...
It suddenly developed an oil leak about 50miles after I changed all that stuff. I am worried about the possibility of dropping the flange in the pan, so I watched a few videos on youtube.... This seems to be the easiest way.
2001 7.3 6spd, basically stock except for AIS/tune/Exhaust. Born on April 2001.
63,850 to date. Still on the stock Firestones.
-Master/Slave assy for clutch (the trip home from the landfill was quite interesting)
-Water Pump/Radiator/hoses/Tstat
-Batteries (lasted 10 years)
-2 tag lights
-Shocks
-Front sway bar end links and sway bar bushings.
-CPS recall/Cruise Control Recall/seat belt recall
-Recharged the A/C at ~58,000
Love this truck! Now that it's 12 years old and still looks new, it gets a lot of comments.
Ive got a buddy that runs a big corn farm and hotshot company with his wife and a crew of ten. You 7.3 guys might like the 7.3 numbers! I quoted this off his facebook account. Note that all 6.0s have egr deletes and coolant filters except for the 05 which has head studs as well. The 6.4s and 6.7s have DPF and EGR deletes.
Quote: 2000 7.3 6speed regular cab (My Baby) with 840k, 2002 7.3 auto extended cab with 635k, 2003 6speed 7.3 crew cab with 702k, 1999 7.3 6speed crew cab (silver truck) with 1.2 million!!, 05 6.0 6speed with 459k, two 07 6.0 King Ranches, one with a 6 speed and 327k, and another with an Auto and 297k. 08 6.4 (Wifes) 6speed, 301k, 09 6.4 6speed with 350k, 09 6.4 6speed with 343k, and two 2012 6.7s with 75k and 72k and an 2011 6.7 with 121k. Just a few trucks with low miles.....
Ty (Dukey)
Curious if all the 7.3's are original to the trucks...would not surprise me, even at 1.2 million. Hard to say when mine will give up the ghost...drivin it till it grenades...
