7.3L Power Stroke Engine and DrivetrainDiscussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Re: Whats your mileage on your 7.3 ? and with what repairs???
2002 model with 17k and have not replaced anything yet. Keep it in 6th gear and under 2000 rpms and it gets around 20 mpg highway. Towing 12k it will get maybe 12-13 mpg.
215K on truck as of today.
BTS trans at 120K
Water Pump at 135K
IPR at 140K
Upgraded brakes see signature at 115K
Dinatrack conversion at 140K
My dad has a 95 with 650K miles with just the normal stuff replaced.
If you live in AZ come join us at Arizona Powerstroke Group... Click here... http://www.azpsg.com/index.php?referrerid=6
99.5 F-350 PSD Lariat, 4x4 Off Road, CC, SB, 3.73's, NVK2, BTS Trans and T/C, V-10 and Tru-Cool Max Trans Cooler, Evans NPG Coolant, BTS 100 HP Chip, ART Cryogenically Treated & Slotted Rotors with Performance Friction Brake Pads, Dynatrac Spin Free HD Front Hubs, TAG I & II, Ford AIS Intake, 4 inch Stainless Exhaust from turbo to 5 inch chrome tip. Auto Meter Ultra Cobalt Gauges. 35X12.5 BFG KO's on 16x10 Rims, Bilstein Shocks.
135K , solid 20mpg hwy , 15 around town and country.
Repairs:cps , gpr , tires , brakes.
About to go through brakes all around and basically rebuild front axle minus carrier bearings and gears , shocks , tie rods , bj's , unit bearings , hubs....tires(4)....etc ..about three grand worth of parts.
01 f250 7.3 diesel ,x-cab,xlt,144k,...stocker , powerslots and hawks , Rotella ELC , Dieselsite coolant filter
69 Bronco 302 np435 , not enough tires, lift ,time or money.
99 F250 2wd, 180,000, water pump, cam sensor(2x), brakes, and now need to change tie rods and so forth. Looking for info. About 19-20mpg. West Texas dirt here.
'01 F-250 4x4 with 68,000 miles. Gets a regular 17mpg empty.
Fuel drain o-rings replaced at about 60,000.
Driver's side front hub bearing replaced at 58,000.
Still has original Steeltex tires in good condition.
2001 F-250 Powerstroke, auto, super cab, short bed, 4x4. Bright red with silver on the bottom, lighted visor, chrome step bumpers and fender trim.
1988 F-150 302 V8 five speed, full bed, 2x4. Over 207,000 miles and runs like it just rolled off the assembly line.
684,377 miles. 1 set of injectors, 2 waterpumps, 3 alternators, 1 starter, 2 CPS, 1 IPR,2 sets glow plugs, 2GPR, 1 turbo, 1 Tranny, fixed for good with a BTS, u-joints, 2 sets diff bearings,1 fuel pump,2 sets of rotors, and pads front and rear, 4 sets of rancho shocks f&r, gotta love lifetime warranties, ICP sensor, and preperation H.
02 F350 Lariat CrewCab Toreador Red/ Silver DRW AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 738,210 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 XLT SC DI DRW 5Speed 314,000
04 Grand Marquis LS sure wish it had a BTS!
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
93,000 now, but at 73,000 the old owner had
all brakes done, new pads & rotors resurfaced.
End link assembly. connecting rod, drag link pitman arm?
multiple oil leaks---they mention EBP actuator and turbo stand
Inner cooler hoses leaking -replace hoses and clamps
Ignition key/lock cylinder
New hubs, bearings etc. Old owner had big wide tires that tweaked the front tend and wore out the bearings and did other damage. About $2,500
At 89,000 Starter. Drive gear fell off/dropped into pan-no damage!
At 89,500 Water pump. Original hoses and belt were still good but I replaced them.
Passenger seat heater is going out.
THREE CPS failures---new grey one in now.
All door lock motors replaced and now bad again.
Still have original batteries, Tranny works fine (knock on wood) exhaust system looks new but is original
Get 20-21 mpg at steady 57 to 60 with DP on 80 econo
2001 F-350 Lariat,CC,LB,SRW,4X4,Auto,7.3,2"lift,KYBs, 285x75x16 ProComp AT's, 3.73, steel oil x-over, aFe Stage II Pro 7, AirCond mod, Fumoto, DP 60,80,100. AIH Delete, hi-lite/fog-lite on mod.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MarvinVR</div><div class="ubbcode-body">
Mine didn't work when I bought my truck, tried this fix and sure enough both work now. And it's a free fix! [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
