Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-18-2008, 08:32 PM   #61 (permalink)
270,000, water pump, ball joints, one injector (need all ) tranny ,fuel line
99 f-250 7.3 edge programmer, afe intake , mbrp exhaust, custom red paint w/ black and blue air brush graphics, 315 BFG At on AR wheels, cervinis fiber.ram air hood,custom grill,carbon fiber tail lights 270,000 on original motor BTS auto tranny at 260,000 diprocal gauges
tile man is offline
Old 05-18-2008, 09:52 PM   #62 (permalink)
06Clone's Avatar
My Photos: (5)
2000 Ex 4x4 Police Special (USSS reject) 70k (born 9/99)
5K 20x9 inch wheels (8/170s rare as hens teeth back then)
10K CPS Warranty, carbon fiber interior package/steering wheel
40K put on OEM 20" GY tires as sooon as the came out in 05
50K Shocks, put in extra front leafs and updated front end to 2006
55K Turbo back ss big tube, air intake and tranny flush.
60K batteries and Alternator and put 2007 grill on it
65K Brake brain under pedal caused excellent rotors and pads to wear out in a week. Replaced all and two calipers.
70K Serviced Pumpkins & 15th oil/filter change (1st at 1K)
71K Serpentine belt and coolant flush
15/20 mpg new, 17/23 mpg @ current 72K (custom fuel blender)
06Clone is offline
Old 06-26-2008, 06:46 PM   #63 (permalink)
stangdiesel's Avatar
Send a message via AIM to stangdiesel
115K Shifter Pump on Tranny shifting hard (by pulling 13k fifther up highest mountain in Colorado in overdrive, just had hard shifts, quick fix, changed ATF and filter)
183K cracked water pump (pulling 40ft 29000LB load in late July)
194k speedometer sensor
215K cam senser
225K cam sensor
237K cam sensor
241K New front end ball joints
247K cam sensor (found out they were all being defective, came out with new design)
251K Tranny lock up and Slip (haven't fixed yet)
great truck that has been threw hell, been borrowed by everybody, been used by mostly oilfield work, pulling trailers, backhoes, fifthers, pipe trailers, and hauling ass like a bat out of hell to the rigs.
early 99 F350 4x4, 4 door, long bed, 7.3L Auto Tranny, XLT, straight exhaust (no cat or muffler), superchip tunner put on at 123K and amsoil bypass at 186K, now has 251K.
stangdiesel is offline
Old 06-26-2008, 10:22 PM   #64 (permalink)
57,000. 19MPG, front rotors, pedal assembly recall, CPS recall.....thatsssssssit.....thatsitttt.
02 F350 4x4 Super Cab, long bed TRUE BLUE all over, pre and tank mods,ZooDad mod (thanks Ben), NC Hornets CCV mmod, Fumoto, pillar gauges, Timbrens, PowerSlots, Arma Coat, acetoned badges...a boat haulin' dream. Smiles when it pulls the Bayliner, doesn't even know the drift boat is there.
rodmaker is offline
Old 06-26-2008, 10:50 PM   #65 (permalink)
161k Miles and average 17.6-19.1 mpg
3 heater cores
front brake rotors and pads
rear pads
waterpump on condition not failure
new batteries on 10/06
torque converter 10/04 because this is an early 99 and it was rattling
CPS recall by Ford
The most reliable vehicle I have ever owned, nothing has broken, uses no oil between changes, reasonable fuel mileage, 90K miles out of Firestone 275/65/16 tires.
Awesome vehicle...
fun2drive is offline
Old 06-26-2008, 11:47 PM   #66 (permalink)
Western Diesel Chip at 15K
Run Amsoil bypass with 5W-30 Series 3000 oil
New Shocks at 65K
new injectors at 80K (water in fuel I think... I was gone...)
maintenance in accordance with Ford guide
Current mileage, 99K
avg ~16 mpg over life of truck
Recently I have slowed down and get 21 mpg consistently at 65mph on the highway.
Switch
1999.5 Reg Cab F-250SD 7.3L
1999.5 F250 manual trans. Powerstroke w/chip and pillar guages.
Switch is offline
Old 06-27-2008, 03:34 PM   #67 (permalink)
140,000 Miles
Under Warranty (extended):
43K Left front hub/bearing assembly
56K Alternator
58K Right front hub/bearing assembly; Left hub seal
75K Clutch master/slave cylinders
89K HPOP leak (not sure if it was o-rings or something else), 2 of 4 ball joints (warranty only covered the 2)
After Warranty:
105K 2nd Alternator and batteries
117K Parking brake cable
119K Clutch - due to failed pilot bearing, not clutch but decided to do it all after pulling transmission
124K CPS
139K Cracked injector cup - While in there, decided to replaced glow plugs and UVC harness. Also required all new coolant/heater hoses, thermostat/gasket, and injector o-rings. HPOP leaking again - new hose adapters.
After 3 sets of front rotors, decided to try Powerslots. Hoping they last longer, but only have 2k on them so far.
All other routine maintenance (oil, filters, lube, brakes, coolant, other required fluid changes)
2002 F350 SRW 7.3PSD Crewcab LB 4x4, 6 speed manual, 3.73LS, BFG All-Terrain T/A KO 295/75 R16 Tires, DiPricol gauges, Superchips 1705, AIS intake, MagnaFlow 4" exhaust, 144K miles
RC_02F350 is offline
Old 06-27-2008, 07:20 PM   #68 (permalink)
224k towing heavy
tranny
3 alternators
radiator
water pump
overflow bottle
hpop
ebv seals
injectors
in the shop now for headgaskets
I shoud have put studs in the heads. I thought with my mild mods I would be ok. I guess towing heavy all the time like I do stretched the head bolts.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo.
skibarefoot is offline
Old 06-27-2008, 08:11 PM   #69 (permalink)
Truck in signature:
Power steering pump 2X under warranty
CPS
Ball Joints
Rear caliper
Water pump
A/C clutch mod
GPR
Overhead computer display
Power door locks
2000 F-350, PSD, CC, automatic, 3.73 L.S., Lariat, SRW, Shortbox, Edge Juice with Attitude, K&N, Line-X spray-in liner, Pace Edwards rolltop cover, oil bypass filteration system, Woodland Green and Harvest Gold
1999 32TKS Golden Falcon 'Presidential Series' 5th Wheel
GCVW: 19,200lbs
Niagara-on-the-Lake, Canada
Flyingdutchman is offline
Old 06-29-2008, 07:06 PM   #70 (permalink)
My Photos: (12)
2000 F550
six speed man, 2wd service truck. total weight is 15000 lbs. truck has 150XXX miles.
all new injectors and turbo at 136XXX miles. all stock cept a dfuser power mod(10K mod)
truck gets average 10-11.5 highway and around town.
bone stock the truck will hit 1200* egt
with the 10k mod on it CAN hit 1500egt. dont run that unless i have to move quick outa the way.
83 F250 6.9 rebuilt at 280,000. NP435, NP205, 4x4 conversion with hp60 front, 10.25 rear. 35inch Cepek Mud Countrys - RESTING IN PEICES (PARTED OUT)
99 Expedition 5.4 gasser
2000 F550 Lube Truck (Work Truck)
Certified PA Inspection Mechanic
i'd rather be 6.9'n than cummin or strokin'!
CowKiller is offline
Old 06-30-2008, 06:04 PM   #71 (permalink)
mfd911's Avatar
2000 F250 7.3
190k
cam sensor x2
rear axle seals x4
rear end rebuilt
water pump
water / fuel seperator drain cracked
shocks
added
firestone airbags
4'' mbrp turbo back pipe
aux 60 gallon tank
modified air intake
mfd911 is offline
Old 06-30-2008, 06:11 PM   #72 (permalink)
aklim's Avatar
98K.
Bad airbox, bad CCV, bad oil pump, bad trans, see sig for all the bad items.
Seriously, I have replaced all the fluids and trans and CPS and turbo pedestal. The rest of the parts just went "bad" on their own. In fact, when I get a little more cash, my injectors will coincidently go bad too and probably need AC single shots.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, Van Turbo and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 06-30-2008, 10:06 PM   #73 (permalink)
almost 200,000
since i've owned it just an alternator
JD4440 is offline
Old 07-01-2008, 09:30 PM   #74 (permalink)
Send a message via AIM to DozerDan82
105,000 bought it at 97
Since owning I have done Ball joints and bearings (only one side needed it, but I did both)
Just did front brakes (pads/rotors/calipers/lines)
And I had to put a tranny in it
Previous owner did CPS, new tires and had the one side ball joints done (susposedly)
It also needs a new bumper and fog lights, thanks to a suicidal deer two weeks ago
DozerDan82 is offline
Old 07-02-2008, 09:07 PM   #75 (permalink)
210,000 miles: manual trans because of bad pilot bearing wearing input shaft, did clutch while it was apart, ball joints ,one set of brakes, water pump, one CPS, two sets batteries, IDM Module, carries 11.5 ft camper with total weight around 12,000 lbs and just under 26,000 lbs combined with my enclosed trailer.
99 (8/98) F350 XLT CC LWB SRW 4X4 6spd ZF, Hide-a-ball Gooseneck Hitch, Line-X Bed Liner, Custom Running Boards & Camper Tiedowns, 11.5 ft Caribou by Fleetwood Camper, 24 ft Haulmark Elite 10,000 lb Car Hauler, Superchips Tuner, Toyo 305/70R16 Tires on Weld Typhoon's, Bushwacker Fender Flares
SuperdutyPSD is offline
