When doing a compression test on a 7.3 do you...
After reading some scary stories of Compression numbers, I realized I never tested mine. Had 122,000 mi when I got it, has 184,000 mi now. Runs fun but you never know.
Anyways, when testing on these motors, all GP's out, is it best to disconnect the main UVCH connector or each injector connector when doing the test. Is there anything else that needs to be DC'd for the test? Was stock compression 400psi or 450psi?
Truck:
Early 99 F-350 (99.5+Conversion)
Lariat Crew Cab Long Bed
05'-07' Front End/08' Tail Lights
184,000mi
Body:
8" Fabtech Lift
37" Toyo Open Country M/T
18" Rockstars
15" Cieling DVD
Engine:
99.5+ Conversion
AFE Stage 2 Intake
4" Turbo Back Exhaust
Ceramic Coated Bellowed Up-Pipes, Exhaust Manifolds, High Flow Turbo Outlet
ITP In-Tank/PRE-Pre-Pump Mod
HP Oil X-Over Line
AIH Delete
ISSPRO Boost, Pyrometer, Trans Temp A Pillar Gauges
CCV Mod
Truspeed
Other Rides:
67' Camaro RS/SS Dart Big M 540cu
