where to buy 4r100 transmission - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 08-01-2009, 12:48 PM Thread Starter
best prices? want something that will last with a 10" lift and 38" tires. also I am not sure what is broken but I think it is the input shaft that has snapped? the truck wouldnt move in gear and wouldnt stop rolling in park if it were on a hill.
2000 excursion 7.3 lifted 10" 38" toyo open countrys 4" exhaust K&N filter Palmer engineering software.
leerichmond is offline
post #2 of 17 (permalink) Old 08-01-2009, 01:51 PM
Mark Kovalsky's Avatar
My Photos: (6)
That's not the input shaft. The output shaft is what holds the truck in park, not the input.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 17 (permalink) Old 08-01-2009, 03:33 PM
SmokeyWren's Avatar
My Photos: (45)
I would say you have three viable choices.
A Ford rebuilt 4R100 tranny has a three-year Ford warranty. About $2,200 for the tranny, plus labor to R&R and fill it with MERCON V ATF.
Ford also now offers a HD 4R100 rebuilt tranny. It also has a three-year warranty, but Ford says it's meant to compete with the BTS and John Woods rebuilt trannies. That one is almost $3,000 plus R&R and ATF.
If you want the best, and darn the price, then you want a BTS. About $4,500 plus shipping both ways plus the R&R and ATF.
Brians Truck Shop
The Ford rebuilt trannies are available at any Ford dealer. Some dealers will price-match other dealers that advertise on the internet. So get the price from Wabash Ford near Indianapolis and see if your dealer will match it. For example, here's the normal 4R100 for your truck. Call them to see how much more the HD version is.
Your Premiere Source for Ford Truck Parts and Accessories
SmokeyWren is offline
post #4 of 17 (permalink) Old 08-01-2009, 03:46 PM
My Photos: (6)
Is the truck a 4x4? If so, look at the transfer case. It is more likely the problem.
Mark
Former
post #5 of 17 (permalink) Old 08-01-2009, 05:25 PM
Rogue1970's Avatar
Hmm, hope this post stays clean
Adding to Smokey's post. If you read up on any of the powerstroke forurms, your 4R100 options boil down into 2 options.
BTS - Brians Truck Shop
AND
John Wood Automotive
They both cost near the same, and should be the last transmission you will ever need for your truck.
If you plan on keeping your truck for a long time, then one of these two options is a great investment.
If you live in the Western United States, go with John Woods; If you live in the Eastern United States, go with BTS.
What ever your choice is, good luck.
Larry
- Purchased 8/3/08
DPTuner F5, AIH, BigAir, Gauges (Pyro, Trans, Boost), ScangaugeII, Zoodad, Harpooned, Hutched, Pre-Pump Filter, Boost Fooler, Turbo Master.
Tranny out at 95K - JW Towmaster installed, Ported Compressor Housing from DieselSite - waiting to be installed
Pulling 11k Attitude Eclipse full of sand toys. 2x
s, 2x2007 Kawasaki KFX90's.
Rogue1970 is offline
post #6 of 17 (permalink) Old 08-02-2009, 07:58 PM Thread Starter
ive taken the driveshafts off and when the tranny is in park i cant rotate the transfer case but when i had the truck in park before, it would just roll down the hill?? what do you think I broke if i stepped on it and something broke when it downshifted. it will shift through the gears but wont move the truck at all. transfer case shifts from 2wd to 4wd but still wont move the truck ...no grinding noises or anything
post #7 of 17 (permalink) Old 08-03-2009, 03:30 PM
TransBrain's Avatar
How many miles are on the rig? Any past work done on the trans or t-case? Do you 4X4 often? Sounds like an internal Transfer Case issue but could also be a trans issue. Do you get any engagement in 4X4 Low? When the truck would roll in park did you get any clunk/ratcheting noise that would coincide with speed? Have you checked the fluid in the t-case?
A couple things you could check would be removing the electric motor off the t-case (I'm assuming it has one) and try getting an engagement in the t-case by playing with the shift shaft. It may be futile but worth a try. Also drain the fluid, if any comes out for contaminents...I've seen a couple that have broken the shift forks, or the inserts have burned off when they've run low or out of oil.
If that all seems okay, then drop the pan on the trans and check the rooster comb nut for loosening up on the shift shaft or something broken in the shifter area of the trans. Have someone shift through the gears while you inspect with a bright light. This is usually quite rare but can be common if previously worked on
TransBrain is offline
post #8 of 17 (permalink) Old 08-03-2009, 07:55 PM
smokey, i know this has been beat to death but,,, everybody say bts or john wood, heres the thing suncoast is less than 60 miles from me ( ft walton fl) what is the general opinion on their stuff???
2000 X ,4x4, DIY TYMAR, WALKER BTM, HYPERTECH LEVEL3, AIRDOG 100,... 2001 f350 crewcab 7.3/auto 4x4 shortbed srw stock-for now
Dirtcheap is offline
post #9 of 17 (permalink) Old 08-03-2009, 09:45 PM
Pappy19's Avatar
My Photos: (6)
Don't let any of these dudes tell you that a Suncoast isn't one of THE best tranny's in the business. I ran one in my 2002 7.3 with 400hp and ran it for 130k when I sold it. That truck now has 280k and is running fine. You can't go wrong with a Suncoast and if the Suncoast shop is that close to you, then it's a no brainer. Get the Suncoast. You'll love it.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
Pappy19 is offline
post #10 of 17 (permalink) Old 08-04-2009, 08:30 AM
SmokeyWren's Avatar
My Photos: (45)
Originally Posted by Dirtcheap View Post
... suncoast is less than 60 miles from me ( ft walton fl) what is the general opinion on their stuff???
Suncoast makes good stuff. They are a mass-market outfit that sells quality stuff to their customers.
BTS and John Wood specialize in the hot-rod end of the business. They build bulletproof trannies that will live with high horsepower and the abuse of racing. Brian Thompson at BTS dares you to break one of his 4R100 trannies, regardless of how much power your engine produces. If you can break it, he'll fix it free.
I don't have high horsepower and I don't race, but I figured if a BTS can live behind one of David Lott's engines in his SnowWhite race truck, then it will live behind my mildly hot-rodded towing machine with only 300 horses. I've had my BTS for 5 years. It has been a reliable tranny with absolutely no problems. I don't know if I could say the same about a Suncoast.
Brian started his career hot-rodding diesel trucks. He could make them produce gobs of power, but he couldn't keep an automagic tranny from blowing up behind his race engines. And he couldn't find anyone to build him a bulletproof 4R100 tranny that would live behind his engines. Not even Suncoast. So he began tearing into his busted 4R100 trannies and replacing broken parts with better parts. Before long, by replacing almost every part inside the tranny with stronger parts, he could build a 4R100 that would live behind his hot-rod engines. Then other racers asked him to build them one of those bulletproof trannies. And that's how BTS became famous for building bulletproof 4R100 trannies.
If you watch Brian build a tranny, you'll notice that almost every part he removes from inside the tranny goes in the trash bin. Many of those parts look as good as new, but Brian replaces them with higher-quality, stronger, parts. And he also has a few "trade secrets" that he's learned to include in his trannies. He makes some holes bigger and some smaller to give the tranny the proper shifting "feel".
Brian is proud of his work, and he charges for it. That's why the typical 4R100 rebuild now costs around $4,500. But worth it.
post #11 of 17 (permalink) Old 08-04-2009, 11:21 AM
69mach1377's Avatar
What about ATS, which is closer to me?
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, otherwise mostly stock.
Jayco 26BHS elite, no RV parks...just the woods.
69mach1377 is offline
post #12 of 17 (permalink) Old 08-04-2009, 04:24 PM
Pappy19's Avatar
My Photos: (6)
You don't have to go to the ATS or to the Suncoast shop to get a new tranny. If you want an exchange for your tranny, just call and make arrangements. Just make sure that you use a local tranny shop that you can trust. Also don't buy just a new tranny without also getting a beffy torque converter. I would recommend the Suncoast tranny. In fact, Suncoast has a rebuild kit for $500 that vastly improves what you have, plus the cost of the TC at $2000 and you will save about $3,000 over a BTS or Woods, and still have a great tranny setup.
Pappy19 is offline
post #13 of 17 (permalink) Old 08-04-2009, 05:45 PM
aklim's Avatar
Unless he takes the lift and tires off, I don't see the warranty working. want something that will last with a 10" lift and 38" tires.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
post #14 of 17 (permalink) Old 08-04-2009, 05:49 PM
aklim's Avatar
But does that include the cost to rebuild and the warranty to the trans? Otherwise you are comparing apples to oranges. I just replaced a turbo in the wife's car. MB wanted $1800. I did it for $900. Well, I got it aftermarket and I did the labor. How are those comparable?
aklim is offline
post #15 of 17 (permalink) Old 08-04-2009, 06:27 PM
westvandude's Avatar
Either way you drive away with a new turbo. Option #2 leaves an extra $900 in your pocket. There are many guys here who are willing to work on their own given you purchase a couple of specialty tools here and there.
The BTS/JW rant gets a little old after a while. It's not the ONLY option.
If you have more cash than brains (or don't have the time) get a BTS/JW. If you got a brain (and not so much cash) do it yourself. That's pretty much the bottom line. There are lots of 4R100 rebuild kits/parts/upgrades available for DIY folks.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, cheap OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, Level8 striker 16x8.5 blk rims, etc.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. Aftermarket android 4.2 navi 7" touch head unit, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. GTI grille and projector fogs.
BioPro190 owner. 20,000L produced 2010-2015.
westvandude is offline
