Where to buy hubs? - Diesel Forum - TheDieselStop.com
Old 08-27-2009, 10:29 PM   #1 (permalink)
Where to buy hubs?
I'm neediing a hub assembly for my2001 pass. side(already pulled it and sealed bearing is bad). I've looked on ebay and they have some for the $130 range with a 1 yr warranty and them they have some Timekin brand for about $250. My local Oreilly Auto parts store said the cheaper ones are not even lasting a year. What are you guys experience? I only put about 10K a year on my truck. Just looking for some feedback before ordering one or picking one up. What brands are good?
thanks,
matthew
mkmiller1 is offline
Old 08-28-2009, 03:38 AM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
I'd recommend a name brand unit. Timken would be good, or BCA/National, which I believe is the OEM manufacturer for Ford. When it comes to bearing units, you get what you pay for. What good is a 1 yr warranty if it leaves you stranded on day 366?
Hard or no-start? Check Here
klhansen is offline
Old 08-28-2009, 11:05 AM   #3 (permalink)
Rock Auto has a pretty good price on wheel bearing assemblies.
Fin
2002 F250 SRW CC 4x4,diy intake, BTM muffler, gauges, zoo dad, DP Tuner60tow, 80econ, sonnax, AIH delete,ATS Housing,
finman is offline
Old 11-03-2009, 09:35 PM   #4 (permalink)
Swellmel's Avatar
Ford F-Series Pickup Front Hub Bearing Pair at 1AAuto.com.
2002 F350 Red PSD Auto SC/LB SRW 4x4 Tymar Intake 4"Dual Exhaust DI 6 position twisty knob BTS 4R100 Vegistroke V3
Swellmel is offline
Old 11-04-2009, 12:52 AM   #5 (permalink)
tomjon's Avatar
Here is where I bought mine ..... I think I got the big kit because it was my BJ's going out AND my mileage was getting to the typical hub replacement mileage AND my axle seals were leaking AND tires bald AND shocks AND brakes AND..... $4k later .....
Your Premiere Source for Ford Truck Parts and Accessories
01 f250 7.3 diesel ,x-cab,xlt,170k,...stocker , powerslots and hawks , Rotella ELC , Dieselsite coolant filter
69 Bronco 302 np435 , not enough tires, lift ,time or money.
tomjon is offline
Old 11-04-2009, 07:16 PM   #6 (permalink)
Make sure you buy a recognized name brand that is stated as Made in the USA. Otherwise you will wind up with that Made in China junk.
2000 Ford SD; PSD; Crew Cab; SB; Lariet; Air Lift suspension; K&N; Dynomax exhaust; ATS 88mm BB turbo; A-pillar three gage pod with Auto Meter pyro, boost and tranny temp gages; Prodigy brake controller; Rancho 9000 shocks; DP Tuner; 4R100 by Trans-Craft.
Willcamp2001 is offline
Old 11-05-2009, 03:25 AM   #7 (permalink)
NorthernAutoParts.com had the cheapest timkin hubs for my truck. I've probably spent $1000 there and never once had a problem with them or the parts.
'99 F-350 Supercab Lariat built 2/13/99
Camper Package, TS chip, DIY Tymar, 4" Magnaflow Exhaust, Isspro Gauges, 203* Thermostat, Coolant Filter, Upgraded Headlights/corner lamps, Custom center console with a sub, and quite a few other things.
Autometer Guages were stolen!
MANUAL HUBS AND TRANSFER CASE!
My Truck
Mrit is offline
