My turbo is shot. I bought a kit to rebuild it, but the compressor wheel AND the drive wheel are destroyed. Also, for the first few miles (7 or so) I can hear it dragging, even if the block heater was plugged in overnight.
So where did you buy yours? How much was it?
Sent from my Verizon 4G-LTE smart phone.
Personal Trucks:
Red 2003 F250 XLT Crew Cab 6.0L Powerstroke FX4 162,000miles,
BONE STOCK
Black 2003 Excursion Limited 6.0L Powerstroke 178,000miles.
4" Magnaflow Turbo Back, Warn Manual Locking Hubs
You can buy a factory balanced center cartridge from RiffRaff for 5-600. Or if are boosting over 25psi, you need to upgrade to something that can handel the higher stress level such as the 38R, H2E,.....
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes (Stock, 40 Tow WITH Whsiper tune, 80 Daily Driver, 100 Race, 140 Extreme, 140 smoke show)//Recon smoked cab lights/MM Hubs/Hood/HPx/FRx/GPR switch-Indicator
First vehicle (still driving): 96 F250 XLT 2x4- All factory (injectors & turbo) except straight exhaust. 570k miles
We can get rebuilt stockers or best option a GTP38r...
I did order that balanced center cartridge from riffraff yesterday, now I need to figure out how to fix the pipes leading to the turbo from the exhaust manifold.... They are leaking exhaust heavily at the top, and I can wiggle the Y-flange all over the place when the turbo is removed.
I do have new gaskets, but Im worried that it might be destroyed from letting it go so long, also those bolts look like they are going to break if I try to remove them. Maybe they will break free with alittle heat? :/
Personal Trucks:
BONE STOCK
Take the collector off of the pipes. More than likely, you can remove the bolts on the manifolds and the pipes will slide right out. After that, you can work on the collector on the bench. Soak the bolts with PB Blaster and they should come loose. A little heat may also help free it up.
You can sometimes save the factory set-up using Fel-Pro 8194 exhaust gaskets. You may find yourself redoing this later on, but can make it last for a year or two. The permanent fix is the Bellowed Up Pipes from International. RiffRaff Diesel has the best price usually. They come with all new parts from the manifolds up. It elminates the slip gaskets that fail so often.
Ken
Ok. Ill look into that, i already have the gaskets sitting on the shelf at home now, so when i change the turbo, I will use those, and order the better up pipes later.
I lost ANOTHER injector this morning, started knocking loudly.... Parked it immedietly so I dont damage the cylander. **sigh** now I wish I had just spent more money for a better truck when my old one puked out, rather than buying one from a backyard mechanic that uses cheap knock off injectors instead of real Alliant.
Personal Trucks:
BONE STOCK
