my truck started idleing rough when i first start it and seems to have a huge loss of power and its white smokeing really bad any ideas? read it could be injectors but what else? thanks
Bluish white smoke or White Steam. The first is the burning of OIL and the latter is coolant. Smoke will linger and Steam will disapate pretty fast, Unless its cold outside then steam sticks around a little. Is degas bottle empty ?
looks completly white... whats "degas bottle" would that cause my truck to lose power?
How long does the white smoke linger? Is it a puff or continous stream? Is it cold out?
2002 Quad Cab/ Short bed/ BTS Auto/ Ford AIS Intake/ BTS 6 Pos. chip/ DI boost relief valve/ 4in DP no muff all the way back/ Bob's IC boots/ Bob's A/C bypass valve/ Bob's coolant/tranny filter/ 3 Yellow Tops Optimas under the hood/ HID's/ Switched GP's/ And a Really big wish list!
whats your motor running at temp wise is it over heating spiking the coolent gauge? is the smoke steady or does it seem to clear out? does the power loss get worse as the motor runs or is it pretty constant?
2000 White F250 PowerStroke 4X4 Off Road
6 Inch super Lift
38 Inch Nitto Muds
BushWacker Pocket Flares
Dick Cepek DC1's
AEM Bruteforce Intake
AutoMeter C2 Boost, Trans Temp, EGT
MBRP 4 Inch Turbo Back Up to 5 To 7 Inch GrandRock Miters
Edge Juice With Attitude Moniter(Just For Gauges)
Custom Programing From Jody DP-Tuner F5
Stock,No Start, High Idle, 80 Econ, 120 Race, 140 Agressiv
OverBoost Annihilator, HPX Cross Over Line IC Pipe Foil Delete MOD
Running Garret GTP38R Ball Bearin non WasteGated 1.15 Exhaust Housing
Transmisson Done by The Local Guy New Housing, Transfercase and Drive Line Factory 3.73's "All Heavy Duty Billet Steel Internals"
Pro Torq Stage Three Billet Torq Converter
Rhino Liner, 10,000K HID's, Black Diamond Eye Head Lights, Recon Running Board LED's, Remote Start, Dual 7 Inch Touch Screen In Dash DVD, 12 Inch JL Audio Sub, Rockford Fosgate 600 Amp
Still Get Smoked By 6.0's
But Whos Truck Do The Women Always Want to Ride in?
9999, does the white smoke clear up when the engine warms up? White smoke on starting a cold engine usually relates to a glow plug problem. Is it hard to start?
jgr
2000 F350, Ecab, LWB, SRW, 4X2, ZF6, Full Gauges, Ebrake, Chipped 271rwhp/584tq, Scan gauge II, Coolantfilter, fumoto valve, oil by-pass filter, CCV mod with return to intake, dahl 100, 40 gal. aux tank, straight piped, PML cover, 203 stat and billet, AIS, Zoodad
hope its not a head gasket check your coolent level in the tank make sure its not burning it.
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
I would check you GPR to see if it is working correctly. Then check your GP, ohm them out...should see .6 ohms if they are good. When the truck is fully warm does the smoke go away?
what are you running for boost numbers are they the same they always been? with your setup you should be upwards around 30 psi if your having a gasket issue you wouldent be boosting. itd be nice to rule that one out but if you had a gasket issue the motor would be overheating as well. check your oil make sure theres nuthing that shouldent be in there as far as fuel or coolent.
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
my boost when on it 26psi from 0mph but from like 75mph punch its only 24psi no over heating... is there something i can look at to make sure no leaking somewhere???
Check your fuel pressure. My guess is that your fuel pump has given up. As long as the fuel system is tight, the injectors act as little tiny pumps and will draw fuel from the tank. But you won't have any power at all, as the injectors won't completely fill with fuel before asked to deliver it to the cylinders.
k well if your hitting those numbers not loosing coolent or over heating rule out the gasket issue. Hansens right up there saying white smoke means the motors starving for fuel (fuel issue) head gaskets not wrong ither but now youv ruled that one out. maby hansen could also shed some light on a simple way of checking to see if your injectors are firing correctly in the first place. like he said the pump could be going but with that check the little things to check the fuel bowl filter maby thats cloggin up or if its even filling with fuel,could be the screen in the tank clogging up cutting fuel delivery altho i didnt think those would cause the smoke just rough running. over my head i guess bring in the vets!!
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
