White Smoke at idle when cold / rough run at idle when warm - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 04-03-2008, 11:04 AM Thread Starter
bea_rolf@fidibusteam.com's Avatar
Send a message via Skype™ to bea_rolf@fidibusteam.com
Does anyone have experience with this?
Starting the engine (PSD 7.3L, year 1999 (05/98) in the morning a lot of white smoke comes out of the pipe. At higher rpm (more than idle) white smoke stops. Coming back to idle white smoke is again there until the engine gets really warm.
Waiting at stoplights (at idle) engine runs rough even if engine is warm! White smoke with warm engine has disappeared.
Many thanks in advance for any hint about what we could do.
bea_rolf@fidibusteam.com is offline
post #2 of 10 (permalink) Old 04-03-2008, 12:46 PM
Send a message via Yahoo to treytroxell
couple bad injectors? loose injectors? bad tunning? fill out your sig to tell us what truck you have and whats done to it.
1999.5 Ford F-250 7.3l 4x4 PSD With some extras
treytroxell is offline
post #3 of 10 (permalink) Old 04-03-2008, 12:52 PM Thread Starter
We have 209000 Miles on that engine. Changed the injectors with 180000 Miles. Changed Glowplugs and GPR recently. Fuel Filter changed. Regular service always done.
post #4 of 10 (permalink) Old 04-03-2008, 12:59 PM
what about glow plugs? that could be a problem for the morning starts. alright sounds like you might have a air leak in your fuel lines.
post #5 of 10 (permalink) Old 04-03-2008, 01:06 PM Thread Starter
Glow Plugs changed two days ago!
If it were airleak in fuel lines - wouldn't it always smoke?
We recently had also a vacuum on the tank - we cleaned the tap (with key) - and we had the impression there was less vacuum - need to monitor longer for that.
1999 (05/98) Ford F350 Super Duty crew cab, long, 4x4, 6 speed manual transmission, manual hubs, double rear wheels, 350000 miles, 150000 miles on new 7.3 L DIT engine, heavy duty usage in the Andes of South America (Argentina & Chile and shortly also in Brazil, Peru) = many gravel roads, a lot of dust and many very bumpy paved roads
post #6 of 10 (permalink) Old 04-03-2008, 01:21 PM
did you notice this right after you did something or just all the sudden truck running like crap?
post #7 of 10 (permalink) Old 04-03-2008, 01:30 PM Thread Starter
It smoked always little, but we have the impression that it becomes stronger, especially waiting (idling) at redlights. Two days ago, when GP were changed, the mechanics had to remove one cap of the injectors (only of one) because they had to remove the old glowplug. Could this have any influence?
post #8 of 10 (permalink) Old 04-03-2008, 02:42 PM
sounds more like injectors. does the truck ever feel like it is skipping on you
mdonnarumma is offline
post #9 of 10 (permalink) Old 04-04-2008, 02:29 PM Thread Starter
What do you mean with "skipping on you"?
post #10 of 10 (permalink) Old 04-04-2008, 07:28 PM
You can check the IPR o ring ,,,the small one on the end ,,may have a cut in it ,,,a cheap test , you can tell by looking at it ,,,
you can also ,unplug the ICP ,,see if the Idle smoothes out ....
You may need a new IPR altogether ...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
