Why does the BATTERY LIGHT come on? - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 04-20-2006, 12:58 PM Thread Starter
Banned
My Photos: (38)
Been working on the truck for several days changing the turbine housing. Go for a short test drive, in which the exhaust collector is leaking and blows smoke and soot all over the engine compartment, and hear a really wierd noise, like I heard with the DIY Intake when I put it on, like a huge turbo surge, then the battery light comes on.
I had my lard self laying on the truck a 100,000 times and another post sparked that it may be the wires on the top of the alternator shorting out, I checked them, but they look fine, not frayed, fried or anything...
Any ideas on why this would have come on... The truck starts and runs fine, ran the headlights for a long time, didn't run down batteries, but I know it would take a while...
Should I just have the alt tested? Sometimes I don't trust the guys and their machines at the parts store...
gregrob is offline
post #2 of 20 (permalink) Old 04-20-2006, 01:07 PM
Re: Why does the BATTERY LIGHT come on?
Might be coincidence that the battery light comes on now after you have been working on the engine but my guess is that you leaned on a terminal or something that is causing your problem. I would check all of the connections especially around where you were working to see if maybe you pulled a connection apart, strained some wire(s), etc.
John [img]/ubbthreads/images/graemlins/smile.gif[/img]
99.5 (5/99), F-350 SD XLT, auto, SC 4X4 Off Road, Manual 4WD, SWB, 3.73 LS, Trailer Pkg, Woodland Green, Duraliner, Lund Hood Flair, WeatherTech Deflectors, Autometer Gauges and Pod, Coolant Filter, Gold Coolant
Jmerritt is offline
post #3 of 20 (permalink) Old 04-20-2006, 03:01 PM
szalkayw's Avatar
My Photos: (13)
My battery light came on just a month ago while on the road and it turned out my alternator was bad (found this out after having it towed 200 miles back to the nearest repair shop in town).
2000 White/Tan F-350 7.3L Lariat 4x4 Crew Cab Long Bed * DOM 9/99 * Mobil 1 Turbo Diesel Truck 5w-40 * OilGuard Bypass filter * MBRP 4" Turbo-back exhaust * Brakesmart Controller * Kenwood DVD/Navigation player (DNX8120) and a Directed 12" overhead video/dvd player in rear * Pro Comp Ultra Lite Pyro, Boost and Trans gauges * Husky 16K FW hitch * Firestone air bags w/ dual air command setup * Tru-Cool 4739 MAX Trans Cooler * DieselSite Coolant Filter * DieselSite Transmission Filter
szalkayw is offline
post #4 of 20 (permalink) Old 04-20-2006, 04:16 PM Thread Starter
Banned
My Photos: (38)
Is the alt the only reason it would come on, or could it be something else?
gregrob is offline
post #5 of 20 (permalink) Old 04-20-2006, 04:42 PM
PSDfreak's Avatar
Could be the alternator is bad...could be the voltage regulator on the alternator, but yes it should be alternator/battery related...get a volt meter on your batteries with the truck off..should be about 12 volts or so...then turn the truck on and it should kick up to around 14 volts or so.....if it doesn't kit up....alternator....
-Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #6 of 20 (permalink) Old 04-20-2006, 04:44 PM
PSDfreak's Avatar
You could also (if you feel good about the shop) take it down somewhere and see if the system is charging and have the batteries load tested...
-Casey
PSDfreak is offline
post #7 of 20 (permalink) Old 04-20-2006, 05:04 PM Thread Starter
Banned
My Photos: (38)
I had the batts tested a while back and bought (one), they both failed the load test but I replaced the worst one, they said the other one would be good for a while longer.
Could it be the weak battery causing problems?
gregrob is offline
post #8 of 20 (permalink) Old 04-20-2006, 05:25 PM
It could be. I have always heard that you should replace both batts at the same time.
Wells
mtnbkr132 is offline
post #9 of 20 (permalink) Old 04-20-2006, 10:32 PM Thread Starter
Banned
My Photos: (38)
Well, back to square one, I had the alt checked today and they said it was putting out fine.
I'm not really thinkin this is the battery. Any more ideas out there peeps?
Thanks.
gregrob is offline
post #10 of 20 (permalink) Old 04-21-2006, 06:56 AM
-Casey
Great tip, Casey. This is a handy test to remember. Quick, and you can do it yourself at home. My grandfather taught me the same test... holds true every time I've tested it.
Greg, I'm curious.... could you do the above test and see what you find? Just for my own reference, if you wouldn't mind. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body |||
taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions,
no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
ryaneverk2 is offline
post #11 of 20 (permalink) Old 04-21-2006, 03:17 PM Thread Starter
Banned
My Photos: (38)
Yeah, I'll have to borrow my buddy's volt meter, the one I have is crap. That is essentially the test they did at the parts store, and the alt is charging fine.
He said I could take it off and let them test it on the bench, which would test the regulator, diode, etc
I guess it could be stuck and charging constantly. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
gregrob is offline
post #12 of 20 (permalink) Old 04-21-2006, 03:42 PM
PSDfreak's Avatar
With the alternator...I had the one on my gf's 4runner bench tested a while back because the car died on us going up I-5 and it checked out at 100% good...put it back on her car with new battery fired it up and in 20 minutes it was dead again....take the alternator back down there, passes bench test with flying colors again...bought a new alternator anyway, put the new one on, charged the batteries....car hasn't died since and that was at least 8 months ago.
-Casey
PSDfreak is offline
post #13 of 20 (permalink) Old 04-21-2006, 06:03 PM Thread Starter
Banned
My Photos: (38)
-Casey
That's how it goes... The batteries HAVE started dying now. I'm going to take it off and have it tested on the bench, if it passes, I may buy one anyway.
gregrob is offline
post #14 of 20 (permalink) Old 04-21-2006, 06:13 PM
Greg, before you take it off, take 1 minute with a voltmeter and do that little check... betcha find out the alternator isn't putting out like she should.
[img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/smirk.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img]
Ryan Arthur
post #15 of 20 (permalink) Old 04-21-2006, 06:23 PM Thread Starter
Banned
My Photos: (38)
In which case I would have to take it off anyway... I'll try to round up a voltmeter, but like I said the one I have is a piece of crap. lol
I would like to test it myself, then see what they say about it...
We'll see, I appreciate the help, hope I can get it figured out tonite, I'm supposed to run it on the Dyno tomorrow with the CO PSD Club guys and gals.... [img]/ubbthreads/images/graemlins/frown.gif[/img]
gregrob is offline
