why is my high pressure oil line bursting? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 02-16-2008, 12:56 AM Thread Starter
nick9823's Avatar
Send a message via MSN to nick9823
hi
ive got a 2000 f350 7.3 last weekend i bought a toy tarailer weighing 5500 pounds.when i hooked up to it my truck felt very week. no more than 2 miles up the road my right side high pressure oil line exploded leaving me stranded. after getting new hose that day i was off again only to make it maybee ten miles and the other side exploded. its now fixed and i havent tried towing since this hapened. i bought this truck just for towing and now have had zero luck please help. this truck has an edge with aditude,air intake with k&n,full exhaust and also lifted with 37 inch tires. i assume stock gears. this was all installed when i bought this truck. thanks alot
nick9823 is offline
post #2 of 14 (permalink) Old 02-16-2008, 01:30 AM
detroitfd's Avatar
Without having something to check pressure, I'd say it's probably just old lines. If I was you I''d tow the trailer around town close to home and have a spare on hand. Could just have been time to replace em. Usually when one of anything that has a mate goes, the other is close behind.
Originally Posted by nick9823 View Post
hi
Jerry
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
post #3 of 14 (permalink) Old 02-16-2008, 03:58 AM
I agree. Now that you have them both replaced, you are probably fine to tow again. I tow an 11,500 lb toy hauler, and it is no problem at all for my truck.
Replace that k&n intake right away. Those k&n intakes are no good for powerstrokes. I lot of people have learned that the hard way when their turbo and engine was destroyed and they had to replace everything. Get ais intake for $200 if you can afford it here.
Powerstrokeshop.com
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 170,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
DonWarkentin is offline
post #4 of 14 (permalink) Old 02-16-2008, 09:29 AM
Kanman's Avatar
I would check and make sure the ICP sensor didn't get unplugged. I would also get codes pulled ASAP to find out why this is happening.
Kanman is offline
post #5 of 14 (permalink) Old 02-16-2008, 11:22 PM Thread Starter
nick9823's Avatar
towing with 37s on a powerstroke
does anbody tow with 37 inch tires on a powerstroke with stock gears, if so hows it pull? with a trailer weight of 5500 or so i cant believe ive had problems. how likly is it that i need to re gear or get some smaller tires to tow comfortly? also when i was towing i had the edge in level 3 wich i read up on and they dont recomend this setting for towing wich i found out after the problems. thanks for all the help. Nick
nick9823 is offline
post #6 of 14 (permalink) Old 02-16-2008, 11:35 PM
Should not have caused these problems, I think you were the victim of coincedence.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #7 of 14 (permalink) Old 02-16-2008, 11:38 PM Thread Starter
nick9823's Avatar
what is coinsedence?
nick9823 is offline
post #8 of 14 (permalink) Old 02-16-2008, 11:43 PM
Sorry, I meant Coincidence
Coincidence - Wikipedia, the free encyclopedia
Two lines going out under similar circumstance, totally unrelated to each other, and making you think you have an underlying common problem that caused both malfunctions.
I think I pretty much covered your question.
Andy
arisley is offline
post #9 of 14 (permalink) Old 02-16-2008, 11:44 PM
F350_6's Avatar
Just random bad luck that's not really related.
I'd start off by not towing in a chip/tuner setting that is not recommended for towing. With 2 new lines off the HPOP you should be fine now.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 500,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
post #10 of 14 (permalink) Old 02-16-2008, 11:56 PM Thread Starter
nick9823's Avatar
thanks andy i see what you mean now all is appreciated. my truck is being checked for problems at local diesel shop after that ill be doing some local towing to see if its all fixed. just hopeing for good results ive been told to regear it but dont really want to i like to go 70 or 75 on my way to the dunes. thanks
nick9823 is offline
post #11 of 14 (permalink) Old 02-16-2008, 11:59 PM Thread Starter
nick9823's Avatar
thanks andy i see what you mean. ive been told to re gear this to help with towing are 37s to much tire for stck gears trailer shouldent weigh any more than 8000 fully loaded.
nick9823 is offline
post #12 of 14 (permalink) Old 02-17-2008, 12:00 AM Thread Starter
nick9823's Avatar
thanks andy. ive been told to regear, are 37s to much tire for towing a trailer weighing no more than 8000 fully loaded?
nick9823 is offline
post #13 of 14 (permalink) Old 02-17-2008, 12:02 AM Thread Starter
nick9823's Avatar
just wondering if 37s are to much tire for stock gears and a trailer weighing no more than 8000 fully loaded
nick9823 is offline
post #14 of 14 (permalink) Old 02-17-2008, 12:09 AM
I wouldn't until you try it out.
Andy
arisley is offline
