Will it fit? - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 04-29-2017, 07:39 AM Thread Starter
Whiskyb's Avatar
Will it fit?
I am still looking for a replacement engine for my 2001 F350. I have found one out of a 99 vin# 1FDAF57F5XEB01683 When I did a free online search of the vin it came back with this below. Is this the same as my current engine. I really am in need of something fast and am having a hard time finding something that just runs
Thanks for any help
Tech Specs
Vehicle Name Ford Super Duty F-550
Body Style Reg Cab
Body Code 141" WB
Drivetrain 4-Wheel Drive
Passenger Capacity 2, 3 2.0 min 3.0 max
Gross Axle Wt Rating - Front 6000 lbs 5600.0 min 6000.0 max
Gross Axle Wt Rating - Rear 13,500 lbs
Curb Weight - Front 3831 lbs 3831.0 min 4152.0 max
Curb Weight - Rear 2571 lbs 2545.0 min 2640.0 max
Gross Vehicle Weight Rating Cap 17,500 lbs
Gross Combined Wt Rating 26,000 lbs
Dead Weight Hitch - Max Trailer Wt. 5,000 lbs
Dead Weight Hitch - Max Tongue Wt. 500 lbs 500.0 min 500.0 max
Wt Distributing Hitch - Max Trailer Wt. 10,000 lbs
Wt Distributing Hitch - Max Tongue Wt. 1,000 lbs
Fifth Wheel Hitch - Max Trailer Wt. 18,300 lbs
Engine Order Code 99F
Engine Type Turbo Diesel V8
Displacement 7.3L/444
Fuel System DI
SAE Net Horsepower @ RPM 235 @ 2700
SAE Net Torque @ RPM 500 @ 1600
Trans Order Code 446, 44E 446.0 min 446.0 max
Trans Type 6, 4 4.0 min 6.0 max
Trans Description Cont. Manual w/OD, Automatic w/OD
Trans Description Cont. Again Electronic
First Gear Ratio (:1) 5.79, 2.71 2.71 min 5.79 max
Second Gear Ratio (:1) 3.31, 1.54 1.54 min 3.31 max
Third Gear Ratio (:1) 2.10, 1.00 1.0 min 2.1 max
Fourth Gear Ratio (:1) 1.31, 0.71 0.71 min 1.31 max
Fifth Gear Ratio (:1) 1.00 1.0 min 1.0 max
Sixth Gear Ratio (:1) 0.72 0.72 min 0.72 max
Reverse Ratio (:1) 5.23, 2.18 2.18 min 5.23 max
Clutch Size 13.0 in 13.0 min 13.0 max
Trans Power Take Off SAE 6-Bolt
Trans PTO Access LH
Transfer Case Model New Venture 271
Transfer Case Gear Ratio (:1), High 1.00 1.0 min 1.0 max
Transfer Case Gear Ratio (:1), Low 2.72 2.72 min 2.72 max
Cold Cranking Amps @ 0 F (Primary) 750 650.0 min 750.0 max
Cold Cranking Amps @ 0 F (2nd) 750 750.0 min 750.0 max
Maximum Alternator Capacity (amps) 260, 130 95.0 min 260.0 max
Maximum Alternator Watts 3900, 1950 1425.0 min 3900.0 max
Total Cooling System Capacity 30.6 qts 28.5 min 30.6 max
Frame Type Ladder
Suspension Type - Front Multi-Leaf
Suspension Type - Rear Multi-Leaf
Spring Capacity - Front 6000 lbs 5600.0 min 6000.0 max
Spring Capacity - Rear 13,500 lbs
Axle Type - Front Monobeam
Axle Type - Rear Full-Floating
Axle Capacity - Front 6000 lbs 6000.0 min 6000.0 max
Axle Capacity - Rear 13,500 lbs
Axle Ratio (:1) - Front 5.38, 4.88 4.88 min 5.38 max
Axle Ratio (:1) - Rear 5.38, 4.88 4.88 min 5.38 max
Shock Absorber Diameter - Front 35.1 mm 35.1 min 35.1 max
Shock Absorber Diameter - Rear 35.1 mm 35.1 min 35.1 max
Front Tire Order Code T9A, T91
Rear Tire Order Code T9A, T91
Spare Tire Order Code 512, 515 512.0 min 515.0 max
Front Tire Size 225/70R19.5F
Rear Tire Size 225/70R19.5F
Spare Tire Size 225/70R19.5F
Front Tire Capacity 3640 lbs 3640.0 min 3640.0 max
Rear Tire Capacity 3415 lbs 3415.0 min 3415.0 max
Spare Tire Capacity 3640 lbs 3640.0 min 3640.0 max
Revolutions/Mile @ 45 mph - Front 654, 653 Rev/Mile 653.0 min 654.0 max
Revolutions/Mile @ 45 mph - Rear 654, 653 Rev/Mile 653.0 min 654.0 max
Revolutions/Mile @ 45 mph - Spare 653, 654 Rev/Mile 653.0 min 654.0 max
Front Wheel Size 19.5 x 6.0 in
Rear Wheel Size 19.5 x 6.0 in
Spare Wheel Size 19.5 x 6.0 in
Front Wheel Material Steel
Rear Wheel Material Steel
Spare Wheel Material Steel
Steering Type Power
Steering Ratio (:1), On Center 20.3 20.3 min 20.3 max
Turning Diameter - Curb to Curb 52.04 ft 52.04 min 70.82 max
Turning Diameter - Wall to Wall 54.61 ft 54.61 min 73.42 max
Brake Type Power
Brake ABS System Four Wheel
Disc - Front (Yes or ) Yes
Disc - Rear (Yes or ) Yes
Front Brake Rotor Diam x Thickness 14.53 x 0.47 in
Rear Brake Rotor Diam x Thickness 15.55 x 0.47 in
Fuel Tank Capacity, Approx 19.0, 36.0 gal 19.0 min 36.0 max
Fuel Tank Location Midship, Aft-of-Axle
Front Head Room 41.3 in 41.3 min 41.3 max
Front Leg Room 40.7 in 40.7 min 40.7 max
Front Shoulder Room 68.0 in 68.0 min 68.0 max
Front Hip Room 67.4 in 67.4 min 67.4 max
Wheelbase 140.8 in 140.8 min 200.8 max
Length, Overall w/o rear bumper 225.7 in 225.7 min 285.7 max
Width, Max w/o mirrors 93.6 in 93.6 min 93.6 max
Height, Overall 81.7 in 80.7 min 81.7 max
Overhang, Front 37.4 in 37.4 min 37.4 max
Overhang, Rear w/o bumper 47.5 in 47.5 min 47.5 max
Front Bumper to Back of Cab 118.2 in 118.2 min 118.2 max
Cab to Axle 60.0 in 60.0 min 120.0 max
Cab to End of Frame 107.5 in 107.5 min 167.5 max
Ground to Top of Frame 24.1 in 24.1 min 24.1 max
Frame Width, Rear 34.2 in 34.2 min 34.2 max
Whiskyb
2001 F350 4X4 Super Duty PSD Dually
Almost 400k and still given her
DP Tuner
and guages, DIY air intake, BTM,
Dieselsites trans and coolant filters
Wicked wheel 2 (Gone) , Guzzles billet fpr
Whiskyb is offline
post #2 of 10 (permalink) Old 04-29-2017, 09:43 AM
RT
RT's Avatar
Yes it will fit. You may have to use your turbo pedestal, turbo, and pipes as it may have the smaller tubing of the early 99, but as a long block it will be 100% identical.
RT is offline
post #3 of 10 (permalink) Old 04-29-2017, 11:37 AM Thread Starter
Whiskyb's Avatar
Great, Thank you. I would have been using my original turbo as I just had it rebuilt.
Again, Thank you
Whiskyb
DP Tuner
Whiskyb is offline
post #4 of 10 (permalink) Old 04-29-2017, 12:39 PM
RT
RT's Avatar
The cool thing about this swap is the 99 is going to have forged rods for sure whereas your 01 has about a 50% chance of having powdered metal rods. Now you can crank up the power without worrying about snapping a rod.
RT is offline
post #5 of 10 (permalink) Old 05-15-2017, 09:53 AM
Relentless007's Avatar
how did the rebuild go? Did it have the early 99 turbo set up on it?
1997 F250 Heavy Duty 7.3 Powerstroke 4x4 Crew Cab, SRW, Automatic E40D
BTS Valve Body
Tru-Cool Trans Cooler
4" Turbo Back Diamond Eye Stainless Exhaust
Tymar Air Intake
TS Six Position Chip (stock,High Idle, +50, +75, +100, +120)
Tymar HPX line in hand but no installed yet
285/75r16 BFG All-Terrain KO2
ARE LSII Custom Color Tonneau bed cover
Color match Rhino spray in bed liner
Better To Be Tried By 12 Than Carried By 6
Relentless007 is offline
post #6 of 10 (permalink) Old 05-18-2017, 06:40 AM Thread Starter
Whiskyb's Avatar
Finally able to pick it up. Owner stated it only had 200k on it. One inspection I think it had a hard life or has more. Price was dropped and hopefully I have a good rebuild able core. Went out last night and picked up a 2000lb engine stand. Will mount it up this weekend and dive in.
Not looking for a killer drag motor just something a little extra power, any suggestions while I am at it
Whiskyb
DP Tuner
Whiskyb is offline
post #7 of 10 (permalink) Old 05-18-2017, 07:50 AM
Would be a good time to freshin' up glow plugs. And if you have the extra cash perhaps upgrade injectors.
Did "new" engine come with a complete top end? (heads, turbo, etc.)
BTS Valve Body
Tymar Air Intake
post #8 of 10 (permalink) Old 05-18-2017, 04:36 PM Thread Starter
Whiskyb's Avatar
Yes its complete. Talked to machine shop today to get an idea of machine work. Should I look for a full rebuild kit or re-use factory stuff
Whiskyb
DP Tuner
Whiskyb is offline
post #9 of 10 (permalink) Old 05-18-2017, 07:39 PM
klhansen's Avatar
My Photos: (180)
Even with 200k+ on it, you may still find crosshatch patterns in the cylinders.
Before tearing it down, I'd try and do a compression check. Even if you do wind up rebuilding it, chances are the cylinders may just need re-honing so new rings can seat. Unless they ran extremely hot, the pistons should be OK. Look for cracks in the combustion pocket in the top. They'll usually appear in a radial pattern matching the injector nozzles resulting from the injected fuel flamethrower effect. If there are significant cracks in the piston tops or damage at the ring grooves, the pistons should be replaced, but not before you decide if you're reboring the cylinders (again, likely not needed) so you can get the correct size.
), AIS,
regulated return,
klhansen is offline
post #10 of 10 (permalink) Old 05-20-2017, 07:17 AM Thread Starter
Whiskyb's Avatar
Thanks, hopefully apart tomorrow.
Whiskyb
DP Tuner
Whiskyb is offline
