Will taller tires give better mpg? - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 01-11-2008, 02:10 PM Thread Starter
My truck with 4.10 rear end is great for pulling my 11,400 lb toyhauler at 55mph. But when I'm not pulling a trailer and want to go 70mph, the rpms seem too high to get good mpg. If I got taller tires, would that give me better mpg at 70mph?
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: starter, batteries, cps, brakes, tires, alternator, ball joints, AC compressor, serpentine belt.
DonWarkentin is offline
post #2 of 20 (permalink) Old 01-11-2008, 02:32 PM
jetskier's Avatar
My Photos: (23)
Re: Will taller tires give better mpg?
It's doubtful, but within reason you could. How much? Who knows. If you run 255/85r16s on your DRW, you might pick up something over the 235/85rr16 stockers. The wider tires usually kill mileage due to the additional rolling resistance at the pavement.
2013 F350 Lariat Ultimate FX4 CC LB SRW
jetskier is offline
post #3 of 20 (permalink) Old 01-11-2008, 02:53 PM
glockman's Avatar
not going to make a whole lot of diff maybe .5 mpg or so your problem is trying to go 70 with 4.10 gears it just dont work like you said 4.10s are great for pullin but if you want miles your gonna have to change gears I run 3.73s in mine its kinda the best of both worlds you get good pullin power plus a lot lower rpms at 70 mph equals more mpgs
Y2K (built jan 2000) F-250 CREW CAB, 6SPD, 4x4, Lariat, 4" Turbo back exhaust, EBPV delete, CCV mod, SB con ofe, ISSPRO guages, FORD AIS, BWD Bellowed up pipes, Bully Dog power pup,50,75,90,120, 182,000 and still counting!
glockman is offline
post #4 of 20 (permalink) Old 01-11-2008, 03:15 PM
Your sig says, "completely stock"...easy flowing air-in and air-out will probably help more than different size tires.
2000 F350 7.3L CC/LB 4X4 XLT/6-speed/DP-Tuner/Bean's 1.0 with WW/4" turbo-back exhaust/AIS/Isspro EV's/285-75-16 Goodyear Wrangler PRO-GRADE/LS monotube shocks/Prodigy trailer brake controller/zoodad/leveling kit/All red - what other color would a firefighter have?
2002 F250 7.3L CC/LB 4X4 Lariat/4R100/DP-Tuner/Bean's Van Turbo with WW/Isspro EV's/4 inch lift/285-75-16 Goodyear Wrangler PRO-GRADE/LS monotube shocks/AIS/4" turbo-back exhaust/zoodad/ALL Black - wife's truck
Just because you can, doesn't mean you should!
FireHunter is offline
post #5 of 20 (permalink) Old 01-11-2008, 03:54 PM
jgarden's Avatar
i went from stock 265s to 285s and my mileage went down slightly. YMMV.
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
post #6 of 20 (permalink) Old 01-11-2008, 04:04 PM
Jack,
check yur PM's
01 F-250, CC, 4X4 manual, AIC,
+ box, ISS gauges, DP-Tuner SCT, B&W headache, Easley grill guard, Firestone air-bags, Bob Riley coolant filter, ZooDad+CCV(NChornet), AFE, Magnaflow 4" exhaust,
Tranny
USARVN 67-68
StoneMan is offline
post #7 of 20 (permalink) Old 01-11-2008, 04:23 PM Thread Starter
Firehunter,
How much mpg could I pick up if I installed the AIS and larger exhaust?
post #8 of 20 (permalink) Old 01-11-2008, 07:50 PM
My Photos: (19)
well I went from 285/75-16 to a 255/70-22.5. That's a 33" to a 36" tall tire. I gained about 2mpg across the board. I can still tow my backhoe and really heavy trailer no problem. I'd be willing to say that a taller tire will help you. The question is, how tall are you willing to go?
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
post #9 of 20 (permalink) Old 01-11-2008, 08:00 PM
SmokeyWren's Avatar
My Photos: (45)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dstuartw</div><div class="ubbcode-body"> If I got taller tires, would that give me better mpg at 70mph? </div></div>
Theoretically, yes. In the real world, no.
If you could go taller without going wider, then that should give the truck longer legs without more tire contact patch. But more contact patch causes significantly worse MPG, and nobody makes a taller easily-available truck tire that's not wider.
One possibility is "military tires" in a tall skinny size such as 9.00R16. They are 36" diameter and only a scooch wider than LT235/85R16. With 577 revs/mile, they would change your effective rear axle ratio to 3.61. Probably too long of legs for your current max load of around 20k to 21k GCW. But I've never seen any of those rated for higher than 62 MPH. So going 70 MPH on those tires is a no no. http://militarytires.com/
As others mentioned, re-gearing to a 3.73 rear axle ratio would give you 10 percent longer legs. And the truck will easily tow up to 20,000 pounds GCW. But if you're one of those that overloads your tow vehicle by grossing more than 20k on the road, then you probably don't want the 3.73 rear end.
Another possible fix is an auxiliary tranny - Gear Vendors or U.S.Gear makes them. A 20 percent "double overdrive" is common, and your truck would "feel like" it had a 3.28 rear end when in double overdrive. Long legs indeed. But not enough power to pull a hair out of a gnat's hiney, so don't even think about towing more than a rowboat in double OD.
Plus, the auxiliary trannies cost over $3,000. You can buy a lot of diesel for $3,000. They're most useful for folks with really short legs, such as F-550 towing machines with 4.88 rear end. With a GV for unloaded cruising, they would "feel like" they had a 3.90 rear end when in double OD. Not much better than your 4.10, but a heck of a lot better than their 4.88. [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
SmokeyWren is offline
post #10 of 20 (permalink) Old 01-11-2008, 08:10 PM
You've only owned your truck for 6,000 miles. You might want to go and change out all your old fluids and replace them with synthetic. Check your air filter and brakes. A good wash and wax will help with wind resistance. And make sure your air pressures are up to normal. Get some guages. Get a chip from Jody at DP-Tuner and maybe a couple postions for stock, towing, and fuel economy. As long as you keep your foot out of the pedal the custom tuning of the chip will net you more MPG than trying to cheat your way with an empty load on larger tires than hurting the mileage while towing.
Danny Om
01 SC PSD Dually (build date 08-00 w/ PMRs), 8" Edge, dual F&R Doetsch aluminum shocks w/ resevoirs, 37" SSR on all 6 tires, 2" (hub & wheel centric) wheel adapters by Fearless Fred Goeske, Fabtech racing track bars.
APC Projectors (HID 10k), clear corners, clear cab lights, clear dually side markers, Amp-Research retractable side-steps, power rear-slider, Snug-Top canopy, billet grill, and chrome truck nutz!
Fully built motor w/ B-codes, GT42R, and Terminator w/ remote IPR HPOS.
Auto Enginuity Pro-Bundle equipped if you need assistance locally.
duallyduty is offline
post #11 of 20 (permalink) Old 01-11-2008, 11:57 PM
I went from stock to 355-85 r-16 and got better mileage. Not much but better. A substantial drop in rpms going above 70.
2001 F-350 CC ZF-6 DRW 4x4 4.10, 7.5 ton modified J&I flatbed dump, Rifraff frx, Garret BB, Non EBPV pedistal, IH bellowed pipes, DP tuner F-6 chip, SB dual disk, Midwest short shifter, Ranch Hand legend front end, Ford AIS, AGR super pump, AGR gearbox, Mile Marker 10k hydraulic, 4 inch turbo back, Riffraff boots, Pacbrake, 2WD Low mod, ISSPRO boost, pyro, trans gauges, DIY gooseneck/bumper hitches, Prodigy brake controller, 4 leaf overload springs, Viair compressor with horn, Dieselsite 203* t-stat, ESOF lines, DIY Oil HX mod, 08 mirrors, 245/70r19.5 tires. All led lights.
1997 F-250 EC SB ZF-5, 4x4, d60 front swap, E-fuel, Full Force stage 1s, DP F-5 chip, Swamps IDM, 6637 filter, 3in downpipe to 4 in exhaust muffler delete. Leveling kit on 18 weld wheels and 35's, all led lights, Reunel Rear bumper, Flatbed w/stackrack
AE in Northern California
fire57dan is offline
post #12 of 20 (permalink) Old 01-12-2008, 12:50 AM
When I went to taller tires I lost milage. Alot of the time when poeple install taller tires on their vehicle they dont relize they are altering the speedometer reading. The speedo will actually read slower so when you hand calculate your milage you need to know how far off it is because your odometer will show less miles, making it seem worse than it is.
2001 F-350 Dually CC 4x4 long bed; Autometer gauges; 2 inch leveling kit; Ford AIS intake; DP tuner stock, 40 heavy tow, 60 tow, 80 econo; 4" exhaust; ATS ported turbo housing.
2002 f-250, cc, long bed, 4x4, 4 inch lift, 295/75-16 BFG all terrains, dp-tuner stock, 40 tow, 80 econo, 6.0 transcooler, 6.0 intercooler, aih delete, wicked wheel, autometer gauges, tymar intake, 4inch exhaust, mag-hytec diff cover, power slot rotors/hawk lts pads, built trans. **SOLD**
ragenford1 is offline
post #13 of 20 (permalink) Old 01-12-2008, 11:35 AM
My Photos: (19)
That's the beauty of my TrueSpeed and a GPS unit in the truck at all times. My mileage is almost dead on. And if I notice it starting to drift, I reach down and grab the screwdriver and adjust it back again. And SmokeyWren is right. If you can find a tire that is narrower it will help. I lost about 4" of overall contact width with what I did. I'm sure it helped.
BTBBT is offline
post #14 of 20 (permalink) Old 01-14-2008, 04:34 PM Thread Starter
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PwrStrokinDually</div><div class="ubbcode-body">You've only owned your truck for 6,000 miles. You might want to go and change out all your old fluids and replace them with synthetic. Check your air filter and brakes. A good wash and wax will help with wind resistance. And make sure your air pressures are up to normal. Get some guages. Get a chip from Jody at DP-Tuner and maybe a couple postions for stock, towing, and fuel economy. As long as you keep your foot out of the pedal the custom tuning of the chip will net you more MPG than trying to cheat your way with an empty load on larger tires than hurting the mileage while towing. </div></div>
Thank you everyone for all of the great information about MPG related to tire size. I'm still undecided about what to do with the tire size, since some people found an improvement in mileage with increased tire size, and some people thought that it wouldn't help or would be worse.
I guess I will keep the tires as they are for now.
Thanks, PwrStrokinDually, for the suggestion that synthetics would help with MPG. That is certainly an easy thing to do; so I will start there and see how much that helps. Which synthetics would give me the best MPG?
post #15 of 20 (permalink) Old 01-14-2008, 04:56 PM
Amsoil, Redline, and Royal Purple are a few popular synthetics. There are others, but some prefer the mentioned over others.
Danny Om
