WIX coolant test strips? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 06-29-2007, 04:08 PM Thread Starter
CG_Lock_Racer's Avatar
I just got some WIX coolant test strips. Are they equivalent to the Fleetgard strips? I haven't used them yet so if not i can still return them.
Thanks!
Phil -
Early '99 F250 Super Cab SWB 7.3L 4x2
AIS Intake
Zoodad
Straight pipe exhaust
Bilsteins
Edge New Evolution
T/C Lock Switch
Royal Purple in engine, trans., and diff.
Other Cars: '90 CG-Lock /
, '06 Mazda3i,
Trailer: 2008 MTI 26' + 5' V-Nose
CG_Lock_Racer is offline
post #2 of 7 (permalink) Old 07-02-2007, 02:42 PM
SmokeyWren's Avatar
My Photos: (45)
Re: WIX coolant test strips?
Fleetguard makes two kinds of SCA.
DCA2 was used by GM, Caterpillar, Detroit Diesel and some other diesel marketers. It contains nitrite but not molybdate.
DCA4 was used by Ford, International, Cummins, and a few others. It contains both nitrite and molybdate.
Fleetguard 3-way test strips are made to test coolant treated with DCA4 SCA.
Wix coolant test strips are closer to DCA2 test strips. They call them 3-way, but they don't test for molybdate. They test for nitrite, glycol, and PH.
Here is a blurb from Wix about their test strips:
Wix COOLANT TEST KITS
Cooling systems with which have been treated with Dry Chemical Additives (DCA) type Supplemental Coolant Additives (SCA) may be checked with these kits. These kits are not suitable for use with extended service, extended life, long life or fully formulated anti-freezes, chemistries or anti-freeze colors other than traditional green.
If I were still using green coolant with SCA, would I use the Wix test strips? Only if I couldn't find the Fleetguard 3-way test strips that include molybdate in their test.
SmokeyWren is offline
post #3 of 7 (permalink) Old 07-03-2007, 01:25 AM
Banned
Phil, there are industry conversion standards for testing DCA-4 SCA's with the 2-way (WIX) test strips. This is because Nitrite, not Molybdate, is the primary cavitation inhibitor in any SCA, whether it is DCA-2 or DCA-4.
800 ppm Nitrite (as read on the Wix test strip) = 1 DCA-4 Unit
You want a minimum of 1200 ppm Nitrite, or 1.5 Units, for adequate protection. No more than double that.
By SmokeyWren:
Both DCA-2 and DCA-4 meet the specification for his PSD, and both are approved for use by International, who made the engine.
By SmokeyWren:
DCA-4 wasn't introduced until 1984. Prior to that, all diesels requiring SCA used DCA-2 or a similar nitrite-based SCA. Today, DCA-2 still remains the most popular and widely used SCA in the world. DCA-2 does not rely on Molybdate "synergy" for cavitation protection. It simply relies on the primary cavitation inhibitor, Nitrite, using a simple, proven, easy to find, easy to use technology.
DCA-4 was later developed by Fleetguard, which was (is) owned by Cummins. Cummins (Fleetguard) developed DCA-4 so they could specify and sell it for their own engines...capitalize, so to speak. At that time, Ford held interest in Cummins, and International was in business ventures with Ford. So...what's good for the goose is good for the gander...Cummins capitalized on DCA-4 by specifying it for their own engines and taking advantage of their relations with Ford and IH, who also decided to recommend it. DCA-4 relies on "synergy" between the Nitrite and Molybdate. But the theory is questionable since you can't optimize the Molybdate/Nitrite scale, or add just Molybdate alone. Plus the theory allows you to have adequate protection with zero Molybdate present, as long as there is enough Nitrite...exactly what the DCA-2 does.
By SmokeyWren:
Uhh...the 3-way test strips will test any SCA, whether it contains Nitrite only, or Nitrite and Molybdate. When testing DCA-2 with a 3-way strip, simply ignore the Molybdate scale.
By SmokeyWren:
Freeze-point, Nitrite level, and pH are the most important things to test for. pH will tell you the over-all condition of the glycol, especially if you compare it to the pH of the coolant when it was new. Nitrite is the primary cavitation inhibitor, Molybdate need not apply. The importance of freeze-point speaks for itself, especially in cold climates.
Gooch is offline
post #4 of 7 (permalink) Old 07-03-2007, 09:36 AM Thread Starter
Thanks for the replies!
I ended up using the WIX strips. It mentions DCA-IV on the bottle of them and that is what the SCA I got from Ford contains. My coolant tested low for the nitrates, so I added 1 pt. of the SCA drove the truck normally for a day and retested after it was cool. Then everything tested normal.
Thanks again!
Phil -
AIS Intake
Zoodad
Bilsteins
Edge New Evolution
T/C Lock Switch
, '06 Mazda3i,
post #5 of 7 (permalink) Old 07-03-2007, 10:01 AM
NCHornet's Avatar
Quote from Smokey:
What has changed since you switched to the Gold? You still should check your SCA's, and if you would dip a strip you would find that your gold is at 800 ppm or less straight out of the bottle, far below the 1200ppm minimum level, and less than half of the ideal 1800ppm you would like to see.
To the OP, 1800 is the ideal level to keep your SCA's at. Glad you got the right stuff, now when your coolant needs changing go to the Fleetrite ELC and throw those strips away.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #6 of 7 (permalink) Old 07-03-2007, 04:13 PM
SmokeyWren's Avatar
My Photos: (45)
Apparently you (and some others) had some problems with Chemistry 101.
The test strips are for measuring DCA (dry chemical additive) in green antifreeze. G-05 "gold" coolant doesn't include DCA. Yes, it includes nitrite, but it's in a different chemical compound than DCA, and the test strips won't properly measure the effectiveness of gold or any other long-life coolant.
Wix says their test strips should not be used to test anything other than green antifreeze with DCA. They won't work right with G-05 or any ELC coolant. I suspect if you read deep enough, Fleetguard will tell you the same thing.
Have you asked Zerex if their G-05 can be tested with ordinary DCA test strips? They will tell you no, because G-05 doesn't include DCA.
Ford says the gold coolant is good for 100,000 miles with no maintenance in Ford diesel engines. Zerex says 150,000 miles. Dig deeper into the chemistry of the G-05 coolant and you'll probably learn why.
post #7 of 7 (permalink) Old 07-03-2007, 05:18 PM
Banned
Smokey, your continual "Golden" coolant drivel is ridiculous. There are some things you are better off learning from, rather than preaching about. Since you have absolutely no actual experience, training, or education concerning coolants (Google doesn't count), I might suggest you hold your tongue and take your Ford blinders off. That is unless you are capable of engaging in a coolant chemistry 101 discussion yourself? That would be ok with me.
Look Smokey, the only cavitation additives that a test strip will test for are either Nitrite (2-way strip) or Nitrite/Molybdate (3-way strip). There is nothing special there concerning the G-05 or any DCA.
The G-05 contains the Nitrite cavitation additive. No Molybdate. In fact it is called a "fully-formulated" coolant because the Nitrite is added to the G-05 as SCA.
Any test strip that indicates "Nitrite", either a 2-way or 3-way strip, will tell you how much Nitrite is in the G-05.
To drive this point home, some G-05 users like John Deere, print right on their bottle of G-05 that the coolant should be tested at least annually, and SCA added as necessary. Ford also requires the addition of SCA to some of its F-series vehicles using the Gold. This is because the SCA additive (Nitrite) will deplete over time due to the inorganics present, and the G-05 isn't up to the task otherwise.
As for Ford and Zerex's change interval....Zerex supplies the Ford G-05. But Zerex doesn't manufacture the G-05. They get it from BASF. And BASF says the G-05 is good for 3-years/30K miles. In fact according to BASF, it has a shelf life of only 3-years.
Believe what you want from Ford...they also said we didn't have to test our conventional "green" coolant SCA either. But hey, you can run the Gold 100K or 150K if you want. I wouldn't. Not when there are much more robust coolants available made specifically for diesels that can go 750K miles with zero maintenance.
Gooch is offline
