wont start without ether - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 04-26-2011, 04:13 PM Thread Starter
im looking at a used psd and the guys says it wont start without ether.. what could be wrong with it that it wouldnt start without it ??? thanks 7.3 obviously
2000 X ,4x4, DIY TYMAR, WALKER BTM, HYPERTECH LEVEL3, AIRDOG 100,... 2001 f350 crewcab 7.3/auto 4x4 shortbed srw stock-for now
Dirtcheap is offline
post #2 of 7 (permalink) Old 04-26-2011, 04:53 PM
tbpower's Avatar
I would run away from that one. Ether is not good to use along with glow plugs. Can you say ka-boom.
2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) . 6637 riffraff filter kit . AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler. Riffraff FRX
tbpower is offline
post #3 of 7 (permalink) Old 04-26-2011, 05:18 PM
Many things could have started the hard to start scenario, glow plugs or the GPR most likely. For me it wouldn't matter at this point unless they were giving me such a good deal that I could drop an engine in there for the bargain I was getting. Their statement indicates that not just once but as a pattern to get the unit started they have used starting fluid. That can damage many things internally on a PSD that are not easily evident right away, like a cracked piston, bent valves or cracked rod. I would walk away from it or demand a super deal because of it. Who knows maybe it is OK but why make their unknown condition yours. 106
2002 F250 7.3L PSD, bought new now at 202K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
post #4 of 7 (permalink) Old 04-26-2011, 07:40 PM
rammertide07's Avatar
Send a message via MSN to rammertide07
I've only been able to NOT be able to get a high mileage 7.3 without ether one time and it was a blown head gaskets. Oil pressure can also cause a no start...assuming all fuses are good.
Sent from my ADR6300 using AutoGuide App
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #5 of 7 (permalink) Old 04-28-2011, 10:47 AM Thread Starter
hes askin $3900 or so for a ext. cab 4x4. i figure worst case it needs a new motor..
post #6 of 7 (permalink) Old 04-28-2011, 02:26 PM
jstrauss's Avatar
If it starts on ether and then runs fine thereafter, I would reckon that is a glow plug issue. You might have him demostrate his ether-starting method, if he just shoots a quick little shot in and then goes and starts it up, that is not anything to worry about IMO. If he tells you hit the starter and then he sprays and sprays until it finally kicks off, yeah I would stay away from that motor.
Ether is not an automatic diesel-killer IF you know how and, more importantly, how not to use it.
1991 F150 SC 4x4 7.5L/ZF5
1991 SAE Bronco 7.3L IDI NA/ZF5
1974 F350 Tow Truck 360/T18
2005 Escape 2.3L/CD4E
jstrauss is offline
post #7 of 7 (permalink) Old 04-28-2011, 02:30 PM
x2 My 96 F250 is cold weather ether dependant
