Wrench Size for Removing Fan - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 01-22-2006, 10:34 PM Thread Starter
Does anyone know the wrench size for removing the fan to get to the water pump pullley? I know it's over 1", is it reverse thread? Thanks
[b]'02 F-350 XLT PSD DRW CC Auto 4x4 4.10LS AIC Mag-Hytec Rear Cover & Trans Pan Ford AIS Severe Duty Filter Kit Di-Pricol Gauges Walker BTM Rhino Liner 525 Torque All Black
<font color="red">'97 Harley-Davidson FLSTS White/Red
Diesel_Dog is offline
post #2 of 13 (permalink) Old 01-22-2006, 10:41 PM
fordmastertech's Avatar
Re: Wrench Size for Removing Fan
It's a 17/8 wrench and it's the normal right hand thread.
FMT
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #3 of 13 (permalink) Old 01-22-2006, 10:53 PM Thread Starter
Thanks FordMastertech! Also, is the best way to get the belt tensioner to move by using a box end wrench?
post #4 of 13 (permalink) Old 01-23-2006, 02:18 AM
GS
1/2" drive wrench with a little cheater, if necessary.
Bowhuntr
99.5 Red Metallic F250 SWB 4x4 Off Road, DAC2 PSD CC Lariat, Isspro EV Pyro/Boost, SCMT, SB CON-O, Modified Zoodad Intake w/K&N filter, 4" DPPI exhaust w/6" SS Tip, 6 speed, Man hubs, C/TT, 3.73 LS, 4whl ABS, 4" Procomp/Dual Rancho 9000's, Rear add leaf, 315 BFG MT's. Pulling 30' Savanna 5er
GS is offline
post #5 of 13 (permalink) Old 01-23-2006, 05:46 AM
NCHornet's Avatar
FMT
17/8 what is this? If I remember right this is an improper fraction, the proper size would be 2 1/8", unless I missed something [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
BTW you can buy a cheap stamped wrench at any auto parts store for about 10-15 bucks. Now install a coolant filter to save your new pump!!!
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #6 of 13 (permalink) Old 01-23-2006, 08:28 AM
JimTJr's Avatar
My Photos: (20)
I think you wont be able to get the fan off with a wrench alone. I used a air chipping gun to get the OLD ONE OFF,, DO NOT use it to reinstall on the new fan. Take the chipping gun blade and put it against the proper edge to unscrew,,and burp it a couple times. Nut will come off very easy then. To reinstall just get it as tight as you can while holding the fan,,, engine running will do the rest over time.
AND I THINK he meant 1 AND 7/8" wrench NC.... just missed the space.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #7 of 13 (permalink) Old 01-23-2006, 08:37 AM
you mean an "air hammer" with a chiesel tip [img]/ubbthreads/images/graemlins/smile.gif[/img]
9/1998 f-550 wrecker all stock with around 200k
new swamps,fuelpump,lines,tank,filters,oil!!
031600 is offline
post #8 of 13 (permalink) Old 01-27-2006, 10:12 PM
My Photos: (10)
Try using a pipe wrench on the lip of the pully and 1 7/8 wrench or big cresent.And yes he forgot a little space.
j_apetersen is offline
post #9 of 13 (permalink) Old 01-28-2006, 01:56 AM
klhansen's Avatar
My Photos: (180)
A pipe wrench will surely bugger the pulley up, and you'll need a 24" or larger pipe wrench to open that far.
The best thing to hold the pulley is the proper wrench that engages two of the bolts on the pulley, kind of a hinged "Y" shaped arrangement with hooks on the ends. I got mine at NAPA for about $25. Pretty cheap investment, and saves lots of screwing around and potential damage.
The nut on the fan clutch is actually 48mm, but 1-7/8 inch is close enough.
), AIS,
regulated return,
klhansen is offline
post #10 of 13 (permalink) Old 01-28-2006, 06:37 AM
The tool you need to hold the fan still can be barrowed from Auto Zone or any other local such store. As for the big bolt, I used a crescent wrench. No problem. I got all confused with this reverse thread vs. Standard thread, and which way we are facing.... if you are looking at the truck from the front you will need to turn the wrench counter-clockwise. Good luck and may the force be with you...
1999 PSD 4X4 (Black)
Leather
Programmed
LineX Bed Liner
4.10 LS
Straight Pipe exhaust
33's on Lariat Wheels
nbeihl is offline
post #11 of 13 (permalink) Old 01-28-2006, 08:52 AM
I replaced my WP not long ago. I used a pipe wrench on the nut. O'rielly's here had a "fan clutch wrench". Thier policy is to buy the tool ($75), and of brought back within 48 hours they give you your money back, essentially a free loaner.
The fan clutch wrench DID NOT list the 7.3 PS as one of the engines it fit, it did however work great.
'99.5 F250 crew cab, stock
'02 Excursion stock
Check out my blog:
scbaguy is offline
post #12 of 13 (permalink) Old 01-28-2006, 10:06 PM
My Photos: (10)
I used a small pipe wrench about the size of my hand. putting it under the lip and used it like a vice, if you use a rag no markes.
post #13 of 13 (permalink) Old 01-29-2006, 02:45 AM
klhansen's Avatar
My Photos: (180)
I understand now. Kind of like hooking the wrench over the lip of a tin can. You still might run the risk of bending the pulley rim if the fan clutch nut on there real tight.
I still prefer the pulley holding tool I got, but might try the pipe wrench in a pinch and nothing else was available.
), AIS,
regulated return,
klhansen is offline
