Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-08-2008, 03:12 PM   #1 (permalink)
12-71 roots on 7.3L PSD
I just picked up a 12-71 roots blower last night. Has any one ever tried ditching the turbo set up for a roots supercharger? Looking at compressor maps for this blower, it looks like its most efficient at 2000rpms and ~17-20psi. I know I'd lose the intercooler and have fab up the belt drive and intake.
Anyone thoughts on this?
2002 F250SD Supercab Longbox, Edge w/Attitude, AFE Stage 2 PG7, MBRP T304 Cool Duals, BD Exhaust brake, WW, ATS housing, FTVB, TM wastegate controller, Brite Box
295.7hp / 707.9 ft/lbs
90Ranajo is offline
Old 07-08-2008, 04:20 PM   #2 (permalink)
I have had similiar wild hair thoughts and remind myself that the truck is the toy hauler, not the toy...in my case
you can always run a water to air intercooler underneath of the blower and place the heat exchanger where the intercooler sits now. Then exhuast manifold or a simple elbow would be needed to close of the gap in exhaust flow. Oil, etc to and from the turbo too.
'00 F250 7.3L, 4x4, 6-spd, stock for now
96 Impreza "WRX" coupe time attack car
WVO kit in the making. To-do list: 4" TBE, DIY intake, B-code injectors, DP-tuner
Homemade WRX is offline
Old 07-08-2008, 04:37 PM   #3 (permalink)
Why give up the turbo for a power robbing roots blower
The Roots blower will be a less efficient and will rob power from motor to turn the blower. Hard to beat a turbo setup as far as power and efficiency.
99 F-250 PSD, CC, SB, 2WD, Jody Tipton 4 position Chip, DPPI 4" exhaust, AFE Stage 2 intake, Sonnax valve, BD torque convertor, Turbonetics 1.0AR Ceramic Coated turbo with Ceramic up-pipes, Terminator Dual HPOP's, ITP Diesel Regulated fuel return, Diesel Site hoses. A-pillar boost and exhaust gauges, fuel tank mod
toddg is offline
Old 07-08-2008, 04:40 PM   #4 (permalink)
Keep the turbo on the 7.3 or upgrade to a larger turbo if need be. But leave the blower to gassers.. It takes alot of power to turn that blower.
99.5 F-350, 6 speed - DI Tuning, DI B-Codes, DI Reg Return, DI One piece up-pipes, DI Pushrods, DI Intercooler, DI HX-crossover, DI Intercooler, ARP Head Studs, Garret GTP38R, FASS 150/150, Magnaflow Turbo back, Boost pressure regulator, Comp 910 Valve Springs, South Bend Con-FE Clutch, AFE Stage II, Autometer Sport Comp II gauges
Leveling Kit w/35X12.5R16 Nitto Mud Grapplers 10 Ply.
Rockrunner86 is offline
Old 07-08-2008, 08:55 PM   #5 (permalink)
Yeah, but they also have far less in the way of pumping losses, which the higher manifold pressure ratio really is a killer of hp too...not a static drag but as pumping loss and through reversion
Realistically a turbo will be far easier/cheaper as you don't have to do custom work or nearly as much.
