1500 cold cranking amps? - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 10-28-2007, 08:24 PM Thread Starter
My Photos: (5)
I was looking at CAT batteries, and was wondering if anyone had them on their PSD? I figure if my motor ever let me down, i could drive home on the starter with that many cca's lol. I was also reading that they made batts for frequent starts, and some for ideling all day and some for running accs for longer periods. Which one would be best? http://www.cat.com/cda/components/fu...7&x=7&id=90282
thanks
2002 7.3 powerstroke diesel lariat, automatic, crew cab, long wheel base F-350 SRW. 35" mud brutes, 6" procomp lift, custom tool box, 5" smoke stacks, brush guard and an oil leak <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
yamahajo is offline
post #2 of 17 (permalink) Old 10-28-2007, 08:46 PM
Re: 1500 cold cranking amps?
The OE batteries for your truck have 750 CCA's each. Some replacements have more. The ones in my truck have 875. You will have to do some hacking to make those group 31's fit too.
444-4D is online now
post #3 of 17 (permalink) Old 10-28-2007, 09:06 PM Thread Starter
My Photos: (5)
is there any point in it?
yamahajo is offline
post #4 of 17 (permalink) Old 10-28-2007, 09:07 PM
Any point to what?
post #5 of 17 (permalink) Old 10-28-2007, 09:28 PM Thread Starter
My Photos: (5)
putting that big of a batt in a PSD? Other then faster starts mabey?
yamahajo is offline
post #6 of 17 (permalink) Old 10-28-2007, 09:47 PM
sirthomas's Avatar
because if a little is good, alot is better, and too much is just about right
01 F350 Lariat Crew Cab Short Box 4x4,4" Magnaflow turbo back exhaust,K&N air intake,Edge Juice with Attitude,Warn Manual Hubs,6.0 Trans Cooler,B&M Trans Temp Gauge,ATS housing,Turbo Master Wastegate Controller,Banks transcommand,CCV mod,coolant filter
sirthomas is offline
post #7 of 17 (permalink) Old 10-28-2007, 10:25 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: yamahajo</div><div class="ubbcode-body">putting that big of a batt in a PSD? Other then faster starts mabey? </div></div>
I'm not even sure what battery you are talking about. You talking about one of those CAT batteries or a replacement battery that fits? Did you miss the part about the OE batteries having 1500 CCA's?
post #8 of 17 (permalink) Old 10-30-2007, 05:23 AM
I believe he is wanting to put in batteries that have 1500cca apiece. Combined 3000cca. To the original poster, it won't hurt anything that I know of to put the more powerful batteries in. You might want to do some measuring before you buy them. I don't think you have enough room under the hood for them.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
post #9 of 17 (permalink) Old 10-30-2007, 12:12 PM
That's what I thought until I looked at his link. He linked group 31's with 710,825,and 1000 CCA's.
post #10 of 17 (permalink) Old 10-30-2007, 07:23 PM
haul_n_horses2's Avatar
My Photos: (17)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: yamahajo</div><div class="ubbcode-body">I was looking at CAT batteries, and was wondering if anyone had them on their PSD? I figure if my motor ever let me down, i could drive home on the starter with that many cca's lol. I was also reading that they made batts for frequent starts, and some for ideling all day and some for running accs for longer periods. Which one would be best? http://www.cat.com/cda/components/fu...7&x=7&id=90282
thanks </div></div>With Group 31 batteries you will need to pull the existing battery trays, including the OEM snorkel/battery box and custom fab two new trays. Also note that those batteries do not have automotive terminals but studs, so you will need to put new ends on the OEM wires. I put Group 31 Commercial Yellow Top Optima batteries. They were a bit pricey but they have not let me done in two years.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #11 of 17 (permalink) Old 10-30-2007, 07:52 PM
Here are the sizes.
Stock batteries size 65 12 1/16 L X 7 1/2 W X 7 9/16 H
BCI 31 battery size 13 L X 6 13/16 X 9 7/16
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: starter, batteries, cps, brakes, tires, alternator, ball joints, AC compressor, serpentine belt.
DonWarkentin is offline
post #12 of 17 (permalink) Old 11-01-2007, 03:07 AM
CriticalRick's Avatar
check out optima 31 group, 12.8x6.5x9.4 they are fairly small with 900cca ea not 1500 ea but way better than stock and much lighter (59.8lbs ea)they will fit under the hood on their side.
http://www.1st-optima-batteries.com/
2000 CC/SB 4x4, MBRP stainless 4", Aero Turbine muffler, HPX, CCV, 6637, Edge Evolution, AutoMeter gauges, 2009 mirrors, 17.5 MPG!
CriticalRick is offline
post #13 of 17 (permalink) Old 11-01-2007, 05:51 AM
Putting a very large (heavy) Battery in your truck will be very hard on the body and tent to shake things apart, if you have high demand for running accs for longer periods. with the truck not running, You will want to look into a Deep Cycle battery. If you are running accs large for longer periods with the truck running and running down your battery, You need a larger alternator not battery. and unless you are trying to start a larger displacement engine you really have no need for very high CCA's Spike481
2002 F/350 Super Cab XLT Lariat trim 6spd SRW 4x4 3.73 posi 7.3 LUBERFINER 272-C AUXSILERAY OIL FILTER, MBRP 4"409 stainless steel exhaust AIS,
Spike481 is offline
post #14 of 17 (permalink) Old 11-01-2007, 05:52 AM
My Photos: (17)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: CriticalRick</div><div class="ubbcode-body">check out optima 31 group, 12.8x6.5x9.4 they are fairly small with 900cca ea not 1500 ea but way better than stock and much lighter (59.8lbs ea)they will fit under the hood on their side.
http://www.1st-optima-batteries.com/ </div></div>Read my thread above again. That is what I have. They will not fit in the stock location without replacement of both battery trays even if they are slightly smaller!
post #15 of 17 (permalink) Old 11-02-2007, 06:48 PM
I just priced optimas at the local store
all I can say is have a chair handy when you see the price...yikes
made me go out and clean off the teminals and add some life to my batteries.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
