1999 F350 7.3 major oil leak - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 09-24-2006, 05:19 PM Thread Starter
Hi, I could use a little help I discovered a major oil leak I do not understand what or where the item is coming from. The leak is coming from an area above the oil filter where a steal looking item look like it goes in to aluminum item. I am learning more and more as time goes on with this truck. The truck is a 1999 F-350 quad cab dully with the 7.3L engine 4x4. The truck is all stock with 44k+ miles. I am the second owner. The oil is leaking in a stream coming down.
Thank you
Patirck aka Freejack.
gormanpat@cox.net
Freejack is offline
post #2 of 4 (permalink) Old 09-24-2006, 07:24 PM
Re: 1999 F350 7.3 major oil leak
Could it be leaking from the oil cooler? Its that clyinder located just forward of the area you are describing.
Early 1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW
DIRTBIKEZ is offline
post #3 of 4 (permalink) Old 09-24-2006, 07:26 PM
It sounds like your oil cooler.
01 D2500 2x4
DART505 is offline
post #4 of 4 (permalink) Old 09-24-2006, 08:24 PM Thread Starter
thank you. I have relooked at it after the engine cooled and the filter connects to the alumiun housind and this other piece is there. I will look in too the oil cooler
thanks
pat
Freejack is offline
