Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
I'm getting ready to put my 2.5" leveling kit on the front and a 2" add a leaf in the back... i was wondering what size tires i would be able to fit on there after this.
I have 285/75/16 on there now and i would like to go with as big as i could... like a 35 or maybe a 37 12.50.
1999.5 Ford F-250 7.3l 4x4 PSD With some extras
For 35" I'd go with a 4.5 hanger lift 37" better go 6-8". A add a leaf is gona make it ride like crap..
Cary
I have to say, listen to caryt. He helped me out when I was ready to level out and I'm really pleased with my outcome. I replaced the front springs with X-Code springs, put on a 2 1/2" mini spring pack, and 2" blocks in the back to keep it level and of course, new Bilstein Shocks. The ride is great, a little rough on really bad roads, but better than stock overall. I fit 315/75 R16's on with only very minor rubbing on the inside of the fender well with wheels at full lock and hitting big bumps.
i have a tuff country 2 1/2" leveling kit in the front and a 2" add a leaf in the rear of my dually. i run 6 315/75-16s on stock dually rims with a 2" adapter in the rear. if you look at my pics you can see i do wheel with this truck and have never had a problem. you might get a little rubbing like what was said in the post above bot nothing to be worried about
2001 F350 SuperCrew Long Bed Dually.
7.3L turbo Diesel, automatic transmission, goose neck hitch, fifth wheel hitch, stainless steel back rack, 315/75-16 BFG A/T's, AUX back up lights, euro-lite driving lights, upgraded fog lights, dp-tuner, turbo master wastegate controler, dieselsite boost relief valve brv+, auto-meter ultra-lites, 5in stacks no muffler, whelen towmans light bar, DIY tymar intake, DIY coolant filter, 2M ham rig, DIY AIC,
( egauges )
Thanks, I dont care about the ride as much as i want the bigger tires without having to put $900 for a lift. i got all the stuff for the 2.5" for $300 and i want the springs because i pull a lot of big tailors and also a plow in the winter. I just wanted to make sure i can fit 315/75/16 witch is a 35 on there with no problems.
I'm running 295 / 70-17's and thay only rub on my mud flaps. a lot depends on your wheel spaceing and how your going to use your truck. If it's an everyday driver only lift it as much as you have to. If it's your toy lift high and play on.
proud member of ANG 164th AW
2002 F250 PSD CC 4X4 295-70-17 on 17-9, juice with attitude, edge evolution, afe stage II with proguard 7 filter, tank and prepump mods, sonnax valve & tricumulator springs
i have a leveling kit on my truck with 35s and have no problems but depending on how heavy your plow is you might have a problem with that hanging on the front.
__________________ early 99 white lariat. leveling kit with 35" procomps, 4 inch from turbo back, dp tuner (80-120), aeromotive fuel pump and reg return, tymar intake, BTS valve body and tci converter.
coming soon big injectors, big oil, and turbo
89 diesel jetta running b100 with 250,000 on the clock
I also plow with my truck, but probably don't tow as much heavy stuff. I never had a problem with the plow before, it was just low to the ground. Now it sits nice and high if I want, and don't have any problems at all with the new tires and lift.
If you look at my pics, before and after, you'll see a big difference after the X-code springs and the levelling kit were added, along with the tires. Total lift above stock at the front was just above 6" including the tires.
Just installed the Summit Racing 2.5" kit and 315-75-16's and worked great. I did have to space the front bumper out aby 1.5", but if you cut the lower valence you could avoid that. I just didnt want to have a hacked up look. Rides better than stock. I have a 2002 F350 Crew Cab long bed.
