203° Thermostat - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 10-09-2009, 01:20 PM   #1 (permalink)
Ryanspowertroke's Avatar
203° Thermostat
Is it a mod worth doing or not??
2000 F-250 7.3L
8" Lift with traction bars
325/80/16 ProComps
DP Tuner High idle,60t,80eco,120r,140ag
DIY Tymar Intake
4" MBRP straight piped
foil delete, zoodad mod, 10K mod, aih delete
Glow Shift guages they suck but they were free
Ryanspowertroke is offline
Old 10-09-2009, 05:01 PM   #2 (permalink)
Do a Search. Some have had positive results while others have shown no benefit.
2OOO F-250 4WD Crew Cab, 248,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator H2O Pump. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 10-10-2009, 08:05 PM   #3 (permalink)
If you are looking for more heat, then yes, it will give you that, BUT, that is it.
If you are looking for better MPG - forget it, you can get better MPG by keeping the truck light, no lifts, nor oversize tires, speed under 60, and treat the go pedal like an eggshell.
If your truck gets checked for emissions with this tstat, do not be surprised if you are not passed on the emissions test.
Hopes this helps,
Butch Cassidy1
O
2000 F250, 2WD, XLT - A HAULING AND TOWING WORKHORSE.
butchcassidy1 is offline
Old 10-11-2009, 11:10 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Ford engineers determined that 195° was right for the thermostat in our 7.3L PSDs. I haven't seen any evidence that the Ford engineers were wrong. So I'm on my third Ford OEM thermostat in 10 years and 185,000 miles.
SmokeyWren is offline
Old 10-12-2009, 01:41 AM   #5 (permalink)
If you cooling system temperature is above 203º, then it won't matter which one you use, and it will not provide you more heat.
What is your idle temperature?
What is your unloaded cruise temperature?
What is your loaded temperature?
2000 F-250 7.3L Powerstroke. Build date 08/99.
snakyjake is offline
Old 10-12-2009, 10:57 AM   #6 (permalink)
bigb's Avatar
I decided to go with the 203* because my truck sees a lot of short trips. Also I never tow anything.
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 140K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Battery Tender & 2 Marincos.
bigb is offline
Old 10-12-2009, 12:00 PM   #7 (permalink)
Teknobenji's Avatar
Hopes this helps,
Butch Cassidy1
O
Why would that change our emissions? our worst emissions are at idle after startup with a nice cool engine.....
( I am just curious - have always run the OEM Ford thermostat myself)
1999.5 F250 Crew 4" Magnaflo Turbo back exhaust, DIY intake, AIH Delete, HPX Line, zoodad mod, Wicked Wheel, Gauges (Tranny, Boost, EGT) DP-Tuner ITP "In-Tank" mod and prepump filter, RiffRaff FRX Regulated return, foil delete and lighted cup holder...that's right - lighted cup holder.
Teknobenji is offline
Old 10-12-2009, 03:54 PM   #8 (permalink)
missmanj's Avatar
only if you like more heat in the winter, otherwise no benefits at all what so ever, had it installed for over a year.
2000 F250 7.3L 200,000
DP Tuner F5 Gauge Switch (Stock, High Idle, 40t, 80e, 140A, Lope Idle, 120R)
Rancho Nine Position RS9000XL Shocks
203* Thermostat
DIY Intake Napa 6637 Filter
CCV Mod
4" Straight Pipe Exhaust
ATS Turbo Housing
ISSPRO Gauges (Pryo, Trans, Boost, Water)
Turbo Saver
Max AC Assist
Stancor GPR
DB High Torque Starter
missmanj is offline
Old 10-12-2009, 04:01 PM   #9 (permalink)
You need to qualify this. What is your operating coolant temperature?
If your coolant temperature is above 203º, it won't matter what thermostat you use.
Old 10-13-2009, 12:43 PM   #10 (permalink)
DIESELSITE's Avatar
Hopes this helps,
Butch Cassidy1
Based on what knowledge or experience? Your use of the wrong International thermostat? We've been over this before Butch. You bashed my thermostat for years insinuating you bought from us until I posted you never bought mine and you had to admit you bought a short stem International stat.
and to complete the sentence........ to meet the new OEM emmision requirements. (whether testing to determine the difference even existed or not).
To use your logic, the Ford engineers
decided the International engineers were wrong. So, who was right?
Bob
Bob Riley, Owner DieselSite.com
Proud Sponsor of TheDieselStop.com
GOT DIESEL? call us at 888-414-3457
DIESELSITE is offline
Old 10-13-2009, 12:58 PM   #11 (permalink)
DIESELSITE's Avatar
To further note that since all current and future emmissions tests that I know of rely on visual smoke, and the fact that a hotter engine reduces particulate emmissions (soot), then the thermostat should actually help more trucks meet the new emmissions testing coming down the road.
Bob
Old 10-13-2009, 01:56 PM   #12 (permalink)
Rickie's Avatar
Has anyone had to remove their 203* Stat because of failed emissions?
It's an interesting point, emissions in diesel. If you change something to reduce soot, such as increase combustion temp, you increase NOx. If you reduce combustion temp, NOx goes down but soot goes up. Future diesel emissions standards will require hugely reduced particulate matter and NOx, that's why we will have Diesel Particulate Filters and some sort of Selective Catalytic Reduction system for NOx.
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade HX Crossover Mod & Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline
Old 10-13-2009, 02:06 PM   #13 (permalink)
What was your water temperature at the time of emission test?
This is fairly simple...if your temp is above 203º, it won't matter what thermostat you use.
Old 10-13-2009, 02:13 PM   #14 (permalink)
Why do you think this?
444-4D is online now
Old 10-13-2009, 02:32 PM   #15 (permalink)
Because with a 203º thermostat, when the coolant temperature is above 203º, the thermostat is fully open.
If you have a 195º thermostat, it fully opens at 195º. This will include all temperatures above 203º too.
So at 203º, both thermostats will be fully open, allowing full flow coolant to run through the system.
When temperature is below 203º with a 203 thermostat or 195º with a 195 thermostat, both thermostats are operating identically. The is because they are both closed.
The above is how normal and conventional cooling systems work.
So the talked about differences will be if your coolant temperature is below 203º.
The benefits will be when your engine is between 195º and 203º. This benefit is the amount of time it takes for your engine to warm up between 195º and 203º. Or anytime your engine is below 203º.
It's also the reason why most emissions are emitted during startup.
I'm not sure of the idle temperatures between the Ford or large commercial truck. Not sure if Ford tried solving the startup emissions, idle emissions, or both.
And when doing an emissions test, you can run up your RPM's above idle, which may generate enough heat above 195º.
So again, I'm not sure what emissions Ford was trying to solve.
Jake
