203° Thermostat - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 10-13-2009, 03:15 PM   #16 (permalink)
Originally Posted by snakyjake View Post
Because with a 203º thermostat, when the coolant temperature is above 203º, the thermostat is fully open.
If you have a 195º thermostat, it fully opens at 195º. This will include all temperatures above 203º too.
So at 203º, both thermostats will be fully open, allowing full flow coolant to run through the system.
Jake
Those temps are start to open temps. Full open temps are 12-15 degrees higher.
444-4D is offline
Old 10-13-2009, 03:44 PM   #17 (permalink)
Great! Finally someone that was able to make a comment on my logic
I researched more from your comment, and found your comment to reflect other sources.
My logic will have to be modified a bit. And people need to check their coolant temperature to know if a 203º thermostat (coolant above 215-218º) will be a benefit.
I don't know the normal operating temperature, so I can't say. That's now my missing piece of info.
Jake
2000 F-250 7.3L Powerstroke. Build date 08/99.
snakyjake is offline
Old 10-14-2009, 04:53 PM   #18 (permalink)
Originally Posted by SmokeyWren View Post
Ford engineers determined that 195° was right for the thermostat in our 7.3L PSDs. I haven't seen any evidence that the Ford engineers were wrong. So I'm on my third Ford OEM thermostat in 10 years and 185,000 miles.
Smokey hits the nail on the head.
Butch Cassidy1
2000 F250, 2WD, XLT - A HAULING AND TOWING WORKHORSE.
butchcassidy1 is offline
Old 11-06-2009, 04:44 PM   #19 (permalink)
Normal average operating temperatures on a gasoline engine(may or may not be comparable to a diesel) usually run @ or around 230*F. Anyone with a scan tool can check this. Only advantage I see of having a 203* is idle temps can be higher, and most larger trucks idle more so I can see the benefit of the 203*. I have one, and I do get more warm air when idling than I did before, but that is about the only effect of having it.
DD 2010 Ford Fusion Sport
relegated to garage duty
U.S.N. Paradise BB91904
'99 F350 CC LWB DRW
Mods, SuperHyper Improbability drive stage II.
Hypermax 5" turbo back system, triple pillar guages, Heater core shutoff. AEM Brute Force intake. 3.73 gearing. DP PCM with 80HP Installed!
ACD2 is offline
Old 11-06-2009, 06:00 PM   #20 (permalink)
fddriver2's Avatar
I had one for about 2 years, worked fine. I did a coolant flush and put in a oem 195* t-stat and new housing. I couldn't tell any difference between them, performance wise. Mileage didn't change enough for me to tell, engine didn't run any smoother or rougher, didn't make any more or less noise.
If I lived up north where the snow flies and the cold is for real I might have kept it, but here in South Florida who needs more heat?
Just my $.02
I have a philosophy? Who knew. Ok, where's the beer?
2002 F-250 XLT CC SB\HPX\ITP prepump mod\Harpoon\DI 65psi fuel shim\4" SS turbo back Magnaflow\Fumoto\FTVB\Edge Evolution2\Zoodad\2008 Diff cover\V-10 Transmission cooler
fddriver2 is offline
Old 11-06-2009, 07:22 PM   #21 (permalink)
fxdwgi's Avatar
....I make my living off of Ford engineers who are wrong.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 12-23-2009, 05:56 PM   #22 (permalink)
Vaquero45's Avatar
Amen, you tell it brother! Oh that was SO appropriate and I can SO relate. My engineers weren't from Ford but most are born of the same mold.
2002 F-350 SRW CC LB A/T 4X4 7.3 White
BTS VB and fine tuning; BD Pressure Lock
DP-60T,80E,100,120
ISSPRO EGT & Boost
-Mistake- 2001 Dodge RC Flatbed 4X4 Cummins HO 6spd (Owned 3 months)
-Sold- 2000 Lightning White
-Sold- 1995 F-250 RC 4X4 5spd 5.8 White (shoulda kept it)
Vaquero45 is offline
Old 12-24-2009, 04:22 PM   #23 (permalink)
But the F**d engineers were right on the 195 tstat for our PSDs.
ButchCassidy1
Old 12-26-2009, 07:53 PM   #24 (permalink)
Kanman's Avatar
Originally Posted by Ryanspowertroke View Post
Is it a mod worth doing or not??
I am happy with mine. Heats up the cab in the winter quicker. I would buy another one for that reason alone.
Kanman is offline
Old 01-04-2010, 07:57 AM   #25 (permalink)
Originally Posted by butchcassidy1 View Post
If you are looking for more heat, then yes, it will give you that, BUT, that is it.
If you are looking for better MPG - forget it, you can get better MPG by keeping the truck light, no lifts, nor oversize tires, speed under 60, and treat the go pedal like an eggshell.
If your truck gets checked for emissions with this tstat, do not be surprised if you are not passed on the emissions test.
Hopes this helps,
Butch Cassidy1
O
I'd like to see your thought process behind the claim that an 8 degree hotter t-stat will increase emissions.
Do you suppose you could share it?
checkthisout is offline
Old 11-03-2010, 09:57 PM   #26 (permalink)
There's no possible way it will heat up quicker. The coolant is gonna heat up at the same rate with either thermostat.
2001 F350 SUPER DUTY 4x4 CC DUALLY 7.3 PSD SILVERLINE STAINLESS EXH. FROM TURBO BACK
NEW EDGE EVOLUTION....TO BE CONTINUED.....
DarrinWilson is offline
Old 11-03-2010, 10:51 PM   #27 (permalink)
claw444's Avatar
the antifreeze will circulate in a closed loop until the thermostat opens. once the t-stat opens the water circulates through the whole system. once this happens the water temp will drop. a t-stat that is 8 degrees hotter is not going to make much of a difference keeping the water temps higher once the system is open. that 8 degree difference probably helps a lot in temps around 20 degrees outside getting heat in the cab. since the system will stay in a closed loop longer. consistant engine temps are key to long life. if the engine is not holding consistant temps across the board this opens it up to a shorter life. the question being by the 203 staying closed longer is this not allowing a consistant engine temp across the board? or is it? i dont know. just something for everyone to think about.
2002 F-250: CREW CAB: SHORT BED: 4X4IESEL: 6SPD MANUAL: ALUMINUM AIR INTAKE: 4" BANKS DOWN PIPE: CUSTOM MADE 5" DUAL EXHAUST IN FRONT OF REAR WHEELS: TS PERFORMANCE 6POSITION 140HP: AUTOMETER GAUGES ON PILLAR AND ON INSTRUMENT CLUSTER: DUAL FRONT SHOCKS: DUAL STEERING STABILIZER: KYB MONOTUBE SHOCKS AND STEERING STABILIZER: LIFTED 2INCHES: TOYO OPEN COUNTRY AT TIRES LT285/75/17 LOAD RANGE E: 17" AMERICAN RACING WHEELS: CUSTOM MADE WHEEL SPACERS: WARN HUBS: POWER SLOT FRONT BRAKE ROTORS: HAWK SD BRAKE PADS UP FRONT: SMOKED CAB LIGHTS: SMOKED TAIL LIGHTS: POLK AUDIO 10" SUBS IN HOMEMADE BOXES: SONY HEAD UNIT AND SPEAKERS: KENWOOD AMP
claw444 is offline
Old 11-05-2010, 01:29 AM   #28 (permalink)
I will tell you this from experience:
a 203 stat will make the heater hotter than a 195 stat!!! Proven fact. the thermostat will open at the given temp and once settled will level at near the stats range under normal driving conditions. a 203 stat will allow the temps to run hotter and maintain a higher normal operating temp.
A truck with lets say a 180deg stat in the winter WILL NOT Produce the same heater temps as a 195 or 203 stat. I used to have a 79 ford pickup with a 180 stat and the heater sucked in the winter; I replaced with a 195 and made all the difference to keep the truck warm; so those that state that it doesn't make a difference on heater ouput is full of it.
and if that was the case; then there would be no reason to run a thermostat. Also if you DO NOT run a thermostat; why will a vehicle not heat up in the winter EVER???
as far as heating up quicker; I do not recall which way it goes, but one does heat up or produce better heat than the other. I would say 195 would produce heat quicker, but 203 will provide warmer air
a truck with the 203 stat will still pass emissions, no problem. I pass every year with no issues.
I do not physically see/feel any noticeable benefits between the 2, but that does not mean there is no difference between the 2.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
DP Tuner F5 w/guage style switch. No Start, Stock, 1200RPM high idle, 60 tow, 80 econo, 120 race
Autometer Nexus Guages, 4"MBRP Exhaust w/muffler(contemplating a muffler delete). DieselSite Coolant filtration system,203* t-stat and billet housing, AIH delete, DieselSite HP X-Over line. Slotted Cryo rotors F&R with pads. K&N Intake tube w/ (Baldwin PA2818 $20) Bellowed up-pipes; Turbonetics Turbo, Foil Delete, BTS VB, ITP In-Tank mod & Prepump Filter kit
INFRNL is offline
Old 11-05-2010, 09:52 AM   #29 (permalink)
Originally Posted by INFRNL View Post
as far as heating up quicker; I do not recall which way it goes.
There is no difference in how long it takes to get to 195 degrees. The 203° thermostat would effect the increase from 195° to 203° only.
444-4D is offline
Old 11-05-2010, 11:16 AM   #30 (permalink)
Diezel Dawg's Avatar
During my live tuning with Jody, i found out my Oil temps were on the too High End of the temp range, I will soon be swapping back to OEM 195.
Ken
99.5 7.3L PSD 4x4
WOP GQSSB TURBO
Tyrant Diesel Tunes
TYMAR Intake
Casserly 250cc Hybrid Injectors
BTS
496 hp 985 tq!! 16 Apr 11
13.74 sec in 1/4 mile @ 98.5mph
PNWFDE#2
Diezel Dawg is offline
