4R100 Shift improvment - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-07-2013, 09:41 PM   #1 (permalink)
ThunderFord66's Avatar
My truck has 190k on it and the trans is sloppy as... well you know. After adding a chip it just magnified how sloppy it really is. What accumulator kit(s) can I get to firm everything up. I get a slip-bump on takeoff if I get in it a little and then I feel like I run out of power before it sponges into 2nd. With no chip the trans feels "normal". I want solid, smooth power from stopped to stomped. No pauses along the way. Any advice will help. Thanks, David
My Truck Pictures-2002 F350 Crew Cab Long Bed 4x4 on 37R12.5/17 Swampers. Autometer pyro,trans,boost gauges, 4"exhaust with Dynomax Bullet muffler, on board air and some serious air horns.
WHEN YOUR A CROSS THREADER YOU DON'T NEED LOCK WASHERS!!
ThunderFord66 is offline   Reply With Quote
Old 01-09-2013, 01:13 PM   #2 (permalink)
jgorm's Avatar
The chip probably jacked up the pressures. If its still slipping, then you probably need new clutches as adding more pressure probably wont help.
E450 7.3 PSD in a Bigfoot 24' motorhome.
Acquired parts for the intercooler mod
Intake spider
jgorm is offline   Reply With Quote
Old 01-09-2013, 02:07 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Yeah, if that's the original stock tranny, then it's probably simply worn out. Very few 4R100 trannies lived past 150k miles.
SmokeyWren is offline   Reply With Quote
Old 01-10-2013, 02:45 PM   #4 (permalink)
Feedback Score: 3 reviews
X3....
IF the trans is in good shape I would do this:
31 row 6.0 trans cooler
BTS VB
Hybrid tq converter..
We have all including new BTS tran's if you deside to get a fresh one.
PM me if I can help.
Cary
caryt is offline   Reply With Quote
Old 01-14-2013, 06:34 PM   #5 (permalink)
i have 180k on my 4r100 and its still running strong. stroke of luck?
white 2001 f350 offroad edition, 174,xxx miles, ext cab shortbox, 285/75/16 cooper discoverer S/T's, line-X bed liner, gooseneck hitch, pillar gauges, Edge juice with atitude tuner. all stock temporarily, id like to put a 5 inch turbo back exaust, cold air intake and biuld the transmission on it
fordpowerstroke20 is offline   Reply With Quote
Old 01-15-2013, 11:30 AM   #6 (permalink)
Some last longer than others...its a bell curve.
Cary
Old 01-15-2013, 11:48 AM   #7 (permalink)
rammertide07's Avatar
Send a message via MSN to rammertide07
What kind of tuning? The transmissions go much faster with aftermarket tuning.
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes (Stock, 40 Tow WITH Whsiper tune, 80 Daily Driver, 100 Race, 140 Extreme, 140 smoke show)//Recon smoked cab lights/MM Hubs/Hood/HPx/FRx/GPR switch-Indicator
First vehicle (still driving): 96 F250 XLT 2x4- All factory (injectors & turbo) except straight exhaust. 570k miles
rammertide07 is offline   Reply With Quote
Old 01-15-2013, 03:11 PM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Mild tuning up to about an additional 80 HP won't reduce the longevity of a 4R100 tranny, provided you drive by the gauges and NEVER allow more than 225° tranny temp, and you keep fresh ATF in the tranny. I usually ran a 60-tow tune, but sometimes 80-economy. My stock tranny and torque converter lasted 112,000 miles before the torque converter began showing signs of fatigue. When BTS tore it down, Brian said the torque converter was shot, but the tranny would probably have lasted another 100,000 miles before needing an overhaul.
So an aftermarket tune is not the culprit if they were written by one of the good tuners such as Jody Tipton, Bill Cohron, or Tony Wildman. Tunes over 100 HP, inadequate maintenance, and high temps are the killers of most 4R100 trannies.
