7.3 to 6.4 swap - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 10-18-2009, 10:14 PM   #1 (permalink)
powerlifter405's Avatar
7.3 to 6.4 swap
I'm not seeing it so i'm guessing it hasn't been done yet.
I have a 2002 and i took in some water a while back and my compression is going down hill. I"ve been think about a swap and wonder how difficult it would be.
I'd love to grab the AT while i'm at it and put it in as well. I figure HP# wise, this might be the easiest way to do it.
any thoughts??
New08 F350 CC 4x4 w/ADJUSTABLE Pedals Eric-IDP tuning stoopid quick & thanks to Swamps
sold Sweet lookin' BLACK 02 F-350 XLT CC PSDhttp://photos.thedieselstop.com/show...07/ppuser/1137
powerlifter405 is offline
Old 10-18-2009, 10:23 PM   #2 (permalink)
i wanna know this too, and i also want to know if we still have to play by the emission rules because we have earlier model trucks
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
browningbuck225 is offline
Old 10-19-2009, 02:31 AM   #3 (permalink)
Stymie's Avatar
the shear amount of work to get the electronics to work are prohibitive, let alone the fact i am not sure it would even fit.
you'd be better off either buying a 6.4 equipped truck, or building a new 7.3
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 10-19-2009, 05:27 AM   #4 (permalink)
any thoughts??
Why not cost out getting another 7.3? Even if you can't grab an AT, it would probably be the most cost effective and easiest (least painful) approach to take.
As mentioned in the above post, going to the 6.4 would require a lot of time, $$$, labor to retrofit / rebuild your current truck.
Hopes this helps,
Butch Cassidy1
2000 F250, 2WD, XLT - A HAULING AND TOWING WORKHORSE.
butchcassidy1 is offline
Old 10-19-2009, 08:59 AM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Originally Posted by Stymie View Post
the shear amount of work to get the electronics to work are prohibitive, ...
The only logical way to do it would be to transplant both the engine and tranny, along with the PCM. But you may be right if the anti-lock brake system (ABS) module and the injection driver module (IDM) and other computers in the '02 won't plug-n-play with the PCM for the 6.4L engine.
I suspect it would be less expensive to do a complete overhaul of the 7.3L, along with a bulletproof BTS or equivalent tranny and tunes by a smart guy with a goal of around 350 reliable horses. Plan on a budget of $15,000 for that jobbie. That's a lot less than $45,000 for a new 6.4L truck.
SmokeyWren is online now
Old 10-19-2009, 11:20 AM   #6 (permalink)
Todes's Avatar
Can't do it. I've already looked at it and nothing hooks up.
7.3L Stroken 4 life!!!
2002 F-250 4x4 7.3L Powerstroke 205K(7/2011)
AIS Intake system, BFG KM 2 Mud Terrains new @ 184680mi (1/28/10), Cab Clearance Lights self install 4/17/10, Foil delete and new IC boots 4/24/10
Todes is offline
Old 10-19-2009, 12:18 PM   #7 (permalink)
honeydew's Avatar
People have installed 5.9L Cummins in these to make a nice truck. Seems like a no brainer to stick with the 7.3L, though.
honeydew is online now
Old 10-19-2009, 12:25 PM   #8 (permalink)
Mark Kovalsky's Avatar
I know that they are not plug and play. Someone would have to create a software interface to make this work.
Mark
Mark Kovalsky is offline
Old 10-19-2009, 03:13 PM   #9 (permalink)
i got an auto you got a 6spd....wanna trade?
early 99 f-250 315/75/16 3.5 inch fabtech shackle lift,intake,4" exhaust 5" single stacked,DIY t/c lock, billet t/c and shift kit on a fresh rebuild,beans tunes ,4 hella lights, 05 head light, 05 chrome grill,red wire pluged, HID lights 200k
other toys
2008 ltr450
2002 440ex
blandproud is offline
Old 10-20-2009, 08:17 PM   #10 (permalink)
it should be like in gassers, the emission test is based upon the year vehicle not the motor itself. That is the hope.
as far as electronics, it would be no different than swapping a 5.9 into this truck or a ls1 into a mazda miata. yes, the pcm, idm etc.. would have to be sourced but big deal. to get 500+ out of a 7.3 will run me up wards of 7k+. mini-me's plus a gtp38r already are close to 4k. That doesn't include head studs, plus the time to put it together. Even w/ my situation, i still have to get a pcm out of an auto if i want to put in a 4r100, or i can spend some $ on a controller and put in a newer 5spd auto.
As far as a newer 6.4 is concerned I can buy a local rolled 6.4 for 5K even if i have to spend extra on electronics, Painless wiring always has something up their sleeve. Unless i can find a pre 02 w/ forged rods, i'm looking at another 5K-10K for a rebuilt not including speed parts. everyone said you couldn't put an allison 1000 behind anything but a GM but lo-and-behold how many controllers are out there now to put it behind the 7.3, 6.0 and 5.9.
Additionally now that i think about it, the 1st time i called BTS, they told me that i couldn't swap a auto in place of my 6spd.
I won't be the 1st but if i do it, i definately won't be the last. Why rebuild an antiquated motor assembly when I can get what was once thought unattainable out of a new stock + tuner 6.4?
Old 10-20-2009, 11:52 PM   #11 (permalink)
Stymie's Avatar
i'd be curious to see if it fits first.
17x9 Pro Comp 7189
Stymie is offline
Old 10-21-2009, 04:10 PM   #12 (permalink)
that would be awesome to have the speed of the 6.4 in an early 99' like I have. Or just to be able to pull up beside one and pop the hood and see a newish 6.4 resting between the frame rails would be sweet too!
Old 10-21-2009, 10:50 PM   #13 (permalink)
i know a mechanic at the stealership who claims that he does side jobs w/ a few of the commerical mechanics. i'll inquire what the dimension differences are.
I just think it would be pretty neat and about the same $ wise to shoot for 500hp. My motor is heading out and I would like to have the pieces so i can start by summer of 2010. I have the $$ i just want to confirm which way i'm gonna go. unless i can find someone who pampered an 00-01 (want the forged rods) i'm gonna have to possibly rebuild it and no one around here wants to mess w/ it. ***??
We'll see, if i do go 6.4 i'll definately post info here.
Now i have to find a 12v and a 1 ton drive train for my 94 bronco, a whole other project i don't need to spend money on
Old 10-22-2009, 01:21 PM   #14 (permalink)
Send a message via AIM to rockets10510
....Why rebuild an antiquated motor assembly...
how can the 7.3 be antiquated? int still produces the engines as far as i know. and plus the parts avaiable for the 7.3 will probably be around longer than the 6.4. just my .02
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 10-22-2009, 08:58 PM   #15 (permalink)
MilitiaAir's Avatar
Send a message via MSN to MilitiaAir Send a message via Yahoo to MilitiaAir
The 08/09 trucks are still the same chasis. So many parts can be changed over. If you had a rolled donor truck and had ALOT of energy you could make the swap I think. Ive seen front clip changes, dash changes, everything but engine. Youd have to do a complete swap tho. Engine/ tranny harness from 08/09 truck. All the computers ( PCM, IDM, ect). You might even have to swap more. I think all the trucks have the anti roll stuff on them that the PCM would control? But the engine mounts and tranny mounts should bolt in or come close enough to modify to fit. It would be alot of work tho cause it would require installing the new harnesses. Definatly not a weekend job tho. Sounds like alot of hidden obsticles would go with it. Just depends on how much you get your donor parts for... A stock 7.3 without PMR's will make over 300 fairly easy with just bolt ons. Stage 2 injectors will get you 400. I would carefully weigh the options.
2000 F350 Lariat CC SRW 4x4 7.3 Turbo 4R100, 130K, Icon 8in Lift, EPBV Delete, AIH plug, HPO X-over line, CCV Mod, TS 6 pos Chip, 37x13.50x18 toyo MT's, Coolant filter kit, spin on trans filter kit, 203tstat w/ billet housing, MBRP 4in turbo back, 03 power heated tow mirrors, S&B Intake, Dpictol boost,pyro,tranny,hpop gauges, HID headlights, 08 rear bumper 95 F-350 CC SRW 4x4 7.3L Turbo E4OD 305K, Transgo Shift kit, Edge 100hp program, Warn Premium Hubs, K&N drop in, Blue Cam sensor, 105 gal Aux Tank, FPR Mod, CCV Mod. New Injectors than will be sold...
MilitiaAir is offline
