7.3 to 6.4 swap - Page 3 - Diesel Forum - TheDieselStop.com
post #31 of 44 (permalink) Old 12-19-2009, 05:34 PM
it would probably be easier and cheaper to swap in a cummins with a p pump. you would have a better motor than the 6.4 and a ford with a cummins is just cool.
iforge03 is offline
post #32 of 44 (permalink) Old 12-20-2009, 10:58 AM
69mach1377's Avatar
Yeah, I'm sure it would be much easier and cheaper to install a drive train from another manufacturer entirely...
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, otherwise mostly stock.
Jayco 26BHS elite, no RV parks...just the woods.
69mach1377 is offline
post #33 of 44 (permalink) Old 12-20-2009, 05:21 PM
JimTJr's Avatar
My Photos: (20)
It would be a very cool swap, because you wouldn't need the particulate filter, ect.. like the 08s and up need. You could live up the 7.3L "emission" standards and have a ball!
Good luck and keep plenty of pictures if you do this "Mod" LOL
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #34 of 44 (permalink) Old 12-21-2009, 09:08 PM
does anyone know if the interior door panals and seats fit inside of the 99 to 04 trucks?
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
[SIGPIC][/SIGPIC]
browningbuck225 is offline
post #35 of 44 (permalink) Old 12-21-2009, 09:28 PM
JimTJr's Avatar
My Photos: (20)
The doors sure look to be the same from the outside. Front fenders, and hood are the only main body differences, (and tailgate) Seats wouldn't be hard to figure out. Measure the mounting holes.
JimTJr is offline
post #36 of 44 (permalink) Old 12-23-2009, 08:01 PM
that would be a nice way to step up the interior of my early 99
[SIGPIC][/SIGPIC]
post #37 of 44 (permalink) Old 12-24-2009, 12:39 AM
Originally Posted by powerlifter405 View Post
LOL... Your time...yep Your money...thats why i plan to win the lottery!
Where are you getting your numbers from??? The number fairy duh?!
You can get a complete forged rod short block for $3500, a complete long block for $4000... + a few hundred for shipping....Good set of hybrid injectors at least $2300, studs $700+, valve springs $800 and turbo $1800 for another 4k.... $5600 I guess my math is different than yours but thats ok! now another 4k for a tranny Plus a core charge for the auto I don't have.... and your done. That alone is closer to $11,000, not 8k for the tranny and motor add ons.....You have your 500hp and you dont have a bastard truck that will never run... Correct, for example a DI set up w/ 500 should be do-able, a little pricy but reliable and very do-able.
5k for a 6.4 (so you say...Yes I do say, bawhahaha) Yeah, thats right!!! I did my research and found a few. another 2-3k for a tranny (all of which are used) And?? and you have what? nothing... Now you need motor mounts, Tcase mounts, PCM/ECM... Wire harnesses. labor and time to wire the dash, lights, brake systems, OBD2 ports... I can get a complete wiring harness for a few hundred. What labor? I do things myself. You would be in it over 15k before you even got started... let alone any performance things.
I guess you missed this...
Anywho, thanks to rest ya'll for the input.
you wont a A/T well i got you one..10k on it ...sittin under my truck waitin on you M/T
early 99 f-250 315/75/16 3.5 inch fabtech shackle lift,intake,4" exhaust 5" single stacked,DIY t/c lock, billet t/c and shift kit on a fresh rebuild,beans tunes ,4 hella lights, 05 head light, 05 chrome grill,red wire pluged, HID lights 200k
other toys
2008 ltr450
2002 440ex
blandproud is offline
post #38 of 44 (permalink) Old 12-24-2009, 03:25 AM
boomboom's Avatar
99 to 07 use the same seat mounts, so the holes in the floor should be the same. I put 05 buckets in my 01 with no problem
boomboom is offline
post #39 of 44 (permalink) Old 12-25-2009, 12:39 PM
Ford Super Duty with Cummins Diesel Conversion, Forget the 6.0/6.4,to many issue's with EGR'S, EGR COOLER'S ,V V TURBO'S STICKING,head gasket's when you add power ect ,fix your 7.3 and keep the water out!!!! or go here, http://www.youtube.com/watch?v=r_smF-DSZuI
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 Sunnybrook 31bwks triple slide 5th wheel. , Total Gross 20900#.truck wt empty 7420# all at the scale, born 05/02/02. bought 06/18/02 & the wife's 2007 eddie bower expedtion 5.4,6 speed automatic ,power everything,redfire & tan.
poppie is offline
post #40 of 44 (permalink) Old 12-25-2009, 08:08 PM
losfinch's Avatar
Thanks guys...this thread has been great! I mean it. I just love this kind of bouncing back and forth..as funny as it sounds I imagine a bunch of little boys sitting around a school yard with their marbles (anybody remember those?) and having a great time psyching each other out as they brag about their special super-duty steel shooter, etc. Good clean fun...I don't care who wins. Its why I get on this site for few each day.
BTW and FWIW, NEVER take any of this all too serious...in reality we're talking hunks of metal that we won't care one bit about when we're gasping for our last breath on this earth.
Just sorry I can't find that little smiling face guy who is chomping popcorn as he watches the debate build. LOL
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny, 26 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Donaldson ELF7405 oil filter, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #41 of 44 (permalink) Old 12-25-2009, 10:12 PM
69mach1377's Avatar
Poppie,
Is it a requirment that when you do a cummins swap that the tires stick out too much also, just like other dodges? I mean, it's a straight 6 right? Shouldn't need to pop the wheels outboard...
post #42 of 44 (permalink) Old 12-26-2009, 08:32 AM
Originally Posted by 69mach1377 View Post
Poppie,
.............I have no idea???,my son out in Montana told me about a shop that does the swap,I'll have to call him and get the name again,I think it cost around $8000.00 out the door but don't quote me on that price,maybe i can get him to jump in here.
poppie is offline
post #43 of 44 (permalink) Old 12-26-2009, 10:37 AM
My Photos: (12)
Around 8K if you bring your own engine. This guy is a mile through the woods from me. http://www.fordcummins.com
11 F250 S/C 4x4 6.2 V8
94 F250 4x4 5.8 V8
01 Ford Ranger S/C 4x4 4.0 SOHC V6
92 Explorer Eddie Bauer 4x4 OHV
05 Expedition 4x4 5.4 3 valve.
Former trucks:
95 F350 CC PSD 5SPD Gear Vendors O/D 4x4
2003 F250 CC 4x4 6.0 HEADACHE! Traded before it blew!
89 F250 2wd 7.3 5spd with 256K when sold
94 F250 4X4 IDI Turbo 7.3 5 spd 160K when sold
95 F250 S/C 4x4 PSD 5 spd with 146K when sold
00 F250 C/C 4X4 PSD 6 Spd with 126K when sold (180K now)
mjstef is offline
post #44 of 44 (permalink) Old 12-26-2009, 03:37 PM
Thank's Matt,that's the info they need,btw,how come you never took me over to see that shop when we were out last summer.Dad.
poppie is offline
