I have a 2002 bone stock 7.3L with 210k miles. I want to put the following upgrades on it, do you have any advice?
Wicked wheel 2
4 inch turbo back exhaust, no muffler
6 position chip
3 a-pillar gauge set (egt, Trans temp, boost up to 35psi)
I also think my injectors are on the decline because in cold morning starts, the engine won't respond to the accelerator until it's warmed up. Immediately on start up, it will lope idle. I've read that this could be caused by worm poppet valve in the injector. Should I upgrade the injectors too?
Wicked wheel 2
6 position chip
