7.3L gas economy - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 10-29-2009, 07:39 AM   #1 (permalink)
7.3L gas economy
What is the best way to save gas if i were to get a F250.
Put a chip? If yes, Which one? and how much would i be saving? MPG ect..
What else can i do?
Diabloz is offline
Old 10-29-2009, 10:12 AM   #2 (permalink)
jroller's Avatar
Carry as little weight as possible and drive it like my grandma. An 80 econo tune on the freeway will help a little. I changed my uppipes and IPR sensor and I picked up a MPG or two that I had been missing all this time.
2001 PSD 7.3 auto DP Tuner, 4" TBE, KNN Intake (with filter charger), CCV Mod, DB Starter, Stancore GPR, ITP Overboost, John Wood installed valve body. External coolant filter. International Up Pipes.
1994 RAM 4x4 Cummins KNN, 3GSK, AFC Spring, #10 Plate, BD Valve Body, KDP, SCHWITZER S300 turbo 4" TBE.
jroller is offline
Old 10-29-2009, 10:48 AM   #3 (permalink)
7.3 PSD can pass all the gas pumps, but prefers good quality Diesel fuel. The driver is the most important for good fuel mileage. Driving, and weather conditions are a close second. An improved air intake like a Ford AIS, a less restrictive exhaust system, tire pressures, and a good econo tune can help, once the cost of the mods are recouped. Lift kits, and big rubbers definately hurt economy.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
Old 10-29-2009, 10:48 AM   #4 (permalink)
DHTD's Avatar
They do quite well on gas mileage because they dont take gas,LOL!
01' 7.3 4X4 DRK MTLC BLU, DP Tuner F5, AEM Intake, 4" Turboback Silverline Exhaust, BTS VB, AEM digital gauges(pyro, boost controller, trans temp), CCV mod, Rebuilt Injectors, Fuel tank Mods, 203T, 6.0 Trans Cooler, 185,000K and original tranny, so far so good.
DHTD is offline
Old 10-29-2009, 01:53 PM   #5 (permalink)
Sorry im kinda new to this lol, I understand the intake but what would you mean like an less restrictive exhaust system, and econo tune,where would i get this.
Diabloz is offline
Old 10-29-2009, 02:21 PM   #6 (permalink)
What are uppipes and IPR sensor?
Btw im trying to move it up to at least 20 MPG.
Diabloz is offline
Old 10-29-2009, 04:05 PM   #7 (permalink)
aklim's Avatar
You currently have a 3 or 3.25 in downpipe. The less restrictive exhaust system consist of the 4 in downpipe (largest you can fit in without SERIOUS modifications and a free flowing muffler.
The Econo tune is got from DP-Tuner as part of his lot of tunes. A tow tune has a softer shift since you don't want to jar everything you are towing whereas the econo tune has a faster shift and makes more power but is easier on gas than say an Aggressive 140
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 10-30-2009, 01:27 PM   #8 (permalink)
Where and how would i tell if its quality diesel?
Diabloz is offline
Old 10-30-2009, 01:48 PM   #9 (permalink)
aklim's Avatar
Usually, you want to avoid the Mom & Pop shops where the diesel sits in a tank for who knows how long. I try go to shops where they have truckers stop by often so the diesel is fresh. Also when you go to M&P shops, the prices are slower to react. So if it falls, they are still up there and if it rises, they are down there. Too much fluctuation for my liking.
aklim is offline
Old 10-30-2009, 04:15 PM   #10 (permalink)
Thank you, i understand about that now =)
Diabloz is offline
Old 10-31-2009, 07:19 AM   #11 (permalink)
Keep the tach under 2000. That is when my mpg drops.
2000 F350 7.3 SRW - BTS, Aux and V-10 trans cooler, coolant filter, fuel filler, line, and tank mods, Dahl 100 fuel filter, MagHytec diff cover, A-pillar 3 gages, WD exh brake, and other stuff.
WB7E is offline
Old 10-31-2009, 08:49 AM   #12 (permalink)
fxdwgi's Avatar
18-19 mpg on my truck @ 70-75 mph.
It only took $5000 to get it there.......
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 10-31-2009, 09:00 AM   #13 (permalink)
20 - 21.8 mpg (hand calculated), 5- - 55 mph, cruise on, unloaded, 265 tires, not lifted, tire pressures 50 in front, 60 in rears, no jack rabbit starts, coast up to stop signs, red lights.
Hopes this helps,
Butch Cassidy1
2000 F250, 2WD, XLT - A HAULING AND TOWING WORKHORSE.
butchcassidy1 is offline
Old 11-02-2009, 04:30 PM   #14 (permalink)
fxdwgi claims the above #’s driving a ’01 F350 4x4 Crew Cab on 315/75 (35” tires) and a 4” lift. (According to his signature)
Big heavy truck, 4 Wheel Drive, High speeds, Lifted, Big tires and Great MPG’s??
That was a well spent $5k. Your pushing me to the edge of what I’m willing to believe. Of course this is posted on the internet so it must be true and accurate. Were you climbing a 7% grade against a 20mph wind as well? I'm mostly just joking around. If that is accurate then I am definately interested in the mods you have in your truck!
The very next post is the exact opposite:
Butchcassidy1 claims the above #’s driving a stock (according to sig) 2wd (assuming reg cab).
Relatively small, No lift, Stock tires, Slower than Grandpa on a Sunday afternoon and only a 1-2 mph difference from fxdwgi.
These two claims don't seem to be consistant unless the mods fxdwgi has really do make that much of a difference. From what I've read on these forums, the tuning doesn't make that much of a difference but I have heard good things about Transmission / torque converter upgrades. Any other similar experiences?
Both these guys are getting way better mpg's than me so I AM jealous! Maybe I can combine fxdwgi's mods with butchcassidy1's driving style and have a sweet truck that gets 30 mpg?
Michael
'00 7.3 4x4 eXcursion 67K Miles - 2000+ Miles on WATF
Mine since 07/02/09 at 53.5K Miles - Autometer Gauges (EGT, Trans Temp, Boost, Air Pres.) - AIS (Ford Severe Duty) - BFG AT Tires (285/75 R16 BFG AT Load range 'E') - Harpoon Mod - ITP 7.3L Fuel Tank / Pre-Pump Kit (aka Hutch Mod) - On Board Air (Extreme Aire w/ 11 Gal. Tank) - Diamond Eye 4” Turbo Back Exhaust - 6.0 Trans Cooler - 2009 Side Mirrors - Modified B Codes - 30mm Rear Sway Bar - DPTuner F5 (Stock, Hi Idle, 60 Tow, 80 Econ, 120) - 203*Therm - DIY Coolant filter - ELC Coolant - Cryo powerslots & Hawk pads all around - SS Brake lines - AIH Delete.
bnjmnalan is offline
Old 11-02-2009, 06:14 PM   #15 (permalink)
fxdwgi's Avatar
Oh, I forgot to add that the 18-19 mpg @ 70-75 mph is on 120R setting with my tires @53 psi. I actually got .5 mpg LESS using the 80 E setting (calculated over a 3 week period alternating every tank with every setting) I have this calculated 5 ways of Sunday via a program called Roadtrip. Now my brother who has the identical truck and identical mods but without the lift, get 19- 20.5 mpg (he is on here also).
I have found that the mpg improvements were incremental to mods and not one mod was a mileage silver bullett. Take into consideration the Boostmaster; I have gained about .8 MPG just with that.
But the biggest reason we get good mileage is that we are all over our trucks on maintenance and repairs. Do you have any idea on the mpg loss of just having a brake pad clip not seated correctly and the pad resting on the rotor ? Or having a U-joint not fully lubed ? I don't have any idea what the MPG cost of those items are, and I never will.
Rotating mass takes power to turn, the harder it is to turn the more power it takes.
Here is another out of this world claim for you to chew on; I also have a 2000 Grand Marquis that gets 26-28 mpg all day long at 75-80 mph.
fxdwgi is offline
