Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-02-2009, 07:24 PM   #16 (permalink)
"Take into consideration the Boostmaster; I have gained about .8 MPG just with that. " Do you mean "Turbomaster?" Just checking.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, custom bed carpet/bench inserts, Rhino grill guard, Bugshield,((XM)), mud flaps, CCV Mod, AIS w/foam sleeve, Fuel filler mod, GOS headlight harness, Hella 80/100s, 02-04 Headlight upgrade, Rancho HD steering stabilizer, C-Btr Mirrors, DIY fixed door lock motors, Hella FF1000 driving lights, DIY Mirror LEDS, Sonnax/Tricumulator upgrade, Htr Bypass valve, 31 row 6.0 tranny cooler,front receiver hitch, Quadzilla Recon XZT gauges, DIY "slo-thru" heads (aka Cackle Cure), ITP Pre-pump/In-tank mods, Pioneer P5000UB, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DTRS and BPP kill switches, DIY "pitstop" switch.
http://community.webshots.com/user/l...host=community
losfinch is offline
Old 11-02-2009, 07:32 PM   #17 (permalink)
fxdwgi's Avatar
Yep....thanks.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Front Bull Bar w/ K.C. Daylighters * Draw Tite Fold Over Gooseneck * Gauges whited out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM *
Sitting in garage waiting to install: 6.0 IC
The REAL toy....
http://community.webshots.com/album/561972003NGydsT
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 11-03-2009, 01:49 PM   #18 (permalink)
But the biggest reason we get good mileage is that we are all over our trucks on maintenance and repairs. Do you have any idea on the mpg loss of just having a brake pad clip not seated correctly and the pad resting on the rotor ? Or having a U-joint not fully lubed ? I don't have any idea what the MPG cost of those items are, and I never will.
Thanks for the replies! For the 4 months I've owned this truck the best I've seen is 16.5 mph average highway driving. So I would definately like to find a way to increase that just like the O.P.
I am going to tear into the front end within the next two weeks to repair a leaking inner seal and hopefully I will also find and resolve some of mpg robbing maintainance problems as I inspect the bearings, u-joints and braking system. After that I'm hoping a 4" exhaust will add a bit to increase fuel economy.
Michael
2000 7.3 4x4 eXcursion 56K Miles
Mine since July 2, 2009 at 53.5K Miles
Autometer Gauges (EGT, Trans Temp, Boost, Air Pres.) -- AIS (Severe Duty) -- BFG AT Tires (285/75 R16 BFG AT Load range 'E') -- Harpoon Mod -- ITP 7.3L Fuel Tank / Pre-Pump Kit (aka Hutch Mod) -- Boost Fooler -- On Board Air (Extreme Aire w/ 11 Gal. Tank)
bnjmnalan is offline
