7.3L Turbo rebuild instructions - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-19-2008, 10:31 PM Thread Starter
Here is a turbo rebuild write up that I made. Hope I help some guys out. It was very easy. You should have no problems following the pictures and direstions I wrote. PM me if you should have any questions while attempting this task.
Turbo Rebuild - a photoset on Flickr
Early 99 F-350 DRW Lariat
Turbo Rebuild with Beans 1.0 Ex. Housing and WW.
DIY Intake, Ram Air Hood, Clear Markers, 4" Turbo Back SS Exhaust, Stewart Warner White Face Gauges, White Face Instrument Gauges, 6 Position TW Chip, 2008 Superduty Center Console, 2 1/2" Leveling Shackles
xsracinggt is offline
post #2 of 8 (permalink) Old 02-19-2008, 11:11 PM
Excellent!
Ironhide is offline
post #3 of 8 (permalink) Old 02-19-2008, 11:29 PM Thread Starter
Thanks man! really appreciate it!
post #4 of 8 (permalink) Old 02-20-2008, 08:37 AM
nice write up!
choose a good year too
early 99 f350 4x4 crew cab
work in progress
southmike is offline
post #5 of 8 (permalink) Old 07-07-2011, 09:44 PM
very helpful
2001 candy apple Red F350 XLT 7.3 Ext. cab 8FT bed 2.5 inch leveling kit 35 pro comp extreme a/t, glow shift gauges, AFE Stage II cold air intake, Whicked Wheel, full 5 inch mbrp straight piped
2007 White F350 XLT 6.0 Crew Cab 8FT bed - stock
Huntor is offline
post #6 of 8 (permalink) Old 07-09-2011, 01:33 PM
If I were a betting man, I'd bet the OP's turbo didn't last after that rebuild.
Kirk R is offline
post #7 of 8 (permalink) Old 07-09-2011, 02:04 PM
klhansen's Avatar
My Photos: (180)
How about sharing why you say that. What specifically do you think he did wrong?
), AIS,
regulated return,
klhansen is offline
post #8 of 8 (permalink) Old 07-10-2011, 08:42 AM
The OP's turbo was damaged beyond what a simple repair kit would fix and he is completely doing it the wrong way. The damage was not assessed properly which is key to repairing a turbocharger.
NEVER shove a screw driver into your turbine wheel. All of the steps he posted are great if you want to bend the shaft on your turbo and end up with a much worse situation than you started with. Let a lone not balancing the rotating assembly prior to assembly.
I use a special fixture for the GTP38 to hold the turbine and a T handle on the compressor wheel to keep from bending the shaft. NEVER use power tools on the rotating assembly.
The following is the turbine wheel from the OPs rebuild pictures, look at how much material was removed from the face of the turbine wheel. It would not surprise me if the seal bore on the bearing housing was also worn (a new seal will not fix this) -
This is what the GTP38 turbine wheel is supposed to look like -
The repair instructions are completely inaccurate and could lead to others possibly damaging their turbochargers more than they already are.
Let alone forgetting the the importance of balancing the rotating assembly!
Kirk R is offline
