Aeromotive fuel pressure regulator - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 06-04-2006, 01:01 AM Thread Starter
clamgulch's Avatar
Anybody using this one: http://cgi.ebay.com/ebaymotors/ws/eB...wItem&rd=1,1&item=8064713537&sspagename=STRK%3AMEWA% 3AIT
Thanks-
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
post #2 of 12 (permalink) Old 06-04-2006, 01:16 AM
GSXRTURBOQUAD's Avatar
Re: Aeromotive fuel pressure regulator
Didn't work for me. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Precision Hybrid from BWD), Industrial Injection BD Injectors, DIIC with custom stainless 3" piping, Terminator HPOS, DI headstuds, BTS tranny, TruCool 40GVW cooler, DP LIVE TUNED F5 with Extreme ICP(ya, it works)!, Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be shortened.
97 F350 Regcab4X4: Twin Turbo's, lots of fuel and oil.
02 Excursion4X4Limited: Wifes ride: Terminator HPOS2, DP Tuner F5
SDRCM #7
GSXRTURBOQUAD is offline
post #3 of 12 (permalink) Old 06-04-2006, 02:07 AM Thread Starter
clamgulch's Avatar
Why not?
post #4 of 12 (permalink) Old 06-04-2006, 02:08 AM
Oh, sorry. I meant the link didn't work for me. [img]/ubbthreads/images/graemlins/frown.gif[/img]
SDRCM #7
post #5 of 12 (permalink) Old 06-04-2006, 02:13 AM
Auction gone. Someone use the Buy it Now?
I have been using an Aeromotive regulator for 4 years now. Forget the model number. Supposed to be good for 100psi.
2000 F250SD SCLB Lariat 4x4
450 cubes, fully studded, modified.
4R100 built by me with Suncoast/Transgo/Sonnax/Ford parts.
325/65/18 BFG A/Ts on Ultra rims, custom 4" lift with rear shackle flip(no blocks), Rancho 9000Xs, Homemade bypass fuel system, bypass oil filter, Racor CCV filter, 3.5/4/5 custom exhaust, 8 yr old DI 4 pos chip, and some other stuff.
22 year US Navy vet (retired)
ASE Master Auto Tech
stangrcr1 is offline
post #6 of 12 (permalink) Old 06-04-2006, 12:15 PM Thread Starter
clamgulch's Avatar
Sorry, that link isn't working. Try this new link which seems to be ok. If it doesn't work, search "Aeromotive billet adjustable EFI Bypass Regulator"
http://cgi.ebay.com/ebaymotors/AEROMOTIV...1QQcmdZViewItem
The thing that impresses me is the number and size of the ports, which means being able to feed both heads equal volume and pressure without buying a splitter, which creates more entrained air problems, and I also like the fact that it is designed for a pressure range of 40 to 100 psi. I contacted the seller but he didn't have a clue about diesels.
I'm aware that there are cheaper Aeromotive units available, but cheap isn't always best.
Please let me know what you think-
Thanks-
post #7 of 12 (permalink) Old 06-04-2006, 12:20 PM
Yup, that link works. Looks like a nice regulator. Should be fine. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
SDRCM #7
post #8 of 12 (permalink) Old 06-04-2006, 03:26 PM
NEVRNF's Avatar
the regulator is after the head but before the return to the tank. Would not make a difference if it has 1 or 10 holes. It is after the fact. [img]/ubbthreads/images/graemlins/confused.gif[/img]
Tony
01 F350 cc 7.3 with Lots of Xtras
99 F250 xcab 7.3
91 mustang 351 turbo roadracer
NEVRNF is offline
post #9 of 12 (permalink) Old 06-04-2006, 03:37 PM
The regulator can go before the heads, the factory regulator is before the heads. He can put it anywhere he wants. Looks like a good regulator Clam.
As far as getting any air out, just put some small bleed lines off the other end of the heads with .015 restrictors. Like mine.
post #10 of 12 (permalink) Old 06-04-2006, 03:53 PM
Why would you want to regulate the pressure BEFORE the heads ?
...coming soon...
2004 Twin Turbo 5.9 F250
Hellmann Performance
Direct Injection Performance
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
UNBROKEN is offline
post #11 of 12 (permalink) Old 06-04-2006, 10:56 PM
The factory system is regulated before the heads but the fuel also is dead headed there. When you change over to a circulating system you will need to put the regulator after the heads. As for the areomotive regulator and there pumps for that matter, the pressure rating is to low for my likeing. Mallory is marketing a regulator that is rated to adjust up to 100psi.
Courage is not the absence of fear but being afraid and moving forward anyway.
kiarasue is offline
post #12 of 12 (permalink) Old 06-04-2006, 11:06 PM
I've talked to Aeromotive, and this is how the reccomend doing it, although I don't agree. They claim that with the small inlet for fuel in the heads, it creates a restriction and the fuel pump will work much harder. The claim that the fuel pressure difference in the lines before the heads and at the regulator (if after the heads) is quite large. I was told by them that if you set the regulator at 65-70 psi, the pressure before the heads is up around 90 psi.
My observations have been no where near that. I have a fuel pressure gauge on the regulator, and another one in the splitter before the heads. There is a difference of about 2 psi, when I'm running 65 psi set on my regulator. This is with the stock fuel bowl gone, using a Y-block to split the fuel to each head. When I had the stock fuel bowl, the pressure in the fuel bowl was about 4-5psi higher than what was at the regulator, running 65 psi at the heads. The fuel bowl was a bit of a restriction there. But, no where near the psi difference that Aeromotive is leading you to believe.
jtharvey is offline
