Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-24-2008, 09:04 PM   #1 (permalink)
Aftermarket fuel pumps
i've been looking into getting an aftermarket fuel pump for my sig truck anybody have any suggestions. I don't want to spend more than $400 but yet get something with just a little bit more punch than the stock one that i am sure is on its last leg now with almost 150,000 miles
2000 Ford F-250 (4x2) XLT extended cab long bed, TS Performance 6 pos. Chip (Stock, High Idle, 50, 75, 100, 140 extreme), Turbo Master Wastegate Controller, ATS Housing, AEM Brute Force dry filter, MBRP Stainless Trubo Back exhaust 4in., Gauges (EGT, Air Tank P.S.I, Boost), High Pressure Oil Crossover, 60gal. aux. tank/toolbox combo, bedliner, Uniden CB w/ 15 watt PA, ViaAir air compressor and 1.5 gal tank, train horn, Pioneer head unit w/ jensen speakers, after market stock ford running lights, 33in. Nitto tires
hitcb1789 is offline
Old 11-25-2008, 07:03 PM   #2 (permalink)
What is wrong with your pump? I don't see the need for a high flow pump from what is in your sig. A high flow pump is not a performance upgrade in and of itself, it a supporting mod to large injectors.
My Truck: Early '99 F350 CC LWB 4X4
Annoy A Liberal
Work Hard, Succeed, Live Happy!
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
Old 11-25-2008, 10:41 PM   #3 (permalink)
Spend the time about $200 and get a Bosch electric and be done with it. Much easier to change out if you mount it under the frame. I know there will be filters, fittings and hoses, but you will be happy in the long run. They last much longer than the Aeromotive and half the price.
Dann
My Mods http://community.webshots.com/user/sconure
1996 E-350 , Bean's stage 2 injectors, 3" intake plenums, dual EGT gauge, boost, tranny, fuel pressure gauges.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 11-25-2008, 11:05 PM   #4 (permalink)
Dann
That is not always the case. There are plenty of Bosch 044 pumps that die and they are not diesel rated so they are not warrantied.
For the mods in the OP's sig, the stock pump is the most reliable pump he can run. Again I ask, why do you think you need a HP pump?
Annoy A Liberal
Old 11-26-2008, 10:36 AM   #5 (permalink)
ITPDiesel's Avatar
Send a message via ICQ to ITPDiesel Send a message via AIM to ITPDiesel Send a message via MSN to ITPDiesel Send a message via Yahoo to ITPDiesel
I'm with SE99 on this one, I don't see a "need" for a bigger fuel pump with his setup. The stock pump is a Bosch unit and is VERY reliable. I frequently recommend that customers just buy another Factory Pump (diesel rated, built specifically for Ford by Bosch) from the Ford Dealership and put it in for years of reliable service.
The only time I recommend an aftermarket pump is when there are modifications that are exceeding the flow capabilities of the stock unit.
Dennis Schroeder - President - ITP Diesel, L.L.C.
ITP Website: www.itpdiesel.com
ITP E-Mail: sales@itpdiesel.com
Telephone: 623-582-4404
We're On MySpace Too!
ARIZONA POWERSTROKE GROUP
ITPDiesel is offline
Old 12-01-2008, 12:29 AM   #6 (permalink)
ok thanks guys im gonna go with the ford factory fuel pump anyone have any gueses to the what the price tag will be on it?
Old 12-01-2008, 12:37 AM   #7 (permalink)
could the stock pump handle 75hp injectors?
Old 12-01-2008, 07:05 AM   #8 (permalink)
JimTJr's Avatar
My Photos: (6)
The stock pump probably can, especially if you put on a regulated return system. (Also a stock pump is gonna cost you in the neighborhood of 300.00 from FORD!)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 6pos chip, AC Stage 1 sticks, 4" Turbo back straight pipe/stainless 5" tip 131st B/W MoAirNatlGuard B-2 BOMBERS at WHITMAN AFB, Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 12-01-2008, 08:25 AM   #9 (permalink)
I am starting to have problems with my stock pump. I just bought an air dog unit. This the FS100 model. I have not installed it as of yet. I should of asked on here first and just got the factory replacement.
Be Safe
THE DAWG
2001 F350 CC LARIET LWB 3.73LS SRW 4X4,ARE CAP WITH FULL REAR DOOR, SOFTRIDE 4 INCH WITH RS9000'S ,MAG HYTEC REAR END COVER AND TRANS PAN,GULF COAST FILTER,AMSOIL THRU OUT,BANKS EXHAUST,TS CHIP,AFE STAGE 2,TRIPLE A PILLAR W/PHANTOM GAUGES,BTS TRANNIE AND BOBS REMOTE FILTER,6.0 TRANS COOLER,WELD VELOCITY 8'S W/ NITTO 325X18'S,KENWOOD 850 WATT SYSTEM W/CHANGER AND SIRIUS RECIEVER,POWER SLIDER,
2006 F350 CHASSIS SRW WITH WALK-IN SERVICE BODY, XLT,KENWOOD STEREO, QUADZILLIA, AFE, 5 INCH EXHAUST
2006 F350 CC Dually 4x2 SCT-2 W INOVATIVE CUSTOM TUNES, AFE, MBRP 5 inch stainless W/ SEWER PIPE TIP. RECON LED's TRIPLE A PILLAR W/ PHANTOM GAUGES
SUPER WONDER DAWG is offline
Old 12-01-2008, 04:35 PM   #10 (permalink)
Keep in mind the airdog is a HIGH VOLUME / LOW PRESSURE fuel supply (10-20psi). You still need a pump to bring it up to 55+ psi fo fuel pressure.
Annoy A Liberal
