AIH code - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-15-2005, 09:20 PM   #1 (permalink)
blowhard's Avatar
AIH code
Howdy. I'm fixin'to remove the air intake heater from my '02 PSD and if that is done on an '02, my understanding is that it will set a code. Someone on this forum described in detail how to prevent this from happening by connecting a 470 ohm resistor into the wiring. I printed that and saved it for later (which is now) and now I can't find what I printed. Can't come up with any discussion of code prevention with a search. Can anyone out there help me? I'd sure appreciate it.
'02 F-250 7.3 PSD. Toreador Red, Lariat long bed, 4-R100 trans, 4" turbo back exhaust, Pyro in both exhaust manifolds, X-Monitor, SuperChips 1705 Tuner, Mag-Hytec transmission pan & Diff cover.
blowhard is offline
Old 05-15-2005, 10:00 PM   #2 (permalink)
Re: AIH code
You can buy one at Black Cloud.
[img]/ubbthreads/images/graemlins/cool.gif[/img] "GO<font color="purple"> LAKERS</font>,<font color="red"> ANGELS</font>, STEELERS !!" [img]/ubbthreads/images/graemlins/cool.gif[/img]
<font color="brown"><font color="#666666">2002 LIMITED ULTIMATE 4X4, 7.3 PSD, MINERAL GREY</font> </font>, Putco Grill w/vent inserts, AIS, Banks Monster 4" Turbo Back, Bilsteins, Hellwig, AIH Plug + Code Eliminator, 203 T-stat, Coolant Filter, Fuel Bowl Drain Mod, BVR+/WW in the box still, FPR @ 65-68psi, Gauges: Pyro, Boost, Trans., A LITTLE help from Jody, BTS Valve Body.
<font color="blue">MY Local Service Dept.--&gt; [img]/ubbthreads/images/graemlins/tongue.gif[/img] + [img]/ubbthreads/images/graemlins/confused.gif[/img] + [img]/ubbthreads/images/graemlins/crazy.gif[/img] = Me--&gt;</font> [img]/ubbthreads/images/graemlins/mad.gif[/img]
<font color="purple">TRUCK PICS.</font>
ForumBlue is offline
Old 05-15-2005, 11:10 PM   #3 (permalink)
Re: AIH code
i got rid of my AIH never had a problem. i would try disconnecting it first. if it throws a code then look into the alternatives if it dont then thats just one less thing you have to buy.
2001 F-350 7.3 liter AKA HBD. hillbilly deluxe
PSD 6 SPEED HANDSHAKER. crewcab,long bed
highly modified &lt;img src="/ubbthreads/images/graemlins/tongue.gif" alt="" /&gt;
heres a few things
lifted
530 hybrids DS &lt;img src="/ubbthreads/images/graemlins/smokin.gif" alt="" /&gt;
complete big fuel system CPR+ extreme
hoosier quick time pro slicks
luk ceramic clutch
head studs ARP
newer model hpop
1.15 ar exh. housing
dp tuner stock,tow,120,and 140 [/color][/b]
fumoto oil drain valve NEW MOTOR BIGGER,BETTER 4" down pipe with 4" pipe back to 6" chrome stackhttp://mysite.verizon.net/res85g9n/id11.html
[color:"black"]15.7@93.6 MPH 1/4 mile [/color]http://media.putfile.com/157-run
slydiesel is offline
Old 05-15-2005, 11:30 PM   #4 (permalink)
blowhard's Avatar
Re: AIH code
Thanks, guys. I'll disconnect it and see what happens. A code from a faulty AIH shouldn't make any operational difference anyhow.
blowhard is offline
Old 05-16-2005, 07:50 AM   #5 (permalink)
Re: AIH code
You can get the AIH plug and P0541 Code eliminator from here
The code doesnot hurt anything, but will be set and stored in your PCM. Its just annoying, and if you are still within warranty you do not want to give them a reason to void it....
wildbill1963 is offline
