AIH Delete?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 04-21-2005, 05:55 PM   #1 (permalink)
AIH Delete??
Why should I do this?
What are the Pros and Cons?
How do I plug the hole it would leave?
[img]/ubbthreads/images/graemlins/cool.gif[/img] "GO<font color="purple"> LAKERS</font>,<font color="red"> ANGELS</font>, STEELERS !!" [img]/ubbthreads/images/graemlins/cool.gif[/img]
<font color="brown"><font color="#666666">2002 LIMITED ULTIMATE 4X4, 7.3 PSD, MINERAL GREY</font> </font>, Putco Grill w/vent inserts, AIS, Banks Monster 4" Turbo Back, Bilsteins, Hellwig, AIH Plug + Code Eliminator, 203 T-stat, Coolant Filter, Fuel Bowl Drain Mod, BVR+/WW in the box still, FPR @ 65-68psi, Gauges: Pyro, Boost, Trans., A LITTLE help from Jody, BTS Valve Body.
<font color="blue">MY Local Service Dept.--&gt; [img]/ubbthreads/images/graemlins/tongue.gif[/img] + [img]/ubbthreads/images/graemlins/confused.gif[/img] + [img]/ubbthreads/images/graemlins/crazy.gif[/img] = Me--&gt;</font> [img]/ubbthreads/images/graemlins/mad.gif[/img]
<font color="purple">TRUCK PICS.</font>
ForumBlue is offline
Old 04-21-2005, 06:23 PM   #2 (permalink)
My Photos: (11)
Re: AIH Delete??
To get <font color="red"> THIS</font> out of your intake track, that heating coil is fairly large and long.
See above and the only con I know of is that you might smoke a little more when it's cold out.
<font color="red"> THIS ALBUM </font> has some fairly good pics from our Jan 05 NOVAPS meeting. You can buy a plug from Bob Riley <font color="red"> HERE</font> which is what I used or either a straight plug or a combo plug and boost gauge tie in from BCD <font color="red"> HERE</font>.
Larry, keeper of the <font color="red"> New revised </font><font color="blue">"little secrets" </font> CLICK HERE [img]/ubbthreads/images/graemlins/smile.gif[/img]
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 04-21-2005, 06:29 PM   #3 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
Re: AIH Delete??
Better airflow...it protrudes into your intake and takes up about 20% of the space there, you don't really need it, it is easy to do (took me 5 minutes), you can by a plug that screws right in from many of the sponsors on this site. I bought a regular plug ($9 shipped I believe) from blackclouddiesel...then when I installed my gauges I bought another one from them that had a built-in boost gauge tap where I tapped for my gauge. It screwed right in also. Piece of cake mod. Better airflow can mean better efficiency/fuel mileage even though it may be very slight with this mod it was worth it to me [img]/ubbthreads/images/graemlins/smokin.gif[/img] Cons..??????? [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]...your hands might get dirty [img]/ubbthreads/images/graemlins/shrug.gif[/img]
*SOLD - 2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day including towing),Cryo treated Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Harley much cheaper on fuel! Joined the other side with a 2004 2500 HD CC SB GMC Duramax...got a great deal!!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 04-21-2005, 06:39 PM   #4 (permalink)
rdvit94's Avatar
Re: AIH Delete??
The mod allows air to flow through the intercooler more freely. I noticed some improvement in throttle response. Two down sides, if you let your truck idle in the cold weather for long periods of time this mod might be isses. If not don't worry about. Second, when you disconnect the AIH from the seleniod your truck's computer might through a code. Not all trucks do this, but mine does. It's not a big deal, the code doesn't effect the truck.
2001 F-350 XLT, CC, LWB, 4x4, Auto, Off-Road, DP-Tuner (stock-40-80-120), SP Diesel Air Intake, MBRP 4" Exhaust, Banks BHA, TAG, Dieselsite BRV, AIH Mod, 203 Stat, Sonnax/Tri Kit, Tank Mods, Redhead Steering Gear, DB Electric Starter, Di Pricol Gauges in A-Pillar, 3.5" Custom Lift, 315/75/16 BFG ATs, Delta Toolbox
Truck Pics
rdvit94 is offline
Old 04-21-2005, 08:02 PM   #5 (permalink)
Send a message via AIM to Bobcat698
Re: AIH Delete??
We've actually developed a code eliminator for those using the AIH plugs.
Check them out here
PURE DIESEL POWER
TS Performance chips, SCT, Edge Products, AFE, Superchips, Diablo, Autometer & Dipricol Gauges, Turbo Air Guides, MBRP & Magnaflow Exhaust, Aeroturbine, ATS, Hypertech, Steroid & 18K modules, South Bend Clutches & more!
Get STACKED with a 4,5,6, or 7 Inch STACK kit!
Call us for your exhaust pipe needs!
Superior Customer Service, FAST Shipping!
Garrett Shields
OWNER
715-498-0707 Call ANYTIME!
www.PUREDIESELPOWER.com
New Rig: 1998 Dodge 2500 Club Cab 12V Cummins, Black, 600+RWHP
Bobcat698 is offline
Old 04-21-2005, 11:50 PM   #6 (permalink)
Kanman's Avatar
Re: AIH Delete??
Black Cloud, you guys are bring to modest. That plug/boost gauge fitting for the AIH delete is a really sweet mod that works very well.
I guess your code eliminator works too, cause my truck has never thrown the code [img]/ubbthreads/images/graemlins/cool.gif[/img]
Kanman is offline
Old 04-22-2005, 10:56 AM   #7 (permalink)
Re: AIH Delete??
I have never had a code either. I wish I had got the one with the built in boost connection now that I got guages, guess Ill have to just use the t line. Once you see the size of that thing you realize how much air it does block. I have pictures on my site of it, link is in my signature.
My Web Site
2001 Excursion XLT 4x4 7.3 PSD - 305/70-16 Bridgestone Dualler AT's - Walker BTM - 6637 intake - AIH delete - boost relief valve - Sonnax/Tricumulator - ISSPro EV Guages - Super Duty Grille - 203* Thermostat - Coolant filter - TS 6 Position
bigdaddyTank is offline
Old 04-22-2005, 12:48 PM   #8 (permalink)
Re: AIH Delete??
This is only on 99.5s and up right? I have an early 99, so I don't have this, nor do I need to worry about it correct? For a boost gauge, I'll just need to tie into the MAP line or whatever then right? Thanks!! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Early 99 Ford F-250 7.3L PSD XLT, SC, LB, Auto
AFE Stage 2 w/ Pro Guard 7
MBRP 4" Turbo Back Exhaust
Edge Evolution on 80 hp/145 ft. lbs.
Autometer Ultralite Gauges: Pyro, Boost and Tranny
Sonnax/Tricumulator in stock tranny
Amsoil in entire drivetrain
Delta Toolbox
Running boards with custom lights
Ready to Rock!!!
COPowerstroke is offline
Old 04-22-2005, 01:18 PM   #9 (permalink)
Re: AIH Delete??
THANKS FOR THE INFO EVERYONE. I ORDERED THE PLUG AND CODE ELIMINATOR FROM BLACK CLOUD. WHEN I GET MY GUAGUES I WILL PROBABLY GET THE PLUG WITH THE BOOST INSERT.
THANKS AGAIN.
Old 04-22-2005, 02:52 PM   #10 (permalink)
Re: AIH Delete??
Correct.
wildbill1963 is offline
Old 04-22-2005, 03:29 PM   #11 (permalink)
yobuda's Avatar
Re: AIH Delete??
Are there any issues with just cutting the plug off and leaving the wires connected?
'02 350 CC SB
4" Turbo back exhaust / Adrenaline HPOP / Air Bags with in-cab Controller / Airdog with Regulated Return / AIS / ATS Ported Housing / CCV / Coolant Filter / Exhaust brake - SP Diesel w/TC Lockup / Gauges - Boost, Tranny, EGT, Fuel Pressure / HX crossover / Hutch-Harpoon / John Wood Tranny and 6.0 Cooler/ IDM mod / OilGuard / Onboard Air - VIAR 450C with 10 gallons & Air Horns / Rancho 9000XL with in-cab Controller /Stancor GPR / TurboMaster Wastegate
yobuda is offline
Old 04-22-2005, 03:48 PM   #12 (permalink)
Scottz's Avatar
Re: AIH Delete??
For those that would like to make their own AIH plug with a boost fitting, here is how I did it.
Parts needed (less than $5 total):
Parts
22 x 1.5 metric plug (fastener shop, about $2.50)
1/8 close nipple (Lowes $.90)
1/8 female pipe coupling (Lowes $1.30)
1/8 fitting that came with your boost gauge (priceless)
Drill and tap the plug for the 1/8" nipple, assemble and install. That easy.
Assembled part
Installed Part
2000 F350 7.3, Auto, Lariat. John Wood transmission, Airdog, ITP reg return, AC single shot injectors, DP Tuner, live tuned.
2005 F350 6.0 work truck
2007 Forest River Wildcat 29RLBS
Scottz is offline
Old 04-22-2005, 04:22 PM   #13 (permalink)
Scottz's Avatar
Re: AIH Delete??
PS: I removed my AIH, not so much because it was a restriction, but because I needed a handy place to plumb my boost gauge into after installing a relief valve in my MAP line. But, after looking at it, I'm glad it's out.
Scottz is offline
Old 04-22-2005, 08:47 PM   #14 (permalink)
Re: AIH Delete??
I just ordered the plug and code eliminator all so from black cloud. hope to have them by next weekend. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2000 F350 7.3 cc srw swb 4x4. afe 2,banks transcomand,bd bypass tube eliminater,edge juice&attitude monitor,boost tube,ccv mod,leveling kit,4'turbo back,Aih delete,code eliminater.coolant filter.ebps code eliminater,gold coolant.ats housing,wicked wheel,gutted ebpv.
powerpit is offline
Old 04-23-2005, 03:29 PM   #15 (permalink)
Scottz's Avatar
Re: AIH Delete??
I just used a 10w 470ohm resister as a code eliminater (electrically replaced the heater element). Since I don't have a code reader, have no idea if it worked, but didn't hurt.
Scottz is offline
