Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Remove intake,pull green line from intake tube,,Remove CAC boots(top)(7/16), unplug AIT in spyder, disconnect AIH, Disconnect map line at bottom of spyder,loosen plenum boots at bottom of spyder(5/16), remove Vband calmp holding spyder to turbo(5/16),disconnect red line to wastegate, remove vband clamp on collector at rear of turbo(7/16), remove vband clamp from flange to downpipe(7/16), remove two 13mm bolts securing turbo to pedistal, the turbo is heavy, and will be stuck to the pedistal, a little wiggling will get it out.
1999(05-99)truck, engine (3-99), F-250SD CC SB 4x4, DP Tuner,1.15 van turbo with ATS housing,6.0 IC, ISSPRO guages, AFE big boost filter, Zoodad, SS HPXOVER ,dualCCV, FASS Fuel system,fuel bowl delete, custom turbo back 4" straight pipe split and out the back with dual 5" slash cut tips under the bumper, 305-70-16 Hankook DynaproMT mudders, 02 headlights,lots of electronics, 263,000 + miles
These are instructions for installing a GTP38R turbo, but it does have nice directions and pictures for you to refer to when removing and re-installing your turbo. http://www.dieselinnovations.com/tec...structions.pdf
Thanks for the write up! I'm getting ready to change my pedestal O-rings b/c there's a massive leak from under the turbo. I think they've been giving way for a while and that's where my oil in the intake valley was coming from. But now it's REALLY coming out.
Thanks again, the pics will make the job much easier!
2000 F-250 7.3L PSD, 6-Speed, 145.5K+ mi, 4-Puck button clutch, TS Perf. 6pos Chip, Western Diesel~Ram Air, Gauges {Boost & Pyro}, AFE Stage 1, 4" Turbo back exhaust, ITP Over-Boost Eliminator, Cyclone Fan Controller, 4" Lift, BF Goodrich A/T 35x12.50x16.5, Eagle Alloy Rims, GoRhino Brush Guard, etc. Check it out here~ Cardomain mod list & pics
that is the one I was thinking about...
I can never find di's installs now.
I either have the old link or the new one wrong...shruggs
early 99 f350 4x4 crew cab
work in progress
