Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
I can't find any info about whether you can still use the EBPV as an exhaust brake with the ATS compressor housing? Anyone know?
TIA
Kirk
2001 F-350 4x4 7.3L DRW 6 speed 4.10
Flatbed work truck weighing in at 9000 lbs
Stock intake, exhaust, and powertrain but not for long
2000 f250 4x4 lariate woodland green metalic and gold on the bottom.sharp looking super cab.100,000 miles .air heater mod,CCV mod,zoodad,80 econo DP tuner PCM ,cranked doun stock waste gate,cubie hole type gauge pod,k@n replacement filter.sonax/tricumulator, map sensor pop off valve,boost tube,BTM ,code eliminators ,wiked wheel,EBPV deleat ,hp oil cross over feul presure shimed and gauge, Heater core hose bypass valve .Wet Okole seat covers with Powerstroke logo ,.home made donaldson intake in the works parts on order.mounting bracket and 45* silicone elbo.piss on this homemade thing it will never be as good as the AFE stage II.thats what i'll get next.i am curently running my stock air box
The ATS housing replaces the OEM cover over the compressor wheel, in the intake or cold side of the turbo. The EBPV is in the OEM cover over the turbine wheel, in the exhaust side of the turbo.
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
