Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
well, after a day lone thrash to install the ITP reg return system, ATS housing, and the DIESELSITE boot kit i have a problem. this thing is too stinking loud! i am taking the truck on a vacation trip to the outer banks in a month, and there is no way my wife will ride in the truck now. and truthfully, i drove it 120 miles yesterday.... and it is really too loud in the truck. would a different air filter assembly quiet it down inside the cab? i really don't want to ditch the ATS housing, or change the WW either. any thoughts? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2010 350 Lariat CC SB 6.4 loaded... Truxx leveling kit with an Icon adjustable trackbar, 20X10 XD Monsters with BFG 285X65X20 AT KO's, S&B intake, H&S Blackmaxx with DPF/Cat delete and MBRP Cool Duals. Sound by Ford DVD/Nav/Sync, Audio Control, JL Audio, and Focal.
SOLD:
'02 Lariat CC SB Edge hanger leveling kit, 16X10 M/T Classic lock wheels, 315/75/16 BFG AT KO's, DPPI duals, 4 gauge pod with autometer C2's, AFE Stage II intake, wicked wheel, ATS housing, Banks Big Head, complete Dieselsite boot kit, BTS valve body, DP-Tuner F-5 chip, ITP boost regulator, ITP regulated return kit, KCM HPX line, Supercrewzer Badges. Sound by: Alpine, MB Quart, Image Dynamics, and Audio Control
You need a closed air box (AIS type) to keep the intake sounds down. An open air filter is what causing all your sounds to be louder in addition to the WW which forces the air at a much higher rate on lower RPM's.
You could also try and add some more firewall insulation in the cab.
Give the truck to me, I like the noise(and the smell), then you could go buy a Duracrap, those are quiet. J/k! Diesels are supposed to be loud. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
__________________ Early 1999 F350 CC/LB 4x4, 7.3L, 3.73LS
*6" Lift
*315/75/16 BFG AT,
*16x10 Outlaw II's(not my favorite rim),
*Warn Hubs
*203 degree T-Stat
*lotsa lights
*Tymar HX hose
*Dual 5 inch stacks
*Tymar Intake
*Isspro guages and color matched triple pod
*Fresh beefed up 4r100 from Greene @ Quality Trans. in Anchorage Alaska
*TS 6 pos chip-no start, high idle, 50, 75, Fuel 7, 140 xtreme....
*Tymar coolant filter kit
*6.uh oh Intercooler
*Firestone RideRite 5,000lbs bags
The AFE Stage II comes with a partition that attempts to contain some of the noise. The Ford AIS should be quieter than either the Tymar or the AFE Stage II. If you thought you could find, fabricate, or otherwise end up with one of the aftermarket airboxes to use as a partition, it would help.
I think that the TAG helps to keep the noise down, but I don't know if it will fit in the ATS housing, or if it would make sense to use those two parts together.
I haven't heard the ATS housing personally, but it gets rave reviews for increasing the owner's level of satisfaction with the overall turbocharger experience. (it makes it louder) [img]/ubbthreads/images/graemlins/smirk.gif[/img] You may be in a tough spot when it comes to the housing, because I guarantee you'll like surge and stall less than you like your new noise level.
I have one last thought for you: Air in your fuel makes your engine louder. In the past, have you noticed your engine grows louder when you have less than 3/16 of a tank of fuel? I did. You might benefit from one or a combination of the several air removal/avoidance fuel system mods. They are:
1) bypassing the orange rubber check valve in the fuel pickup foot with a section of straight stainless tubing
2) eliminating the quick-disconnect fittings wherever they are in service sealing against suction rather than pressure, since they will eventually allow air to leak into the fuel stream.
3) extending the return in the tank, and eliminating the mixing valve
4) adding an Airdog
5) de-burring ID of fuel line tube ends
I've got rubber line wrapped with wire loom and connected with hose clamps from my fuel tank to the Airdog, where the fuel stream is pulled by vacuum. I continue to use the quick-disconnect fitting between the Airdog and OEM fuel pump, because the Airdog pumps fuel to the OEM pump at 15 psi pressure.
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
let me tell you guys.... it's like sitting in the dentist's chair for an hour with him drilling away on your teeth! there is ZERO surge, and the boost spools up really fast. it works great, just too loud for me.
Darth, my engine isn't loud... just the opposite. since i installed the regulated return, and the hpx crossover, it seems alot quieter. it's just the WHISTLE
SOLD:
Don't know if anyones tried it before, but if you could put dynomat on your firewall and interior that might help also.
Personally, I love the noise. Of course, that could also be why I'm partially deaf now. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
2002 F-250 Lariat 4x4 crew-cab short-bed automatic, lots of stuff from DI Performance (Diesel Innovations)713/984-9441, Terminator hpop, ATS trans, and some good help from Chris Pitre at Pitre Automotive of Lafayette, LA 337/945-8049 (and a few other great sponsors) pm me for any details; Best time on 37's = 13.09 @ 102mph, #2 only;12.18 @ 111.71mph on Da Juice
Current Project: '86 Toyota regular cab, full tube chassis, fully built 7.3 Diesel Innovations Powerstroke engine and Terminator hpos
i went from the ais to the afe stage 2 with proguard filter and it wasnt much noisier at all just alot more seat of the pants pulling power
02 f350 7.3 crewcab 4x4 lariat short box. 8 inch bds all spring with bilsteins all around. dual bilstein steering stabalizer. leer browning edition topper, 37 inch toyo mt on ar trex wheels. autometer gauges on pillar.,afestage 2,non ebv pedastal, progaurd,zoodad/pred maximizer cover,jessies highangle driveshaft, procomp billet spacer for front driveshaft,husky floor liners,bushwacker oem fender flares, 4.30 gears installed,DP-tuner stock-20-40-60-80,banks quickturbo, mbrp 4 inch exhaust,banks power elbow,banks quick turbo,banks 6.0 intercooler and tubes,aih delete,itp boost fooler and my favorite transflow 46 gal rep tank.dieselsite water bypass filter,sprayin bed liner, bed slide, are tonneau,clear tail lights, projector headlights,all aluminum grill no plastic, dual front shock hoop dr and dual bilsteins up front
i upgraded my stereo and put a sub behind the rear seat and that seemed to cut down on the engine noise. i have a AFE stage II and i get a little noise when i get on it, but at highway speeds it is surprisingly quite (even with the 4" straight exhaust). either switch to the AIS or an AFE.
02 white CC LB SRW 7.3. Edge J/A, AFE Stage II, 4" straight exhaust, WW, TM wastegate, billet TC, TransGo Tugger II, 203 therm, AIH delete, HX mod, engine boot kit, ZooDad, 2.5" front shackle, 2.5" front springs, SS brakelines, 5" rear block, rear airbags, ProComp traction bars, 37 12.5R17 ProComp X AT's on 17x9 ProComp 7089, painted door handles, billet grille, DEH-P650 Pioneer head unit, 400watt amp, 10" sub, 08 mirrors.
I dont think the ATS housing makes it louder, it is the WW that does it. You have to get rid of that open element filter. Go to the Ford Severe duty one, it is completely encased like a stock housing but flows nicely. Just kind of pricey I think!
I am partial to that whistle, Love my truck sounding like a KW rolling onto the throttle!
Sweeeeeet ,,,,and it aint a HEMI!!!!
I do understand about the wife though. Mine does not ride in the truck that much,,
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
