ATS ported compressor housing - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 06-20-2009, 08:32 PM   #16 (permalink)
I picked up a compressor housing today and I am going to put it on, on Monday with the stock wheel. (pulling the Wicked Wheel out) I was also wondering if it would be worth doing the 1.0 exhaust housing too. I pull a 30 foot house trailer 10K and my EGT's get up there sometimes. Will the ATS housing and stock wheel get me more air flow thus lowering the EGT's.
7.3 4" turbo back, 6637 DIY and 6 pos TW chip.
TIA
deputyzach is offline
Old 06-29-2009, 09:12 PM   #17 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Cool hard facts or ???
Originally Posted by ITPDiesel View Post
The best PERFORMANCE will be had with the housing and stock wheel. Not sure about everyone else, but I'll take actual performance over whistle all day, every day.
Actual proven claim or just your opinion? I would like to know since my housing+outlet+turbo master+cfm plus' new air intake are arriving this week.
I have the "ww" and it helped a lot, it is louder and I have the stock airfilter box. I like the whistle but I agree that "sometimes" it can get annoying but most of the time is a satisfying noise...lol
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 06-29-2009, 10:24 PM   #18 (permalink)
klhansen's Avatar
My Photos: (169)
Think of it this way.
It takes energy to make noise, and that energy could be put to better use making air instead.
Just a thought.
Hard or no-start? Check Here
klhansen is offline
Old 06-29-2009, 10:32 PM   #19 (permalink)
My Photos: (23)
Just a thought.
or maybe the blades are little more aggressive moving more air and that makes it whistle more......regardless, comparing both the WW "looks" like it would move more air, and wants it to be quieter, of course.......imagine people test driving it and getting "annoyed" by a loud whistle
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 06-30-2009, 01:56 PM   #20 (permalink)
jetskier's Avatar
My Photos: (23)
I've had the ATS housing a couple years now w/ the stock wheel. It whistles loud from 9-12 psi and goes away. I believe the WW has alternating fins reduced in size as a fix for the surge so I don't think it can move as much air as stock.
I'd rather have it quiet than hear that deafening whistle all the time. the 3 psi range is all I need.
2000 F350 XLT 4x4 CC LB SRW, PSD, 4R100, MSOF, 3.73 TrueTrac, OTC, wired keypad, AIC, DRL, Gauges, DP F6 Live Tuned, Ford AIS w/ sleeve & Zoodad, ATS housing, 31-row trans cooler, HPX line, Magnaflow & BrakeSmart.
jetskier is offline
Old 06-30-2009, 02:47 PM   #21 (permalink)
i want to keep an eye on this thread
2001 F250 powerstroke
afe stage 2 intake,ats housing,wicked wheel,banks exhuast housing,banks power elbow w/ 4" straight pipe,banks waste gate actuator,banks intercooler,
banks 6gun,TS performance 6 position chip,stage 2 water/methanol,superlift ladder bars,3:73 gears, 35 bfg mud t/a,ccv mod,zoodad mod,dieselsite 203 stat & billet housing,itp in tank & pre pump kit,brush gaurd w/ KC daylighters
Jason01stroke is offline
Old 06-30-2009, 02:58 PM   #22 (permalink)
From what I have read the stock wheel gives better low end performance while the ww has eliminated turbo surge on some vehicles and might give more top end HP. I think the ww was stock on pre-99 turbos. I have not seen dyno curves of the two wheel types side by side so my understanding is gleaned from what has been discussed here and on other sites.
A dyno curve would help a lot !!! Anybody?
Work rig - 2000 F250 7.3 4x4 3.73 auto, 285/75 Michelin ATX, hpx, zoodad, hutch mod, 4" mbrp, 6637, isspro 3 pod, Trucool, ATS ported shroud (someday).
Farm rig - 85 6.9 xl t18 4x4 3.73ls, 88k orig miles, zig-style ram air, electric fuel pump, soup bowl delete, manual 12v glow plugs, Battery isolators, KISS principle generously applied.
Njellison is offline
Old 06-30-2009, 06:17 PM   #23 (permalink)
My Photos: (23)
I am not sure if they actually got the thing on a dyno since it does not show it, BUT, it might be true, so here it is, you can go to the last seconds to see the claim or just watch in its entirely I guess...
YouTube - Wicked Wheel Install
Now, where the heck did I put my stock one LOLOL
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 06-30-2009, 06:23 PM   #24 (permalink)
My Photos: (23)
nice video, you guys probably seen it, at 1:47 sounds like mine when I get on it....that very high pitch whine...first day I heard that I thought I had a bad leak or something, it was after the WW was installed, anyways watch it and enjoy those that drive the beautiful 7.3's :YouTube - 7.3 Powerstroke with 38R and 1.15 exhaust housing
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-01-2009, 11:12 AM   #25 (permalink)
The way the WW gets rigde of surge is by moving less air. I had the WW on my 01 to fix the turbo surge. I have 4" turbo back, 6637 intake and dp tuner and empty I would have turbo surge the wheel fixed it but my EGT's where higher 75-100+. Just this past week I put the ATS ported housing housing and stock wheel back in it and pulled 11K, 600 miles west across windy NE at 80 mph with no surge at all and my EGT's were steady on 900-975 depending on grade and wind gust. I still plan on doing the 1.0 exhaust housing to bring the temps down a little more.
Any body that needs a WW I have one for sale.
10-2000 DOP, 7.3 auto, leveling kit, 4" turbo back exhaust, AFE intake, ATS turbo, 6 pos DP (stock, HI, econ, tow 60, daily 80, smoke), ranchhands f/r, train horns, OBA, air bags, stage 2 tranny, billet converter.
Old 07-01-2009, 09:42 PM   #26 (permalink)
My Photos: (23)
Nice to see that ATS makes a difference, I just wish I had all of that I have now when I towed 3 cars plus trailer over 2800 miles driving 14 hour days. I could not be happier and more proud of this beautiful tuff 7.3 powerhouse, I remember how it screamed up and down the grades in Virginia on cruise control LOL
Thinking back I would probably take it easier if I had to do it again.
But it performed beyond my wildest dreams and expectations, no matter what they say about 6.0's or 6.4's, cubic inch and simplicity still rules.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-02-2009, 06:31 PM   #27 (permalink)
So that begs the question, how does the ported shroud work? From what I've read it has a "bleeder ring" built into the housing so that it has a pressure relief. What's to stop the air bleed from reducing compression when you don't want it to. Could it be that the ported shroud reduces HP ?
If someone who has one or is knowledgable on the air flow dynamics can chime in that would be great.
Old 07-02-2009, 06:46 PM   #28 (permalink)
woodnthings8's Avatar
Probably the biggest improvement is the 4" inlet. The factory turbo has a 3" which is ok with stock tuning and the stock airbox. But when a intake system or BHAF is put in it allows beter flow to the compressor. Then you throw in tuning that allows more fuel which requires more air. The 3" inlet becomes the restrictor to the airflow, that is why the WW reduces surge. It is actually less effecient due to the staggered blades. Surge is really cavitation.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 07-02-2009, 10:46 PM   #29 (permalink)
My Photos: (19)
Have you seen the ATS housing, it may have the 4" inlet, but the area that the inlet to the turbo, is no bigger. that extra .5" around the outside is part of the bleeder ring thing.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 07-03-2009, 12:10 AM   #30 (permalink)
A 3" inlet has just over 7 sqin of area. A 4" has 12.5 sqin of area. That probably makes the difference. Just having the stock inlet tube neck down from 4" to 3" creates the air to increase pressure as it gets sucked into the wheel. I plan on buying the compressor housing soon, because most everyone says it will eliminate surge without boost loss.
Ken
TSB Information
