Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-04-2009, 04:57 PM   #31 (permalink)
My Photos: (10)
The ATS housing works great to eliminate surge. And yes I took off the WW and put the stock one on and it does seem to do better. I have hit 24psi with Jody's 80T and a DIY air filter. I couldn't do that with the WW. I sure tried though.
Once you get the new housing, you will see what I mean by the inlet to the turbo is no bigger with the ATS housing than stock.
'02 F-350 "Babe The Big Blue Truck" 4x4, Ext. Cab, 8' bed
DP-Tuner 80T, ATS Compressor housing, DIY intake, openair CCV, 80HP 'pane shot, SBC DD all ceramic clutch, ISSPRO boost/pyro gauges, 4" lift, 255/70R22.5 tires, brake linelock, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, and who knows what else... oh and a Kennesaw Mountain front bumper (now tried and true)
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, D20, 3.5" WH sus. lift, 3" body lift, 35" BFG muds, Stock Dana 30 front with Lock-Rite, disk brakes, Warn Hubs, Stock Ford 9" rear with mini spool
BTBBT is offline
Old 07-04-2009, 07:24 PM   #32 (permalink)
woodnthings8's Avatar
I have seen in pictures what you are describing, I just haven't seen a picture of the insides, Looks like the smaller area helps feed the air but hard to tell from the pictures. Do you have any complaints about the quality of the housing? I know I have read many posts that guys don't feel the fit and finish is a very high quality. I was wandering if ATS has improved their quality so they wouldn't get a bad name or if everyone is just accepting the product now.
2002 F-350 CCLB 4X4, HD4R100 , 4" Diamond Eye exhaust, Powerslot rotors, DP Tuner-F6, Autoenginuity, KCM S.S. HPX Line, S&B Filters intake, Autometer gauge pod, Inovations canopy,Banks Big Head wastegate actuator, 6.0L Trans Cooler, Zoo-dad, Dieselsite Coolant Filter, DVD and always looking to do more....
woodnthings8 is offline
Old 07-05-2009, 07:31 PM   #33 (permalink)
Supporting Member
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Is the ATS 1.0ar also a good idea along with the ATS ported inlet?
I have the ATS in the box but I saw the ATS 1.0ar for around 200 bucks, maybe it would be a nice addition to all that I have, what do you guys think??
Too much lag maybe? I already have long gears 3.73 with my big wheels......
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
Wicked Wheel
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using SCT 100hp Performance tune.
Wastegate disconnected for now...
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Camera,DVD,Nav.,Satelite Music.
Jason smooth topper.
Here but not installed: 4'' Ported Housing,ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.,TRU Cool tranny cooler (no time )
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 07-05-2009, 08:47 PM   #34 (permalink)
My Photos: (10)
I have a picture showing the inlet, hopefully it is below.
I didn't have any issues with the casting. I also didn't have any issues with the actuator mounting tabs being in the wrong spot. It doesn't look as clean and professional as the stock housing, but it works.
BTBBT is offline
Old 07-05-2009, 09:31 PM   #35 (permalink)
JimTJr's Avatar
My Photos: (6)
Ok, the WW does not stop surge only because it moves less air, it's "MAP" is different. The RPM it could surge at IIRC. Also with the staggerd blades it can spool quicker, and only moves SLIGHTLY less air, not much for sure.
The ATS does not make any more whistle than a stock housing does I don't think. Infact with my stock wheel on I have virtually no whistle now. (Man I miss it too, I had an early 99, and had the ww on my last turbo on here.) But when it went out, my new center section came with a stock wheel, and my ww was damaged slightly. The ATS stops surge and stall because of the PORTED housing.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 6pos chip, AC Stage 1 sticks, 4" Turbo back straight pipe/stainless 5" tip 131st B/W MoAirNatlGuard B-2 BOMBERS at WHITMAN AFB, Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 07-06-2009, 08:54 AM   #36 (permalink)
Supporting Member
My Photos: (23)
Don't you just love it when it starts "singing"!!??
I could not do w/o the whistle guys, it is music to my ears and gives my truck the attitude it needs.
I wonder if with the ATS shroud and ATS 1.0 a/r housing that I have coming will be even louder....jet engine anyone
Wicked Wheel
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
Old 07-06-2009, 10:06 PM   #37 (permalink)
If you install the ATS housing with the stock wheel you definitely will have more whistle.
Not a "cummins louder whistle" but definitely more than the ford stock whistle. It's not a jet engine whistle, but a nice noticeable improvement.I like it.
bbsplash is offline
Old 07-06-2009, 10:18 PM   #38 (permalink)
Supporting Member
My Photos: (23)
Talking Jet engine, really!?!
LOL, jet engine was a lame comparison I know, I was just teasing.
The wicked wheel will be even louder, it is loud now and I have the stock housing and stock air box.
Wicked Wheel
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
Old 07-07-2009, 08:27 PM   #39 (permalink)
JimTJr's Avatar
My Photos: (6)
I guess since I went from the Wicked Wheel on my turbo, to the stock wheel with the ATS I don't notice it anymore....
I DO miss it.
JimTJr is offline
Old 07-07-2009, 09:15 PM   #40 (permalink)
Supporting Member
My Photos: (23)
Did you remove the "foil" around the pipe? people say it makes it louder, I haven't yet,I wanted to buy another stock pipe and remove that one and keep my stock just in case.....on another note.....today I had some spare time and drove around changing programmer settings, I drove in stock mode and it shifted better and it ran pretty good for stock, when I used SCT it didnt shift good when in wot from a stop,the best so far was Superchips on tow safe mode. Why would that be?? transmission does not like the programmers apparently.
Any ideas??
Wicked Wheel
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
Old 07-08-2009, 08:55 AM   #41 (permalink)
padgett114's Avatar
I have the WW and it has a really nice whistle to it. I don't know about lost of performance. With my bts chip on 80E I can hit 35lb of boost all day and hold 25 to 30lb. This is on the stock turbo.
2000 f350 powerstroke 4x4,voltant intake, wicked wheel,MBRP 4 inch exhaust, BTS 6 position chip,BTS valve body, 35" Goodyear MTR's, Autometer carbon fiber gauges,Boost Relief Valve +, air intake heater plug, Max AC Assist,
padgett114 is offline
Old 07-08-2009, 08:59 AM   #42 (permalink)
Supporting Member
My Photos: (23)
Dang!! 35 lbs of psi??!!! U sure!!?? Yesterday I hit around 26 but the needle was vibrating while at it LOL was begging for mercy!!
Wicked Wheel
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
Old 07-08-2009, 09:15 AM   #43 (permalink)
padgett114's Avatar
Seems a little high for me too but on stock mode the boost gauge move pretty slow and will get to 20-22lbs and moves a little faster with each advancement in toons. I had to install the boost relief valve from dieselsite.com so the ses light won't come on. On the 80e and 120 it will easily get to 30plus lb when getting on it.
Old 07-08-2009, 09:55 AM   #44 (permalink)
Supporting Member
My Photos: (23)
with the wastegate connected I was lucky to get 16 psi, when I finally pull the red hose out, I started seeing good numbers and it runs better, it still relieves pressure when I am up there in numbers but it is not recommended, I have the Turbo Master to be installed soon, just waiting on my ATS ported housing...
Wicked Wheel
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
Old 07-08-2009, 10:12 AM   #45 (permalink)
Gustad2005's Avatar
Your pulling your turbo I hope?? It can all be done with the turbo on but the amount of time you spend messing with the little e-clip it aint worth it. All in all ATS housing and Turbo master make good boost on a stock turbo.
2001 F-250 4X4 LARIAT Crew Cab,7.3, FORGED RODS, 4" SS DP to 5" SS exhaust with Aero 5050, X-Code springs, Mini Spring Pack, Adj. Track Bar, AFE Stage II, Air Dog, Turbo Mater Wastegate, ATS Housing, CCV Mod, IC foil Delete, DP tunes (No Start, Stock, 1500 High Idle, 40 Tow, 60 Tow, 80 Eco, 120 Race, 140), JW valve body, 6.0 Intercooler, In-Tank mod., Harpooned Tank, Zoo-dad Mod., Autometer Cobalt series: Pyro, Trans, Boost, AR Atlas 16x8 with ProComp MT 285/75/R16D, 05 headlights, In dash DVD Player
Gustad2005 is offline
