ATS ported compressor housing - Page 4 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-08-2009, 02:14 PM   #46 (permalink)
woodnthings8's Avatar
with the wastegate connected I was lucky to get 16 psi
That is exactly why I dumped my Superchips tuner. I could get 21 lbs with stock tuning, 25+ in high performance, but in tow performance and tow safe the truck could barely get out of it's own way and only 16 lbs of boost. I called SC several times and asked if this was how it was supposed to be or not. They had me send the tuner back to them for "reprogramming" which accounted for me wasting time and money for shipping as nothing changed. They told me soomething was wrong with the truck! Well something was wrong because I removed the Superchips and installed my DP-Tuner and now I get 30 psi in 80E and 26 psi in 60hp Tow. Tells you something about Superchips and there programming. If they would be honest about their product and share information as to what you should expect on a truck, I might not degrade their product to anyone who will listen!
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 07-08-2009, 02:27 PM   #47 (permalink)
jetskier's Avatar
My Photos: (23)
I don't doubt that at all about Superchips. I switch in April 2006. I can't get 30psi, but I get 26 psi in both the 60T and 80E. I'm perfectly ok with those numbers to keep my turbo humming along for another 9 years.
2000 F350 XLT 4x4 CC LB SRW, PSD, 4R100, MSOF, 3.73 TrueTrac, OTC, wired keypad, AIC, DRL, Gauges, DP F6 Live Tuned, Ford AIS w/ sleeve & Zoodad, ATS housing, 31-row trans cooler, HPX line, Magnaflow & BrakeSmart.
jetskier is offline
Old 07-08-2009, 05:31 PM   #48 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Talking
Originally Posted by Gustad2005 View Post
Your pulling your turbo I hope?? It can all be done with the turbo on but the amount of time you spend messing with the little e-clip it aint worth it. All in all ATS housing and Turbo master make good boost on a stock turbo.
Yep, I have so many new parts for the turbo it has to come off, no choice there. Between the non-ebv pedestal, outlet,ATS 1.00 a/r housing,ATS ported shroud,turbo master...........the darn thing will be off for a while LOL
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 07-08-2009, 05:36 PM   #49 (permalink)
My Photos: (23)
Talking
Mine runs fine with Superchips, almost better than SCT. At least the shifting is not all screwed up, it still runs strong for a tow-perf setting.
I agree with the lower EGT's part, rather keep this baby running for decades than be hauling butt around town and only last a year or 2....I will have to try DP one day, seems like us 7.3 guys just gotta have it!!
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-10-2009, 12:00 AM   #50 (permalink)
The E clip on the turbo master was a total PITA...
The housing can be changed rather quickly, but when it comes to putting the e clip back on you will need Beer,band aids,a hanger,potato,duct tape, sledge hammer and no kids anywhere around to hear all the foul words that will be coming out of your mouth after you try for the 986th time to put that damn clip back on.
We can put a man on the moon but Ford can't give you another inch of clearance between the wastegate and the firewall........geeezzzz
Seriously, I tried for hours and couldn't get it, grabbed the wifes makeup mirror to see the back of the turbo and slid that little sucker on.
bbsplash is offline
Old 07-12-2009, 01:13 AM   #51 (permalink)
TransBrain's Avatar
Ford just wants you to lift the body off the frame when you need that extra inch of space. (Insert sarcasm!!)
Cool thread. Cool video a couple pages back. Does the CFM intake help much??
I guess I better order a housing. With a superchip and an Edge Attitude(that just took a crap on me btw), I get a good amount of surge going up a pass. Throttle jockey to rid right now.
Last edited by TransBrain; 07-12-2009 at 10:22 PM. Reason: Edge Attitude instead of Evolution
TransBrain is offline
Old 07-12-2009, 03:01 PM   #52 (permalink)
My Photos: (23)
Cool
I guess I better order a housing. With a superchip and an Edge Evolution (that just took a crap on me btw), I get a good amount of surge going up a pass. Throttle jockey to rid right now.
CFM helped, I checked the temperature of the inlet after a long drive, the red intake was cool, the polished one from the turbo of course was hot as hell, separating them can only be good for cooler air feeding the engine.
The red piece is not made out of aluminum but a very light composite material, since it is cool air I suppose it doesn't need to be aluminum like the one connected to the turbo.
I am installing my CCV delete and my S&B CAI and my boost fooler, I also removed the foil around the IC pipe and painted it w/ a ceramic coating spray paint, it will probably be louder now....it will give some attitude to my Midnight Xpress
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
