Back to BigOil & NO " S" versus "T" ! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 12-03-2007, 09:59 PM   #1 (permalink)
whitjo's Avatar
There ain't a dimes worth of difference in the operation of either one, so I need some tips on gettin' it all put on and working!
I got a pump off Ebad(with an IPR on it!) and I'm getting parts together to build a dual HPOP setup.
Some I'll buy, some I'll make!
Questions:
2 line output with Xover, or 4 line?
Single or dual IPR set-up?
Again, No pissing contest or playground "my dog's bigger than your dog" stuff.
OK?
Early '99 F250 SD, 4X4, SuperCab, Long Bed, 7.3L "PowerStroke" Diesel, Auto, PMT1 PCM w/DPTuner 80 tow, 190K miles,
Volant intake, ISSPRO gauges, BDS front leveling kit, 4" straight piped, Dick Cepek 18x9 DC1-Chrome, Nitto Terra Grappler 325/65R18,
Pro GOD, Pro Guns, Pro Life Important Notice, Pro Life changes when someone breaks in.
whitjo is offline
Old 12-03-2007, 10:44 PM   #2 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Feedback Score: 2 reviews
Re: Back to BigOil & NO " S" versus "T" !
I have another brand with only 2 lines.
I say one pump one IPR and two pumps two IPR's.
Don't go cheap on the lines that high of pressure will make a mess if they break.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 12-03-2007, 11:15 PM   #3 (permalink)
whitjo's Avatar
WHOA DOGG!
Thanks, I'm gonna get a local shop that does custom stuff to do me some HP braided SS lines. does the two line output need a crossover hose?
whitjo is offline
Old 12-04-2007, 01:31 AM   #4 (permalink)
seems like the guys who run 4 lines like it a lot. that said, mine is almost done and i'm only running 2.
personally i would go one IPR but i would change the location.
2002 F250
DarkShadowDiesel is offline
Old 12-04-2007, 02:04 AM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: whitjo</div><div class="ubbcode-body">WHOA DOGG!
Thanks, I'm gonna get a local shop that does custom stuff to do me some HP braided SS lines. does the two line output need a crossover hose? </div></div>
Yes, you need to equalize the pressure so each head sees the same amount of oil. The S and T cross one pump to the other pump, not sure about any others.
My Truck: Early '99 F350 CC LWB 4X4
Annoy A Liberal
Work Hard, Succeed, Live Happy!
Family of 5 saved by Grace.....
strokin_early_99 is offline
Old 12-04-2007, 02:53 AM   #6 (permalink)
GSXRTURBOQUAD's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DarkShadowDiesel</div><div class="ubbcode-body">personally i would go one IPR but i would change the location. </div></div> [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img] It does the job. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Precision Hybrid from BWD), Industrial Injection BD Injectors, DIIC with custom stainless 3" piping, Terminator HPOS, DI headstuds, BTS tranny, TruCool 40GVW cooler, DP LIVE TUNED F5 with Extreme ICP(ya, it works)!, Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be shortened.
97 F350 Regcab4X4: Twin Turbo's, lots of fuel and oil.
02 Excursion4X4Limited: Wifes ride: Terminator HPOS2, DP Tuner F5
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 12-04-2007, 03:27 AM   #7 (permalink)
Two IPR's are just more to go wrong and it's not nessasary.
4 lines may help, haven't seen any dyno numbers to prove it.
You need to equalize the pressure from each pump in some manor.
There is a difference between brands of pro-built big oil.
pmurray is offline
Old 12-04-2007, 03:42 AM   #8 (permalink)
whitjo's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DarkShadowDiesel</div><div class="ubbcode-body">seems like the guys who run 4 lines like it a lot. that said, mine is almost done and i'm only running 2.
what do you mean when you say "change the location" of the IPR?
it has to be in one(or both for two pumps)of the pumps the way it's located in the stock set-up to operate properly, correct?
whitjo is offline
Old 12-04-2007, 04:02 AM   #9 (permalink)
whitjo's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69W900A</div><div class="ubbcode-body">Two IPR's are just more to go wrong and it's not nessasary.
There is a difference between brands of pro-built big oil. </div></div>
Just from pictures of the two popular "pro-built" brands, they both simply use a balance tube between the pumps to equalize the pressure differential, simple enough.
I assume then using a 4 line output would accomplish essentially the same thing?
I think for simplicity, 2 lines would be less hassle as far as having hardware(high pressure lines) subject to failure.
Forgive me for being redundent on some of these questions, but diesel "mods" are still new territory for me and I want to understand the theory, application, and results of making these improvements.(since most of them are DANG expensive!)
whitjo is offline
Old 12-04-2007, 08:20 AM   #10 (permalink)
DZLJIM's Avatar
If you're making your own pumps, then make a remote IPR mount and you'll only need one IPR.
Feed the remote IPR mount with an output from each pump such that they become the 'balance tube' between them, too.
I have not seen the 4 line Kit, but I can't see how you could do that with a remote IPR. Pick one or the other I guess. For the 4 lines you'd need to use 2 outputs from each pump to see any advantage. The rear pump has 3 outputs but the front only has 2. Splitting off of one outlet to feed 2 lines won't move any more oil as the port's the restriction.
When I built my first big single gear pump I had 4 lines, but they were fed off a manifold that was then fed by a huge supply from the pump.
Make sense?
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-350, 4x4, CC Short Bed.
DzlJim.com for some redneck engineered projects.
DZLJIM is offline
Old 12-04-2007, 08:45 AM   #11 (permalink)
whitjo's Avatar
DZLJIM
Makes perfect sense.
Since you mentioned it, I was thinking(pondering)a gear pump set-up as well.
What was your success with that?
I've built several high pressure hydraulic systems with some high volume pumps but usually with large reservoirs and large feed lines to flow the high volume.
If the ports are the restriction, then there's really no need for high flow rates.
whitjo is offline
Old 12-04-2007, 10:00 AM   #12 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Soaggydogg</div><div class="ubbcode-body">Don't go cheap on the lines that high of pressure will make a mess if they break. </div></div>
lots of oil on a hot engine very bad...very Fast.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
Old 12-04-2007, 11:04 AM   #13 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DZLJIM</div><div class="ubbcode-body">If you're making your own pumps, then make a remote IPR mount and you'll only need one IPR.
Make sense? </div></div>
Do you need a special plug to take the place of the stock IPR? It's kind of a funny looking device with multi levels fo O rings.
Annoy A Liberal
Old 12-04-2007, 11:28 AM   #14 (permalink)
I used jb weld and ductape...
sorry couldn't help myself
(don't do that )
Old 12-04-2007, 02:16 PM   #15 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: strokin_early_99</div><div class="ubbcode-body">Do you need a special plug to take the place of the stock IPR? It's kind of a funny looking device with multi levels fo O rings. </div></div>
yes - it has to be machined to match the IPR
2002 F250
