Bad news just keeps coming my way - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-12-2009, 04:06 PM   #1 (permalink)
Ordered the DP Tuner from Jody, had a certified shop install the chip and do axwalk around, ran the truck ran fine, shut it off and restarelted it to find the check engine light on, now truck just cranks and won't start mechanic thinks that the PCM is fried Anyone have any ideas on what happened or ever heard of this happening before?
Nick
1999 F-350 Dually 7.3 diesel lifted 8.5inches 37x13.50 xtream all terrains
Just Installed a DP Tuner F-5 chip, with stock, Decel, 60 Hp Tow, 80 HP econo and 120 HP performance and WOW!!! k&n airfilter Road Armor front bumber Warn 15000 winch Shift Kit, Beefier tourqe converter. Kenwood Indash Navigation, Sirius Radio, Back up camera, Kodiak Electric Steps HID Conversion Kit..
Next up is Gears!
buzzy12 is offline
Old 11-12-2009, 04:49 PM   #2 (permalink)
And should I be stuck paying for a new PCM? Or should that be the shops resposibility?
Next up is Gears!
buzzy12 is offline
Old 11-12-2009, 05:11 PM   #3 (permalink)
Diezel Dawg's Avatar
Why did u have ashop install this chip? Did u make sure they followed every step while installing it? if they left the key in the ignition, it could have caused it. And yes, they installed it, they should be held responsible for the PCM. Jody has very DETAILED instructions when installing his chips
Ken
99.5 7.3L PSD 4x4
WOP GQSSB TURBO
Tyrant Diesel Tunes
TYMAR Intake
Casserly 250cc Hybrid Injectors
BTS
496 hp 985 tq!! 16 Apr 11
13.74 sec in 1/4 mile @ 98.5mph
PNWFDE#2
Diezel Dawg is offline
Old 11-12-2009, 05:17 PM   #4 (permalink)
I had a shop install it because I haven't had the time to install it myself and figured It would be easier for them to install it because I'm working until thanksgiving , which is when I needed the truck by, I agree that the shop should pay for the PCM, and I gave them the detailed instructions and told them to follow them to a t, wether or not they did is a differet story, i've talked to Jody and he said that the only way to fry the PCM is if they had the key in the ignition while installing it.... Just my luck
Next up is Gears!
buzzy12 is offline
Old 11-12-2009, 07:56 PM   #5 (permalink)
fxdwgi's Avatar
Whoa.....I think it took me 30 minutes to install mine.
Dude you must be a busy guy.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 11-12-2009, 08:24 PM   #6 (permalink)
ya I run a research boat and will be out to sea until the 23rd of nov had truck dropped off.... How do you guys like the dp tuner? I'm just nervous to reinstall the tuner and have it ruin another PCM..... If I do reinstall it I'm gonna do it myself but just a little weary
Next up is Gears!
buzzy12 is offline
Old 11-12-2009, 11:34 PM   #7 (permalink)
It is a pretty simple install. I wonder if the cam position sensor went out. That would be pretty remote, being you just had the tuner installed. But it is a possibility. But like the other guys said, if the chip came disconnected, or connected in any way while the ignition was in the on position, the pcm and chip itself are probably cooked. Either way, I hope the shop will step up and cover it for you. Best of luck.
NVJAY775 is offline
